Old 02-08-2019, 05:09 PM #1
IndyFastlane's Avatar
IndyFastlane IndyFastlane is offline
IndyFastlane is on a distinguished road
Towing mods
Having just bought our 18 ORP 4Runner this past fall.....we haven’t had an opportunity to tow a trailer yet. The 4Runner replaced a 17 Tacoma which did *ok* with the help of some Sumo springs to reduce sag. I know the rear of the 4Runner is rather soft, so sag will be an issue with a trailer attached.
I’m looking for advice from those who have towed smaller travel trailers or something similar. We are replacing our popup with a small-ish 17’ camper that weighs roughly 3000# and a tongue weight of roughly 450#.
We are considering a Weight Distribution Hitch with sway control (a Fastway e2) to use with the new camper.
Question: with this setup, do you see a need or benefit to also adding airbags to help reduce rear sag?.....or will the WDH alone be adequate?
Thanks all.
2018 TRD Off Road Prem
Indianapolis
IndyFastlane is offline   Reply With QuoteReply With Quote
Old 02-08-2019, 09:26 PM #2
Fern's Avatar
Fern Fern is offline
Fern will become famous soon enough Fern will become famous soon enough
Fern's Avatar
You should still add air bags or purchase different springs.
2005 4R V8 4x
Fern is offline   Reply With QuoteReply With Quote
Old 02-08-2019, 09:32 PM #3
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
Not sure the built in receiver is for a weight distributing hitch with lift bars.
Airbags work well.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 02-09-2019, 10:56 AM #4
Airbags work well.
Thanks for the feedback/advice, guys.
I’m relatively certain that the receiver on the 5th gen is approved for a WDH, but I will confirm that.
We will plan to go ahead and get the air bags to install.
Thank you!
Indianapolis
Old 07-26-2019, 11:09 AM #5
Eddie Haskell Eddie Haskell is offline
Eddie Haskell is on a distinguished road
What is the verdict on the 5th gen receiver being able to accommodate the WDH?
Eddie Haskell is offline   Reply With QuoteReply With Quote
Old 07-26-2019, 11:40 AM #6
Titanpat57's Avatar
Titanpat57 Titanpat57 is offline
Real Name: Patrick
Titanpat57 is a jewel in the rough Titanpat57 is a jewel in the rough Titanpat57 is a jewel in the rough
Titanpat57's Avatar
Real Name: Patrick
If you search...theres multiple threads that will give you more then enough info and answers.
White 2016 TEP .....My ROAM Truck Build....... My ROAM trailer Build
Titanpat57 is offline   Reply With QuoteReply With Quote
Old 07-26-2019, 12:33 PM #7
if you have a vehicle for towing why not buy a tow worthy vehicle? idk..... sure it's rated for 5k? but id rather pull with a half ton truck. Just like any of my trailers that technically half tons can pull i still use my f250
Old 07-26-2019, 01:07 PM #8
Cymon's Avatar
Cymon Cymon is offline
Real Name: Chris
Cymon is just really nice Cymon is just really nice Cymon is just really nice Cymon is just really nice
Cymon's Avatar
Real Name: Chris
I’ll throw in my .02 although I’ll admit I’m no expert and most of what I’ve learned is from this forum and other research.
First the 4runner can use a WD hitch. Where people get in to trouble is getting one that is overrated for the vehicle and tongue weight. Then with the overrated hitch the torsion bars are torqued too much causing damage.
I recently installed airbags (just last week) because I often have a very loaded vehicle and tow a m416 that is often loaded (I usually have a tongue weight between 200-275 lbs). I have been researching though because we are looking into the potential of getting a travel trailer that is about the same specs as the OP.
Here is what I would do, and please correct me more knowledgeable towers.
Install airbags to reduce squat.
Get a properly rated weight distribution hitch with sway control (sway for me is the bigger concern because of the wheelbase and weight of the 4runner).
When towing pump up the airbags to reduce the majority of the squat.
Set the weight distribution hitch with the least force I can on the torsion bars to help in stabilizing the trailer, switch a little weight to the front axle and reduce sway. With the least torque on the WDH bars there shouldn’t be any damage to hitch or frame.
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
Cymon is offline   Reply With QuoteReply With Quote
Old 07-27-2019, 01:38 AM #9
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
Previously mentioned 1/2 ton truck for towing is a good idea.
SUV springs are soft. Read your owners manual. Follow the directions. Get comfortable using the transmission manual gear kick down. Compression braking keeps service brakes cold for maximum emergency braking. Get a trailer with electric brakes even if not required for your State Law.
I'm not crazy about airbags. They serve a purpose. My problem is they unload the suspension. Vehicle weight now running on two small bottles of air instead of full length metal springs.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 07-27-2019, 03:11 PM #10
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
I don’t think they are suggesting replacing metsl springs with airbags (see Semitrucks). Just small airbags that install inside the coils and provide supplemental support to the metal coils. This brings the suspension geometry back into alignment and keeps headlights aimed properly. Probably works as a reasonable short term compromise/ solution for those not looking to tow at the limit all day everyday.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 07-27-2019, 03:37 PM #11
Cymon's Avatar
Real Name: Chris
Cymon's Avatar
Real Name: Chris
This
ARB Breather Mod
Old 07-27-2019, 04:37 PM #12
Since this thread came back alive, I’ll follow up from my original post.
It was suggested above that I not tow with the 4runner and get a dedicated tow vehicle. Well, in a perfect world where I had unlimited funds and space to park another vehicle, that might be a practical suggestion.....but that isn’t the case. We will tow maybe 10-12 times a year and the 4runner will do fine for our use.
We did get the trailer I suggested above. It’s a 2018 flagstaff epro 17rk (2900 lbs dry and about 350 lbs tongue). We opted for a fastway e2 WD hitch (which also has sway control). I also installed firestone air bags for towing use, but also to assist when we have the back loaded for hauling (bags of mulch, for instance).
The 4runner does fine towing our camper. The WDH does a good job of leveling out the rig and keeping proper weight at the front of the truck. I do add just a bit of air to the bags (10 lbs roughly) and it helps some with rearend bounce.
The only issue we’ve encountered is the wind drag at higher speeds necessitating the use of s4.....the truck doesn’t like to stay in 5th gear (and/or the TC won’t stay locked), so we lock out 5th gear altogether and it works fine. Doing 65-70mph, rpms are in the 2500 range which is not terrible nor annoying. Mpg has been around 11-12 mpg which is on par with what other folks typically get towing these campers with a half ton truck.
Would I want to tow with this rig cross country for months at a time? No. But for our occasional use for regional trips to state parks, etc, it works great!
Indianapolis
Old 03-28-2021, 01:17 PM #13
MyFirstRunner's Avatar
MyFirstRunner MyFirstRunner is offline
MyFirstRunner is on a distinguished road
Did you get the Firestone airbags? How was the install? Videos online look easy enough but how was dining chunks of the bump stop?
MyFirstRunner is offline   Reply With QuoteReply With Quote
Old 03-28-2021, 11:49 PM #14
4Reak Show's Avatar
4Reak Show's Avatar
The post your after is like a year an half old. But I’ll answer: it’s not a bad job. I did it last month to ours for towing a travel trailer. I opted to pull entire bump stop out and work on it on the bench. Way easier. Dropping springs out wasn’t hard. And I used a razor blade to cut the bump stop down as directed by the instructions.
Did it totally by myself on my garage floor with jack stands in about 2-3 hours. This includes running the hoses and messing with the KDSS stuff in the back which was trial and error to prevent unknowns. Anyway, I’d recommend it.
For the record, I did a Redarc brake controller (awesome), the B&M trans cooler (also awesome) Firestone airbags (again, awesome) and we’ve ran a Blueox WD/Sway control hitch (possibly the most awesome). Drive in S4 only. No reason to hear trans extra. Plus it gives quicker control to command a down shift for hills/decel.
3000# Coleman 21 footer. Totally comfortable tow.
Old 05-12-2021, 04:03 PM #15
Awesome, thank you!
4runner , rear , roughly , sag , weight
Minor Suspension Mods (for Winch and Towing) ade678 5th gen T4Rs 8 03-26-2017 08:56 PM
Mods. Done With Mods. KISS Khjphoto 5th gen T4Rs 2 10-09-2016 06:09 PM
Physical Mods Then ECU Mods? liqourish 4th Gen T4Rs 0 09-24-2009 03:00 AM
Towing a 24-27' Boat with the V8 - What are you towing? rmd0311 4th Gen T4Rs 7 09-10-2009 08:36 PM
A Few New Mods rollingthunder 3rd gen T4Rs 26 10-14-2008 07:28 PM
