Old 02-09-2019, 06:05 PM #1
kevinb_NJ's Avatar
kevinb_NJ kevinb_NJ is offline
kevinb_NJ is on a distinguished road
kevinb_NJ's Avatar
Stupid me, strippped sway bar bolt
I love admitting fault! While installing my lift spacers we disconnected the sway bar completely. I swear I started all of the bolts by hand and then used an impact gun only to zip them up before torquing correctly. However, I got distracted on one and let the gun go “too far”. Are these captive nuts that the lower mounts are attached to?
Am I screwed here?
For some reason the phone isn’t uploading pictures.
2015 Barcelona Red Limited
Bilstein 5100 lift with OME springs
Spidertrax spacers
Shrockworks skids
General Grabber 285 70 17's
kevinb_NJ is offline   Reply With QuoteReply With Quote
Old 02-10-2019, 11:02 AM #2
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
Impact wrench is not your friend. Unless you are up to replacing entire assembly you need to drill and tap for larger bolt. Cheaper and less desirable option is Helicoil (not strong enough for suspension parts) but you can give it a go and can tap later if Heli fails. GL
<<<< is offline   Reply With QuoteReply With Quote
Old 02-10-2019, 11:22 AM #3
DEERUNNER's Avatar
DEERUNNER DEERUNNER is offline
DEERUNNER is on a distinguished road
DEERUNNER's Avatar
Look into purchasing a Rivet nut tool, Nutsert tool, or Rivnut tool, etc. Many price points and kits available. Works perfectly and is strong enough for most purposes.
Nearly bone-stock 2015 TRDP<paid under sticker!, TRD Supercharger, Helo 904 17x9 rims, 285/70-17 BFG KO2, BMC, MetalTech OPOR Sliders w/extension, Hella Aux Fogs, Ultragauge, Rockford Fosgate Speakers, FJC Sub Woof Box, Kicker Woof, Cheapo Boss Woof Amp, Aux Glovebox Outlet, etsy TRD hub covers, Shaved/trimmed Mud Flaps and Fenders, Cobra WX75 CB, Rear Storage Drawers, Shovel Mount, Radar, FZ-1 Fuzeblock, AVS LP Visors, Window Tint, Painted Roof Rack, Low Profile SiriusXM Antenna, Dash Cam, Exhaust Tip, Accessory Meter Mod, Some Stickers. 2008 FJ Cruiser, FJNE Member DMAND.
DEERUNNER is offline   Reply With QuoteReply With Quote
Old 02-14-2019, 03:26 PM #4
kevinb_NJ's Avatar
kevinb_NJ's Avatar
Yep, I agree and usually very careful using the gun. Just got lazy and chatting with a buddy. Thanks, I'll have to cut the old one off and then assess what to do next.
Spidertrax spacers
Shrockworks skids
Old 02-14-2019, 03:27 PM #5
kevinb_NJ's Avatar
kevinb_NJ's Avatar
Good idea! Thanks
Spidertrax spacers
Shrockworks skids
Old 02-14-2019, 04:48 PM #6
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
I've already learned my lesson with using an impact to tighten or spin on fasteners...
That lesson also included learning how to change out wheel studs.
Old 02-14-2019, 04:49 PM #7
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
so the bolt snapped off use a reverse drill bit make sure the drill is in reverse ,, the drill will cut into the broken stud and then should unscrew.
not rusted so should come out with no problems ..
I have done this method on exhaust manifold rusted off bolts a bit harder to do when its rusted ..
I loosen studs then if a lot of bolts/nuts I use gun to remove..
I never use air guns to install because of a too much torque..I prefer the electric guns and I set to a lower torque spec which is much more accurate than an air gun..
catrains is offline   Reply With QuoteReply With Quote
Old 04-24-2019, 01:39 PM #8
Prolex7's Avatar
Prolex7 Prolex7 is offline
Prolex7 is on a distinguished road
Prolex7's Avatar
Am I screwed here?
I just encountered the same situation. I stripped the threads. Were you able to resolve without replacing the part itself?
2011 4Runner Trail - Bilstein 5100s set @1.25" front and Cornfed 1" rear spring spacer, Magnaflow 12586 muffler, TRD Intake, Yakima Loadwarrior w/ Extension, Spidertrax 1.25" Spacers
40-60mph run-up http://youtu.be/wWkRZx6Q-l4
Cruisin' for the weekends!
Prolex7 is offline   Reply With QuoteReply With Quote
Old 04-24-2019, 02:33 PM #9
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Which is stripped, the nut or the bolt? You might be able to just re-tap the nut for a larger bolt, or just replace the bolt if that is whats damaged.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 04-24-2019, 03:06 PM #10
Prolex7's Avatar
Prolex7's Avatar
It's the nut that's welded onto the LCA. Retapping didn't work. I got new bolts from Toyota yesterday to confirm and yeah it's definitely stripped threads on the bolt. It never fully tightens. I re-tapped using same size bolt threads and was too weak to hold a new bolt tightly.
Worst case I think the whole LCA is about $160 but the labor to install idk. Seeing what other options are out there before I go that route for a safe vehicle.
Old 04-24-2019, 03:31 PM #11
Jivewalker's Avatar
Jivewalker's Avatar
If it were me, I would retap for a size or 2 larger bolt and get a larger bolt of the same grade. Nothing to lose before going with the $140 LCA expense. Just a suggestion but may work for you.
I am fragile.
Not like a flower.
But like a bomb.
Old 04-24-2019, 03:41 PM #12
Prolex7's Avatar
Prolex7's Avatar
Thank you very much I appreciate the suggestion! I am going to have to try that.
Old 04-24-2019, 04:58 PM #13
57buick's Avatar
57buick 57buick is offline
57buick is just really nice 57buick is just really nice 57buick is just really nice 57buick is just really nice
57buick's Avatar
Im confused which bolt we are talking about? The sway bar? you mean where it mounts to the rear end? Or are you talking about the panhard bar?
2018 TRD Premium, KING suspension, 285/70/17 Duratracs, 4.88 gears, Addicted offroad front Bumper, C4 FAB rear bumper, My build thread https://www.toyota-4runner.org/5th-g...ld-thread.html
57buick is offline   Reply With QuoteReply With Quote
Old 04-24-2019, 07:50 PM #14
4runnerlaw's Avatar
4runnerlaw 4runnerlaw is offline
4runnerlaw is on a distinguished road
4runnerlaw's Avatar
Sway bar end bolts are 12mm - you could even put a 10mm bolt through the hole with enough room behind for a nut.
4runnerlaw is offline   Reply With QuoteReply With Quote
Old 10-08-2022, 06:07 PM #15
KC-4Runner KC-4Runner is offline
KC-4Runner is on a distinguished road
Am I screwed here?
I decided to Tap mine. Those dumbazz tack welds are weak on that thread or nut they put up there in the frame. If the tack weld breaks or something gets stripped, just go ahead and cut the bolt out. I tried many other methods that usually work but none of them did work and I ended up having to cut the bolt anyhow.
Most tap sets do not have taps over 12mm or 1/2" in size and these are too small anyhow for that hole. I went with a 5/8" tap, you will have to buy the tap and match it with a bolt with the right tpi. You will also have to use a 1/2" drill to enlarge the hole in the frame so you can tap the new threads. I used a bolt I found at Lowes but if you ain't in a hurry get a cap head and a washer, or even a button head bolt. Get a 5/8" tap with the finest tpi you can find - you will have to go to a real industrial/machine supply vendor for the tap.
I used a Dremel tool to cut the spinning bolt off and, to enlarge the hole on the bushing bracket for the new 5/8" diameter. Tapping the new threads laying on your back aint fun but it wont take long.
It's a real fastener and wont enlarge the hole beyond what I did. A square carriage bolt will probably work fine but if it does slip or see a good amount of force it is going to start to chew away at the frame and then, tapping may no longer be an oiption.
KC-4Runner is offline   Reply With QuoteReply With Quote
bar , far” , gun , sway , “too
Sway Bar Bracket Bolt Denis_Ruso 3rd gen T4Rs 8 08-25-2016 02:32 PM
HELP Sway bar end link bolt frozen and stripped buckeye4runner08 4th Gen T4Rs 8 07-11-2016 01:29 AM
Rear sway bar bolt stripped..... Ahhhhh xcmountain80 3rd gen T4Rs 14 08-28-2013 09:17 AM
Rear Sway Bar mount bolt sheared off worldcoast 3rd gen T4Rs 4 03-16-2013 08:17 PM
Broke a stupid lug bolt!!! 4Sport Maintenance/Detailing 11 08-22-2011 02:15 PM
