08-12-2019, 11:01 PM
#391
Real Name: I didn't go to Monkey Medical School for 8 years to be called Mr. Monkeypants
2014+ T4R Tri-LED Projector / Sequential Headlights
Came home today to this beast of a box waiting for me:
The headlights were individually boxed inside with four foam bags on each. Definitely well secured.
The install was pretty much a piece of cake. The fit on everything was reasonably accurate with the exception of a single arm that was bent, likely from packaging:
Everything else fit well enough so I flexed it down and screwed it into place without much effort and just went with it. Gotta say these are really nicely made, well finished, and overall pretty great from a manufacturing quality standpoint.
I have the USR full LED blackout taillights in my truck and have intermittent hyper-flash with the turn signals in the headlights. I don’t have the sequential signals active on mine. Hazards seem to work fine. Turn signals work fine with the headlights on (edit: mostly, lol). But with just the DRLs, the left signal hyper-flashes every eighth or so blink and the right does it about every fourth. Interestingly, once they’re warmed up they tend to do it less... Likely not a terribly difficult fix with a resistor or LED flash module. If anyone knows of a module cross compatible with ours (Toyota part # 81980-60160) I’d be stoked to check it out. A quick Google-Fu found nothing.
So, I haven’t been able to check the actual performance yet, but goddddamn they look fcuking spectacular on my MGM Nightshade:
And I definitely dig the look of the DRLs:
Anyway, some of the other initial light assessments have me a little worried, but I’ll hold judgment till tonight and update this with my impressions coming from Morimoto 2-Stroke 2.0 lows and stock highs...
EDIT #1: First drive impressions:
I didn't adjust mine before going for a drive and they seemed a bit low, even with a 2.5" front lift. Not a big deal though. Low beam forward light quality and brightness is good. Nice even light and a crispy cutoff. Definitely on par with the 2-Stroke bulbs. High beams are plenty bright enough. Much better than stock. I have a light bar if I need crazy total light.
All of that said, I don't think I can keep these lights (which seriously bums me out). The side cutoff really is really bad like others have said. I had to slow way, way down making turns (even on streets I know well) because I couldn't see into the corner AT ALL. It's no joke. I didn't believe it could be as bad as people were saying, but it is. Honestly, I don't know how this could have passed ANY on-road testing. One decent LED that's only on with the headlights located near the side marker would solve that. But for now, it's not something that's safe to drive in residential/suburban areas without streetlights. Between that and the hyper-flash, these really aren't production ready. I mean, it's 2019, you have to anticipate people who will be making this upgrade are likely going to also have put LEDs in their taillights.
EDIT #2: Like
@ mrblah
has already discovered, removing the DRL harness completely eliminates the hyperflash (and the DRLs, sadly). Updating that small "harness" should be an easy fix.
EDIT #3: Emailed with XD this morning. Got an RMA without hassle. Really wish they just worked properly and I didn't have to deal with this...
Edit #4: Despite planning to return them, my morbid curiosity got the better of me and I wanted to see if the hyperflash was really as easy to fix as I expected... I just ghetto’d out and jammed a 12v 6ohm resistor I had in the shop between the harness and the light and that fixed it completely. Checked both sides individually, hazards, w/DRL, w/parking lights, and w/headlights, and nothing fazed them. So, yeah. Turn back your LED clock to a decade ago before load balanced lights were a thing and there’s your answer. I don’t know if this is awesome or pathetic that it was this easy a fix and they didn’t solve it before shipping.
2019 Nightshade with a little custom stuff
Reason: RMA
08-13-2019, 05:10 AM
#392
I also wanted to add:
1. My lenses are marked DOT/SAE on them, which is a big deal to some people if you live in a state with mandatory inspections.
i edited my previous review to reflect that.
08-13-2019, 10:27 AM
#393
5th Gen Moderator
5th Gen Moderator
So someone, maybe
@ dot_tom
, should just rip these open and see if one of the low beam projectors, prob the middle one, can be turned outward at all.
Originally Posted by 7harper
First 5th with real CO's
2017 White TRD OR, Icons, BFG Mud-Terrains, Konig Countersteer, Retro Headlights, Gobi stuff
08-13-2019, 11:04 AM
#394
Mine are arriving today which I planned to install. I gotta say, I'm a bit sad to read about everyone planning to return them as it makes me want to just not even mess with installing them.
I'm in the heart of the city so I won't actually be able to do a good test of the side cut-off since the closest area without street lights is far our and it gets dark late here.
I was hoping for at least one person to say "I got them adjusted and they're good enough" but since I'm not seeing that, I may just return them. Super bummed as this is easily the best looking light on the market and looks gnarly on the MGM color.
Voodoo Blue 2020 Tacoma TRD Off Road
08-13-2019, 11:08 AM
#395
Originally Posted by Jesse1983
So someone, maybe
@ dot_tom
Xenon told me they are going to let Morimoto know and hopefully they fix it before production.
If that happens I'll buy another set!
08-13-2019, 01:21 PM
#396
Real Name: Chris
Real Name: Chris
Originally Posted by mrblah
My mini review:
1. packaging was awesome.
2. So the LED side cutoff is real, its a bit annoying, but if you run fogs all the time, it will more than make up for that annoying side cutoff.
3. HID bulbs in OEM housing will give better performance. Maybe just black out your oem housing if you want something a bit more visually striking, but at this moment, my old HID's work better.
4. I couldn't for the life of me get the DRL to work on its own. They give you a wiring harness that taps into the heated mirrors in your fuse box, but I couldn't get it to work without hyperblinkers. So in the end, I left it disconnected because I actually don't care for DRL. I want/like/need the blacked out look during the day. I also have my fogs set on a separate switch if i really want DRL's during the day.
5. Sequential blinking also resulted in hyperflashing. However, if I disconnected the sequential blinking function, and ran the blinkers normally, I didn't get hyperflash. On a side note, I am running LED's in the rear taillights which is probably the culprit. (see post below mine)
6. Install was pretty easy, and instructions can be found on the moromoto website.
7. (edited) My lenses had DOT/SAE stamped on them.
Conclusion: I like it, and plan on keeping them. I knew going into this that this wasn't going to be better than OEM+HID upgrade, but I just hate chrome........As long as the light output was better than OEM, I would have been happy. Fit and finish is very good. Luckily for me, I don't care for sequential blinking and DRL, but some of you might be disappointed that these functions won't work if you have LED's in your taillights. You can probably fix this with resistors though...(I hate working with resistors).
I plan on keeping my old oem housings just in case I get tired of crawlin dem mallz....
Thank you for sharing your honest opinion and review. As much as I wanted to jump on these, I was hesitant due to all of the mixed reviews on the Taco headlights, and having already bought a full MLED retrofit kit and spare set of headlights. I'm glad to hear honest opinions about the real issues with these, given how much they were hyped up.
08-13-2019, 01:47 PM
#397
So someone, maybe
@ dot_tom
It's hard to get a clear picture because the outer plastic is so reflective, but the individual projectors are deeply set in a single housing for all three, so there's really no way to get one of them adjusted to a point that would make any appreciable difference. I suggested adding a side illuminating LED near the marker lights. We'll see what they come up with...
08-13-2019, 05:52 PM
#398
So is anybody planning on keeping theirs? Are returns to XenonDepot a possibility?
I really don't want to yank my bumper off any more than I have to and I didn't realize you had to run a wire to the fuse box. I know none of this shit is difficult in any definition of the word, but going through the hassle only to have to do it again to pull them off seems annoying.
I personally don't mind running fog lights at all times, even though I know some people said they don't want to have to do that. So if the fog lights (especially if I upgrade to the TRD Pro LED ones) make up the gap, I may be okay with it, especially since I primarily drive in the city.
08-13-2019, 06:35 PM
#400
For those that plan on keeping their lights and have hyperflash issues, don’t fret. 2010 is calling and their old 12v 6ohm resistor trick works like a charm. I put one on each side of the DRL harness and it cured the hyperflash.
Edit: I cut the harness (guess I’m keeping them now, lol) and put a single resistor in before the split instead of the pair of resistors after the split and that also solves the hyperflash.
Pic of ghetto test bench:
And a picture of a non-hyperflashing LED turn signal:
Now, who has a solution to side illumination? My fogs are a bit TOO bright and too yellow for consistent use, lol:
08-13-2019, 06:44 PM
#401
Then let me be the first: If making turns in very poorly lit areas isn’t an issue, they’re great lights (now that I figured out the hyperflash fix).
08-13-2019, 06:50 PM
#402
Well **** it, I've got them so I guess I'll put them on and decide on my own how they handle. Because gahDANG they look good, especially going outside and seeing how glaring the chrome is on the OEM headlights on gray paint with everything else blacked out.
Once I get out to the boonies for camping, etc the story may change, but I suppose I can probably figure something else out whenever the need arises.
Planning to do the TRD Pro fogs regardless so maybe that'll make up for the side-light deficiencies.
08-13-2019, 06:58 PM
#403
Yeah. I get it. They’re that good looking. I think I’m going to keep mine now too and just turn my fogs on when I’m in the boonies and need the extra cornering light. #VanityWinsAgain
08-13-2019, 08:06 PM
#404
The New Morimoto XB LED Headlights are here!
Bring your own fog lights, lol
08-13-2019, 08:54 PM
#405
Sucks but whatever. Not any great competition out there for looks and function besides Kustom54 and I'm sure they've got their own issues (price and blatantly aftermarket-looking) or HID drop-ins which retain the same chrome look and have the higher potential for blinding oncoming traffic.
Maybe one of us guinea pigs will figure out a reasonable solution or maybe Morimoto will figure it out so future buyers don't have to worry about it.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
