Old 08-09-2020, 03:57 PM #826
ForRun's Avatar
ForRun ForRun is offline
ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all
ForRun's Avatar
Originally Posted by kelkins View Post
Well my second headlight has failed. Same problem as last time, the corner led failed. Additionally, the lens has turned yellow in five months. They are now requiring a 380 dollar refundable deposit to replace the defective units. This was not required last time. Ultimately seems anti consumer since it potentially prevents people from getting a replacement. They have the option of you sending the defective unit back first, but who wants to drive around for weeks without a headlight?
I’ve had my headlights about 10 months, and have had a failure every 5 months. I’m not enthused.
I would ask for a set of the 2nd gen at no charge. They knew these are screwed up... why else would they re-design, re-tool and make a new one
ForRun is offline   Reply With QuoteReply With Quote
Old 08-09-2020, 06:54 PM #827
kelkins kelkins is offline
kelkins will become famous soon enough
I wish. The crazy thing is that my warranty claim was for yellowing. After my claim was accepted, the LED burned out while driving home.
kelkins is offline   Reply With QuoteReply With Quote
Old 11-14-2020, 10:39 PM #828
VB.TRD.Pro's Avatar
VB.TRD.Pro VB.TRD.Pro is offline
VB.TRD.Pro will become famous soon enough VB.TRD.Pro will become famous soon enough
VB.TRD.Pro's Avatar
So after almost a year of usage, the issue where the LED in the corners of each DRL either flickers or goes out completely started occurring on my set of headlights so it was time to submit a warranty claim.
I worked with the original vendor (HID Kit Pros) to start the process of replacing the set under warranty. Once I was transferred over to Morimoto, it took 3 business days to receive the advanced replacement set. I opted to pay a core deposit for the advanced replacement as I didn't want to send in the defective set first, reinstall the stock units, then repeat the process when the new lights arrived. The core deposit was reasonable and I did receive a Gen2/V2 set of headlights as the replacements which is consolation for the time spent.
Contrary to the bad experiences some have reported in dealing with warranty or RMA, my warranty replacement was as smooth as could be. Morimoto was super responsive and I think the process took a total of 5 calendar days from start to finish with two of those days being the weekend.
My impressions -- The Gen2 headlights are what the V1s should have been. Although the V1 headlights were better than the stock units, they weren't perfect. The Gen2 no longer projects a spotlight-ish beam pattern and the dark spots at the corners are gone. I could go on about how much they've improved but the pictures may do all that. The lateral illumination is much better.
Overall I am quite happy with the replacement lights. I just hope this isn't an annual drill. At least there are 4 years left of warranty if anything goes wrong.
Old lights on top... Gen2s on the bottom
2014+ T4R Tri-LED Projector / Sequential Headlights-morimoto-v1-001-jpg  2014+ T4R Tri-LED Projector / Sequential Headlights-morimoto-v2-001-jpg
2021 Lexus GX460 Premium Plus + Sport Design Pkg
2019 VooDoo Blue 4Runner TRD Pro
2016 Nissan GT-R Black Edition
VB.TRD.Pro is offline   Reply With QuoteReply With Quote
Old 11-15-2020, 11:16 PM #829
I’ll request gen 2 replacements next time mine bites the dust. It’s a matter of time at this point. The corner LED must have an issue with the heat sink. I’ll point them to your post if they give me any problems about the upgrade.
Old 11-16-2020, 01:35 AM #830
VB.TRD.Pro's Avatar
VB.TRD.Pro's Avatar
You're probably right -- those Gen1 units will fail again at some point. I do hope the support issues that some folks experienced earlier this year was a blip due to the unexpected events early on with the pandemic along with the Morimoto merger/acquisition.
I can't believe how quick they were to process the warranty claim and would encourage folks to start monitoring their DRL strips if they haven't noticed the failed LEDs. Thought mine were good to go but wasn't the case as it was very intermittent and sometimes one, both, or neither LED was out. I was finally able to catch one or both out in pictures to ensure there was proof of the defect. At this point Morimoto should be aware of how widespread this issue is and shouldn't be resistant to swap out the lights via warranty. At least I hope not.
The positive that resulted from taking my time to submit a claim was the gen2 replacements. Had I submitted the warranty claim earlier, the replacements might have been the gen1s again. I am glad we do have a 5-yr warranty compared to some of the competitor products.
2014+ , bit , dough , drop , estimated , mid-summer , pricey , set , start , theretrofitsource
Hid's or Projector Headlights Johnnyek9 5th gen T4Rs 164 03-29-2017 07:21 PM
Projector Headlights for 2nd Gen Gtrain Classic T4Rs 11 09-22-2015 11:36 AM
Projector Headlights karmaic1 4th Gen T4Rs 10 06-14-2011 01:33 PM
Projector headlights in 96-98. Non available? ramminyota 3rd gen T4Rs 1 03-19-2010 06:01 PM
Anyone have these projector headlights or crystal clear headlights?? afdj006 3rd gen T4Rs 12 10-30-2007 12:16 AM
