05-24-2019, 07:35 PM
#16
Real Name: Chris
Real Name: Chris
Check out this system by
@ Magnetic4R
. His was the original I saw and inspiration, I just simplified it for my needs. Here is the link.
3rd row drawer system Part 1
Oh and I just installed an ARB fridge wiring kit and installed it. I’ll do a write up soon on my thread although there are plenty of writeups on it already. So now I have the yeti for when larked for several nights and the wired to battery for road trips/local trips where we are not in one place for more than 36 hours.
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
05-24-2019, 08:43 PM
#17
@ Magnetic4R
Looking forward to your write up. I read that other thread as well. Not sure if what I want to do is even possible unfortunately. Flat piece of plywood and fridge slide all the way against the side. I may have to build a box like yours but I'm going to push it all the way against the side. Will have to modify the side latches a bit. Going to have to keep thinking about it and build some templates to see what my options are.
2018 sr5P XP Predator. Needed that 3rd row. TRD Pro susp, Toytec trd pro 2inch lift (HD springs), Gobi stealth, Falken at3w 285s, Trd and rci alum skids, Arb breather, Upper grill light source lightbar, slee sliders, wilco high clearance, arb awning, pedal commander, treaty offroad recovery points, alpha rex pro headlights, trd intake/exhaust, goal zero solar setup, greenlane offroad bumper, warn winch. C4 rear bumper coming...
05-24-2019, 09:11 PM
#18
Originally Posted by matoolie
I made a custom setup having a fridge slide with tilt, small slide out table and drawer with fold out table lid. I am using the two factory tie downs on passenger side and the LATCH anchor point on the back of the 2nd row passenger seat. All can be removed to use the 3rd row.
Do you have any pics of this setup? Especially the tie downs and latch? Thanks!
05-24-2019, 10:58 PM
#19
Real Name: Chris
Real Name: Chris
Sounds like a solid plan. Check out
@ Jhalko
build here....Post #78 and 105 for more ideas. When I built mine I used what he was doing and
@ Magnetic4R
build and did what worked for me. It definitely takes some trial and error but having a custom system that works for you is worth it in the end.
Jhalko's 2011 Limited build/travel thread
ARB Breather Mod
05-24-2019, 11:00 PM
#20
@ Magnetic4R
Did you use screws or bolts for your slide to the box? I know you said it was pretty clean on the inside because you could get an under bed storage container.
To get the box closer to the side I think the built in rings on the floor will have to be inside the box. Will have to cut holes in the top of the box so my tie down can go from the d ring on the box to the built in floor ring. Then I will try to do the same thing you did for the back middle and tie down to the third row bolt. Will see if a d ring will fit there as I dont have anyone to fabricate. Will use tie down straps at the 3 corners. Going to try to do it as low as possible, maybe raised 1-2 inches. May be able to get a narrow slide out table as well. Only going to build one box for half the rear. We shall see.
05-24-2019, 11:15 PM
#21
@ Jhalko
@ Magnetic4R
This was really helpful! Thanks.
05-25-2019, 07:15 AM
#22
I ended up taking out half of the 3rd row out and put in an ARB roller floor. It works great and I don’t have to keep bolting and unbolting a setup. 1 3rd row seat is good enough for us.
I documented the process in my build thread. For some reason I’m not able to upload photos from my iPhone right now.
Good luck!
Wild_Turkey Build Thread
2015 SR5 Premium 4x4 / 3rd row seat: Bilstein 6112/5160 @2.5"F/2"R // Total Chaos UCA // C4Fab Rock Sliders / Fuel Tank Skid / Lo Pro Winch Bumper // 17x8 FN F(X) Pro Wheels // BFG AT KO2 275/70R17 // ARB Compressor/ Fridge/ Rear Air Locker // KC HiLites // James Baroud Grand Raid // Canvasback cargo liner // Rear Diff Breather Mod
05-25-2019, 12:00 PM
#23
Real Name: Halko
Real Name: Halko
@ Jhalko
@ Magnetic4R
So funny this came up, I’m thinking about going to my third version. I want to build a box that will Allow more compartmentalization of things. I don’t sleep in the truck hardly at all anymore. I’m used to my RTT and it’s so fast to setup and take down plus I want to utilize the space above the fridge. I’ve been thinking up designs currently. Version two has been awesome for me though, solid, pretty cheap and is only in for the summer.
2011 Silver LE, 3rd row, 285 GY Duratracs, Elka remote with adjusters/Icon Overland springs, SPC UCA's, RCI skids, Shrockworks step slider with OE Trail rockers, CBI rear bumper, Indel B fridge, SPOD, and more...
Build link:
http://www.toyota-4runner.org/5th-ge...el-thread.html
05-25-2019, 02:43 PM
#24
I have a molle surround I am going to use. One of the local shops built it. Trying to attach picture from my phone, well see if it works. Its molle panels on the side and a hard top to put stuff on.
05-27-2019, 11:35 AM
#25
Do you have photos anywhere???
2017 4Runner SR5 Silver
05-29-2019, 02:34 PM
#26
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
05-29-2019, 06:47 PM
#27
Thanks for the info, although the pictures didnt seem to work and I cant track them down in the photo album section.......
05-29-2019, 07:54 PM
#28
Pics fixed
Michael
05-31-2019, 02:24 PM
#29
Pics fixed
That is a solid set up! I hope to see others follow this design.
06-02-2019, 08:44 PM
#30
Pics fixed
Nice set-up! You've given me some good ideas for something similar, so I can at least still access one of the 3rd row seats.
