Originally Posted by mrblah
so conclusion is:
1. better than drop in LED lights
2. Worse than drop in HID lights
3. better than your oem halogen lights
4. high beams worse than drop in LED's
5. better cut off than LED and HID drop in lights
6. less power consumption than halogen and HID's
7. has updated LED DRL and blinkers
Whether or not its worth the price, is up to the end user.
I personally like the look, but I"m not sure I like it enough to spend 1200 on it either.
Luckily, since its not available yet, i have plenty of time to decide.
This is pretty much the review I have after 5K miles with these.
Coming from stock headlights these will be a big improvement. The cut off and the updated look is also a huge plus. Looks are subjective. I like them a lot and I can also see why someone would not like them. What wins me over is the quality of this style headlight. We have all seen the cheap aftermarket headlights and these do not look like those. Morimoto has done a great job making a quality part.
If you are like me, coming from a drop in HID kit, you will notice these are not as bright. The light is better controlled than a drop in HID kit. HID kits really spread the light out and can result in people flashing you with their high beams if not properly aimed.
I had a 4800k HID kit because that range is more of the OEM style. I'm not a fan of the blue(er) lights like 6000k, which these close resemble.
I am not sure if I agree with "worse than drop in LED kit" since the low beams have 4 individual LEDs (not sure what the rating or details are on these but you get what I mean). Also, I am sure the light pattern is much better than the glare drop in LEDs cause.
At the end of the day you have to decide what you are looking for. Do you want the brightest light output possible at the most competitive price? I'd recommend the Xenon Depot 4800K HID drop ins.
If you are looking for a more modern design with better light output and control over the OEM setup as well as quality, then get these!
If you are going for just looks and quality, well these headlights are for you.
Here are some night shots...
Low Beams with my amber fogs
High Beams no fogs
2017 4Runner TRD OR - Progress Thread
295/70/17 BFG KM3, SCS F5 17x9 -38, Front 5100 Rear MT Icon, Dobinson 314 & 701V, Gobi Stealth, RSG Sliders, ECGS 4.56's, Demello Front bumper, Coastal Off Road Rear Bumper
IG: dot_tom
