Old 07-06-2019, 04:07 AM #1
Punjabi408 Punjabi408 is offline
Punjabi408 is on a distinguished road
Dual Battery Setup or Portable Battery
I just got a fridge for my 4runner and am thinking about either a dual battery setup or just get a battery pack for the rear for now. I did some research and still cannot decide.
1. Battery pack (easy will work for the fridge but not long term)
2. Was thinking about a Blue Sea ACR
a. Good value, but I have read that both batteries need to be the same type. I am trying to keep the stock battery for now.
b. I can self-jump start if I ever need to
c. I read that our alternators are not grate at maintaining batteries, so would eventually have to replace that.
3. The CTEK d250S with a permanent battery tender mounted and maybe in the future smart pass and solar.
a. More expensive but I can use my stock battery.
b. Cannot self-jump
c. Can add solar and smartpass later
I am looking for a system that I can slowly upgrade tell It finally meets my needs.
Punjabi408 is offline   Reply With QuoteReply With Quote
Old 07-06-2019, 04:39 AM #2
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
pros and cons of different setups:
I've done all 3 setups, with currently a ctek under the hood, and I still have my old battery box. I prefer the battery box setup.
dual battery setup in engine bay:
1. puts everything under the hood
2. might have to move things around
3. not a temporary setup. You are stuck with camping around your car.
4. expensive
5. heavy, might make your suspension unhappy.
6. questionable installation if you aren't doing it yourself, or quite possibly questionable installation if doing it yourself..lol.
Dual battery setup but house battery in battery box:
1. cheaper
2. modular
3. takes up space in cargo area
4. can be removed from vehicle to power everything you ever wanted at a campsite, power outage, whatever.
single battery w/ jump pack
1. cheapest
2. still need an AGM for crank battery
3. you will drain your battery by accident at least once.
4. require a jump pack in case you do a number 3.
Old 07-07-2019, 12:37 AM #3
I definitely don't want to stick with a single battery and jump pack. I already have a jump pack at least in case my battery goes back. How do you keep your battery box charged? Do you think that your setup of a ctek under the hood and a battery box would be the best combination. For under the hood i was thinking shrockworks battery tray with the air pump relocation kit and a custom mount for ctek.
Old 07-07-2019, 01:01 AM #4
KWSRStorm's Avatar
KWSRStorm KWSRStorm is offline
KWSRStorm has a spectacular aura about KWSRStorm has a spectacular aura about
KWSRStorm's Avatar
I have a dual batt setup with stock batt and an optima with an acr. Biggest issue is the optima likes a higher voltage to charge. On a day to day i have no issue but once a month i charge the optima overnight with the small optima charger to maintain its overall lifespan but i dont think you NEED to do it. I think the oddessy batts are a little more needy than the optima in terms of maintaining.
Once my stock batt dies ill move the optima to the stock location and add a new optima in the aux spot.
I like that i have everything in the engine bay. 1 less thing to remember. Plus i get daily benefits like disconnecting the aux batt to charge tools, phones, and run lights and not worry about killing main batt.
Sent from my SM-G973U using Tapatalk
KWSRStorm is offline   Reply With QuoteReply With Quote
Old 07-07-2019, 01:38 AM #5
Daohaus's Avatar
Daohaus Daohaus is offline
Real Name: Duan
Daohaus is on a distinguished road
Daohaus's Avatar
Real Name: Duan
I like the idea of those goal zero portable battery with all the outlets etc built-in you can connect to it to charge would that be sufficient for your fridge?
2018 TRD Off Road Premium
Rotiform SIX-OR | Toyo Open Country RT 285/70/17 | Bilstein 6612/5160 OME 2895 | Rhino Rack | Valentine One | Rexing Dashcam
IG: @daohaus
Daohaus is offline   Reply With QuoteReply With Quote
Old 07-07-2019, 02:50 AM #6
JSparky's Avatar
JSparky JSparky is offline
JSparky is a jewel in the rough JSparky is a jewel in the rough JSparky is a jewel in the rough
JSparky's Avatar
I see 408 in your screen name, are you in the Bay Area?
67' Land Rover 109, 97' FZJ80, 16' 4Runner Limited
http://www.toyota-4runner.org/5th-ge...-jr-build.html
http://www.overlandcookery.com
http://www.schaubphoto.com
JSparky is offline   Reply With QuoteReply With Quote
Old 07-07-2019, 04:16 AM #7
mrblah's Avatar
mrblah's Avatar
battery box just plugs into the cigarette lighter.
current dual setup is:
ctek w/ a modified bracket for a ARB compressor
shrockworks battery tray and pump relocation kit.
I don't know man. My battery box was way more useful for me, but having a dual battery setup is nicer because it frees up space in the back. Running a battery box, a drawer system, and fridge took up a large amount of usable space.
If i didn't have that stupid drawer system I have back in my cargo bay right now, I'd probably would have stuck to a battery box or a goal zero.
Old 07-07-2019, 08:20 PM #8
Mack1611 Mack1611 is offline
Mack1611 is on a distinguished road
I'm thinking about doing the 2nd battery isolated by a solenoid. I do like the Redarc's DC to DC battery chargers, but I want to do this on the cheap...
DC to DC Battery Chargers - Dual Battery Setups | REDARC Electronics
Dual Battery Systems - Toyota 4Runner Forum - Largest 4Runner Forum
Dual Batteries on the Cheap - Toyota 4Runner Forum - Largest 4Runner Forum
Mack1611 is offline   Reply With QuoteReply With Quote
Old 07-09-2019, 01:10 AM #9
I am located in San Jose and Stockton, go back and forth. I also did look at the yeti 400 goal zero. People have said that the AGM model will run a fridge 12-24 hrs depending on settings. If I buy a goal zero it would be the 400 in lithium ion to keep it portable.
Old 07-09-2019, 01:11 AM #10
If your looking for a good price DC to DC battery charger I have heard good things about Renogy 20A DC to DC Battery Charger https://www.amazon.com/Renogy-Batter...SIN=B07Q5VYPCF
Old 07-09-2019, 04:04 AM #11
JSparky's Avatar
JSparky's Avatar
I’d recommend giving Kodiak a call, they can explain options in detail and provide excellent install services.
KODIAK INDUSTRIES INC.
Old 07-09-2019, 09:28 AM #12
Roverguy1's Avatar
Roverguy1 Roverguy1 is offline
Roverguy1 will become famous soon enough
Roverguy1's Avatar
Quite happy with the c-tek D250SA I've installed. Bought a C4Fab battery tray (minimal wires to be moved) and mounted the C-tek on top of the fuse box. Easy run to under dash fuse box for smart alt wire. Biggest PITA was getting the wires from the rear pass door through the cargo area in the back without pulling all the trim off but it's done and a Blue Sea fuse box and 12v plug/2 usb/battery meter unit are mounted in the rear pass cargo corner and the ARB fridge is working great. The C-tek has an MPPT controller so when in camp, I plug in my 50w Renology panel.
Roverguy1 is offline   Reply With QuoteReply With Quote
Old 07-10-2019, 01:49 AM #13
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
There's a known issue with the Lithium version of the Goal Zero units. From what I understand they 12V output on them are unregulated. So you won't/can't run a 12V fridge off the cigarette lighter without a work around. You need to run two adapters that GZ sells, an anderson plug and a 12v regulated converter. This is with all their lithium units, from 400W to the 3000W units. I have the GZ 400W Lithium and tried my Dometic 35L on it and true enough it didn't work via 12vdc. I never went around to get the adapters because I run a dual battery system but just wanted to test it out.
Yeti Lithium 12V Regulated Cable Yeti Lithium 12V Regulated Cable / Goal Zero
As well from what I understand the GZ 400W Lithium unit, I'm not sure about their other ones, is NOT LiFePO4 if that matters. I've seen some user reports of the GZ 400W Lithium and it seems to power a fridge for around 12-24 hours. Not the best IMO. I assume they probably just run a bunch of 18650 cells in a daisy chain.
A more expensive and better option is the Dometic PLB40. It uses LiFePO4 cells, is regulated, just as small as the GZ400W, has anderson plugs whereas the GZ400W doesn't, and from what I've seen can run a fridge 48-72 hours. The unit was specifically built to run their brand of fridges with the ability to charge electronics as a bonus. I think GZ adopted the opposite purpose, they built their units to charge electronics and people then tried to adapt it to run fridges since they already had them. I've even seen someone trickle charge their house battery off the Dometic after they ran the power down and it gave it enough charge to start after a few hours.
Dometic PLB40 : 40Ah Lithium Iron Phosphate Battery
To this date I've found very little use for my GZ 400W Lithium since I already run a dual battery system. It's a nice unit for charging other electronics but if your intention is to run a fridge for a few days I'd look at other options, namely the Dometic PLB40. Too many limitations and work arounds with the Goal Zero units.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
Old 07-23-2019, 02:11 AM #14
Duel Battery
So I decided I am going to do a duel battery system. I am going with the Ctek d250s with shrockworks duel battery setup. Now just got to finish making parts list and ordering the remaining pieces.
Old 07-23-2019, 10:41 AM #15
666HailSanta 666HailSanta is offline
666HailSanta is on a distinguished road
It depends on your application and environment - do you go out for single nights or weekends? Are you spending weeks out?
I live in Central TX which means my fridge is running 30-40% of the the time when we're in the summer months (aka 7 months of the year here). It draws roughly 2-3AH at that rate unfortunately. My wife and I also take longer trips out of state with some frequency, most lasting a week+.
Running a battery box or something like a Goal Zero wouldn't make sense for us because of the length of time we're out and our draw. Portability doesn't really matter to me because we're sleeping in a RTT and I wouldn't want to lug a heavy battery around to charge my phone away from the truck or something funky.
I'm running 2 AGM batteries - a 50AH Yellowtop and a 75AH X2 with a smart solenoid. It's charging from the stock alternator but I have put a voltage booster in to keep the batteries happy and charging between 14.1-14.6V. I've also got 100W of solar if we're camped out for extended periods of time to avoid cranking the truck.
Honestly, it's worked out perfect for us - just did two weeks around SW Colorado and had 0 electrical concerns.
666HailSanta is offline   Reply With QuoteReply With Quote
batteries , battery , read , self-jump , stock
Dual Battery Vs. Portable Battery nick_rabbo 4th Gen T4Rs 29 05-23-2022 12:39 PM
Another Dual Battery Setup Airgazm 5th gen T4Rs 26 12-10-2018 03:28 PM
Anyone look at these portable box dual battery setups?? stephan07 5th gen T4Rs 10 01-29-2018 07:39 PM
Portable second battery setup? Swarty 5th gen T4Rs 11 07-23-2016 02:04 PM
A different dual battery setup diddley.bo 5th gen T4Rs 5 07-18-2016 02:19 PM
