Old 02-09-2019, 11:24 AM #1
bigair96 bigair96 is offline
bigair96 will become famous soon enough
Removable fridge slide with 3rd row
Does anyone with an sr5 or limited who has a third row have a fridge in the rear? How did you mount it so it comes out if you are people moving and need the third row? Thanks!
2018 sr5P XP Predator. Needed that 3rd row. TRD Pro susp, Toytec trd pro 2inch lift (HD springs), Gobi stealth, Falken at3w 285s, Trd and rci alum skids, Arb breather, Upper grill light source lightbar, slee sliders, wilco high clearance, arb awning, pedal commander, treaty offroad recovery points, alpha rex pro headlights, trd intake/exhaust, goal zero solar setup, greenlane offroad bumper, warn winch. C4 rear bumper coming...
bigair96 is offline   Reply With QuoteReply With Quote
Old 02-09-2019, 12:24 PM #2
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
I do but I ripped the useless 3rd row out. Relieving the truck of 100 lbs of dead weight. A slide mounted on the back of one of the 3rd row seats may be doable but you would need to check clearances with the rear hatch.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 02-09-2019, 12:49 PM #3
Yeah still need my 3rd row. Definitely useful for me. I'm sure someone has something that's easily reversible.
Old 02-09-2019, 04:03 PM #4
jimmynotjim's Avatar
jimmynotjim jimmynotjim is offline
Real Name: Jimmy
jimmynotjim will become famous soon enough
Real Name: Jimmy
I don't have a third row but could you use an anchor plate (fancy for piece of plywood) that attaches to the factory tie downs? Not exactly fat to install or remove, but you want a fridge attached pretty solidly.
2018 TRD ORP Super White
Pretty much stock but dreaming up mods
IG: @jimmynotjim
jimmynotjim is offline   Reply With QuoteReply With Quote
Old 02-09-2019, 05:38 PM #5
Yeah that's not a bad idea. Thanks
Old 02-11-2019, 05:24 PM #6
matoolie's Avatar
matoolie matoolie is offline
matoolie has a spectacular aura about matoolie has a spectacular aura about
matoolie's Avatar
I made a custom setup having a fridge slide with tilt, small slide out table and drawer with fold out table lid. I am using the two factory tie downs on passenger side and the LATCH anchor point on the back of the 2nd row passenger seat. All can be removed to use the 3rd row.
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
matoolie is offline   Reply With QuoteReply With Quote
Old 02-11-2019, 09:04 PM #7
Cymon's Avatar
Cymon Cymon is offline
Real Name: Chris
Cymon is just really nice Cymon is just really nice Cymon is just really nice Cymon is just really nice
Cymon's Avatar
Real Name: Chris
Just about to do the write-up on my thread. I used t-nuts and bolts the same size as the screws. Here is the link to my modular build “shelving”. I uses containers that slide in underneath with camping and recovery gear.
Cymon's Weekend Warrior and MFD Thread
Dfg Fridge Slide installed...
The tricky part was finding a place to tie down the back of my drawer boxes that still allows access and use to one side for when we travel with 6 people. Found the front bolt that attaches the 3rd Row seats to the floor. The attachment point is what Frontrunner uses for their GX460 rear storage units. Had a person at my wife’s job fabricate a stainless steel tie down that would bolt up. So now I have a completely modular unit. First pic is both sides when attached, before the fridge slide. I can also remove the slide easily to create a flat surface since it is not screwed into the wood but bolted using t-nuts leaving the area below the platform flush for our storage bins. The unit is completely modular so I can use either side of the 3rd Row when I want. The two sides get bolted together into a one life unit when I want the full storage in the back.
Removable fridge slide with 3rd row-e1faf1cb-5f4c-46c0-b0ad-0dd64a63f91c-jpg  Removable fridge slide with 3rd row-f60eb55b-1aac-4299-8ec0-d7e303f2e0e4-jpg  Removable fridge slide with 3rd row-3c584a64-6fcd-43bf-986c-6dbf192e8ea4-jpeg  Removable fridge slide with 3rd row-f5ba47c4-45fe-4d83-9465-3d52d592258e-jpeg  Removable fridge slide with 3rd row-1fd76973-e20a-4b6a-bcb7-f0c08f8c50f8-jpeg  Removable fridge slide with 3rd row-06d45f60-5dfd-4bd8-8c4c-18bce92a75c2-jpeg  Removable fridge slide with 3rd row-f4441efa-bf64-4bc6-86ff-9f8c361eefbc-jpeg  Removable fridge slide with 3rd row-86f0b888-764c-49c1-a672-8f23affc8f21-jpeg
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
Cymon is offline   Reply With QuoteReply With Quote
Old 02-11-2019, 09:35 PM #8
Awesome! Thanks guys.
Old 02-11-2019, 10:00 PM #9
Cymon's Avatar
Real Name: Chris
Cymon's Avatar
Real Name: Chris
ARB Breather Mod
Old 02-11-2019, 10:23 PM #10
Originally Posted by Cymon View Post
How'd you power that fridge? It looks like its plugged into something in one of those pictures. Tried attaching picture but didnt work from phone.
Thanks!
Old 02-11-2019, 11:53 PM #11
Cymon's Avatar
Real Name: Chris
Cymon's Avatar
Real Name: Chris
Thanks!
In the picture you see it plugged into a Goal Zero Yeti 400 Lithium, which in turn is plugged into the rear 120v outlet so it can charge when the car is running. The battery would run the fridge for about 16-22 hours depending on ambient temperature without charging. Since then I got a killer deal on an open box Goal Zero Lithium 1400 solar generator. In the current setup the 1400 gets strapped down next to the fridge (too big for the old spot). The fridge is plugged into the generator and generator into the 120v outlet to charge while driving. Theoretically it will run the fridge for 3-5 days on a full charge. I also have a 100w solar panel in my trailer if we need charging off of the grid for extended periods. On our next trip I made attachment teathers using my kids car seat anchors that they don’t need anymore since they aren’t rear facing to the drivers seat anchor points. I’ll strap the generator down under my kids dangling feet using 1000lb straps. An extension chord will run from the rear outlet to the generator allowing it to charge while driving, and the fridge chord is long enough to run under/to the side of the second row drivers side seat and still allow for the fridge slide to completely slide out.
Essentially instead of a dual battery setup I use solar charging batteries because they are portable and interchangeable between vehicles. I can also use them for emergency power during hurricane season down here in South Florida.
ARB Breather Mod
Old 02-12-2019, 05:53 AM #12
@Cymon that's an awesome setup and very similar to what my goal setup would be overall. Where the heck dod you find an open box yeti 1400?
How long did it take to charge the 400? The 1400?
Old 02-12-2019, 10:45 AM #13
Cymon's Avatar
Real Name: Chris
Cymon's Avatar
Real Name: Chris
It was at an REI garage sale as a returned item as the backlight button was not working properly. I bought it for $500 (very lucky).
The Yeti 400 takes roughly 6-8 hours to fully charge by the plug in the back of the 4runner (about the same time as from a standard wall socket). The fridge pulls about 60-70 watts when the compressor is running, but only 5-7 when not. The vehicle inputs a pretty constant 60-70 watts to the battery when it is plugged in, so it is a net zero loss when the compressor is running and then charges back up whenever the compressor is not running. When stationary in good sun the 100w Boulder solar suitcase I have pulls in about 50-70 watts, so again it matches the fridge with the compressor running and then charges the battery when the fridge is not.
The 1400 would take about 25 hours to charge fully, with the same inputs and output of energy as stated above. But it does have the storage capacity to run the fridge for about 4-6 days depending on the ambient temperature, as the fridge takes an average of about 2-3amps and its a 396 amp/hr lithium battery.
Hope this helps.
ARB Breather Mod
Old 02-12-2019, 12:29 PM #14
Hope this helps.
Wow. That is lucky. Great find. That is really helpful info. Thanks
Old 05-24-2019, 04:40 PM #15
Does anyone have any pictures of a plywood type base they have built for the rear and how they bolted it down? I do have the third row, but would be open to seeing anything that someone has put together.
I really like @Cymon 's setup, but I think I am going to try to build mine flat and not with any space below. I have a custom molle surround so I can put stuff on top of the fridge and on the sides. I may copy what cymon did but flat, but I also want to see if I can get it closer to the side to free up some space, otherwise it goes almost to the middle of the back.
Post up pictures or let me know what you did. Thanks!
fridge , mount , people , removable , row
To slide or not? Fridge help please SwayzeExpress 5th gen T4Rs 22 11-21-2021 03:49 PM
Fridge Slides / Tilt Fridge Slide - Any Interest? kags1969 Group Buys 5 04-24-2017 08:00 PM
ARB Extended Fridge Slide JSparky 5th gen T4Rs 0 03-10-2017 11:54 PM
Removable slide out tray? Lewis&Clark 5th gen T4Rs 7 05-01-2012 03:48 PM
