Old 01-24-2020, 07:27 AM #751
Steel28 Steel28 is offline
Steel28 is on a distinguished road
Originally Posted by fr4c View Post
Sent an email out to my local authorized vendor that I purchased these from. One of the LED diodes for the DRL on my passenger side went out. Considering how time consuming it is installing these, I may just swap back my stocks for now. Only had them installed since November.
I’m about to purchase these lights. This is very concerning.
2017 Super White TRD Pro - SOLD
2020 Army Green TRD Pro
Steel28 is offline   Reply With QuoteReply With Quote
Old 01-24-2020, 08:29 AM #752
VB.TRD.Pro's Avatar
VB.TRD.Pro VB.TRD.Pro is offline
VB.TRD.Pro will become famous soon enough VB.TRD.Pro will become famous soon enough
VB.TRD.Pro's Avatar
Originally Posted by mordotz View Post
I’m glad to see that I wasn’t the only one that had to adjust it the max three turns straight out of the box. I was a bit annoyed by this because it doesn’t leave anymore room for adjustment in the future but figured I would only need to adjust it down if I ever leveled or lifted the truck. As far as I know, there shouldn’t be a case where I would have to raise it higher. I played it safe at 2.75 turns, did you set yours at the max 3?
I felt the same about needing to adjust it upward to the max three turns just to match the stock height that I had marked off on the garage wall. After a couple of days I adjusted it down slightly. It sits somewhere between 2.75 and 3 turns right now.
Originally Posted by mynameistory View Post
Please don't aim headlights based on the number of turns you count. Find some flat ground and a wall, and aim them properly using Toyota's method.
The number of turns to get back to stock height was pretty close to three turns as marked on the wall at the set distance of 25 ft prior to uninstalling the stock headlights. I wouldn't say the number of turns was the primary measurement mechanism used to aim but more of something noted in the back of our mind as counting the number of turns is needed since the instructions say not to exceed three.
My guess is the aiming mechanism consists of two sections, and going to extremes in either direction (not sure which) would allow the two sections to completely disengage from one another rendering the mechanism useless. Hope that Morimoto factored in some leeway before that actually happens but I'm not trying to find out how many turns is actually needed before that disengagement occurs.
2021 Lexus GX460 Premium Plus + Sport Design Pkg
2019 VooDoo Blue 4Runner TRD Pro
2016 Nissan GT-R Black Edition
VB.TRD.Pro is offline   Reply With QuoteReply With Quote
Old 01-24-2020, 09:16 AM #753
fr4c fr4c is offline
fr4c is on a distinguished road
I hope mine is a isolated case. The vendor who I purchased these from said they haven’t seen this in the 4Runner XBs as they’re very solid, but with anything mass produced you just never know.
Now waiting to hear back from Morimoto as I’ve been told they handle requests for XBs directly.
2019 Voodoo Blue TRD Pro
fr4c is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 06:38 PM #754
SlugInfinite SlugInfinite is offline
SlugInfinite is on a distinguished road
I hadn't looked closely at my wife's lights, both her passenger and driver's side have the LEDs out at the same place the LED is flickering in mine. That's 3 out of 4 headlights in our household - appears to be a clear manufacturer issue.
I'm assuming the one of mine that is flickering will die shortly too - we've had her lights in since November, mine since early January.
2014+ T4R Tri-LED Projector / Sequential Headlights-img_1445-jpg  2014+ T4R Tri-LED Projector / Sequential Headlights-img_1446-jpg
SlugInfinite is offline   Reply With QuoteReply With Quote
Old 02-05-2020, 09:36 AM #755
No news update:
The supplier for my wife’s lights has reached out to Morimoto 2x and hasn’t received a response from them. He said he has another customer that has the same LED location failure in his pair.
I’ve contacted Xenon Depot 3x now via email and phone attempt about my lights, and haven’t received any type of response back. Xenon Depot is garbage. I’m planning to dispute the charge with my CC company and ship the lights back to them after the charge is successfully reversed.
I had Kustom54 lights on a previous 4Runner, there were a few issues with those and Pavel took care of them within hours. I will be going back to him.
Old 02-05-2020, 10:20 AM #756
Originally Posted by SlugInfinite View Post
No news update:
Sorry to hear that. I have already sent mine back to Morimoto which they should be receiving today. They confirmed that they will be sending out a brand new set to me since these headlights can't really be serviced.
Old 02-05-2020, 10:23 AM #757
When did you purchase your lights from XD? Are these part of initial 50 units?
Mine are coming from the latest batch from Morimoto next week.
Old 02-05-2020, 11:31 AM #758
I did not purchase mine from XD, and they were not the initial early run of 50 units.
I purchased these when they were available to the public from Lightwerkz.
Old 02-05-2020, 12:18 PM #759
Thanks for the info. Did you deal directly with Morimoto or did you go through your distributor?
I’ve tried to connect with Morimoto too and haven’t received a response.
Neither my wife’s pair or my pair were part of the initial 50 unit run, both were “full production” units.
Old 02-05-2020, 12:23 PM #760
I contacted Morimoto directly, but didn’t get a response back from them until I had Lightwerkz ping them directly with my ticket #.
Old 02-05-2020, 12:34 PM #761
cb1111's Avatar
cb1111 cb1111 is offline
cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold
cb1111's Avatar
How many of you have reported this as a safety issue to NHTSA? Y'all might get a quicker response if the manufacturer of illegal lighting realizes that they are on the radar of the regulators and may be subject to really hefty fines.
When in trouble - obfuscate
cb1111 is offline   Reply With QuoteReply With Quote
Old 02-05-2020, 01:28 PM #762
mynameistory's Avatar
mynameistory mynameistory is offline
mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold
What about the lights is illegal?
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
mynameistory is offline   Reply With QuoteReply With Quote
Old 02-05-2020, 05:21 PM #763
cb1111's Avatar
cb1111's Avatar
The don't meet the requirements of FMVSS 108.
Old 02-06-2020, 04:12 AM #764
FMVSS 108 is 731 pages long. You care to drill down a little deeper in your assertion?
-Tory
Old 02-06-2020, 08:53 AM #765
XenonDepot XenonDepot is offline
Real Name: Caleb
XenonDepot will become famous soon enough XenonDepot will become famous soon enough
Real Name: Caleb
No news update:
Firstly, we recognize that it’s taken us much longer than it should have to respond to your email and we are so embarrassed. Making our customers wait a few weeks is unacceptable, and we are truly sorry.
We’ve been plowing through backlog from the holiday, a skeleton crew here at the office thanks to flu season, and hordes of enthusiasts flocking our way for information on lighting upgrades during the darkest time of the year. None of this should be your problem, but the truth is that we’ve had trouble keeping up. Among recruiting more people to join our team, We’re committed to making some changes for the future.
Can you PM me your order number from us and email address? We'll get this taken care of ASAP!
Sorry!
XenonDepot is offline   Reply With QuoteReply With Quote
2014+ , bit , dough , drop , estimated , mid-summer , pricey , set , start , theretrofitsource
Hid's or Projector Headlights Johnnyek9 5th gen T4Rs 164 03-29-2017 07:21 PM
Projector Headlights for 2nd Gen Gtrain Classic T4Rs 11 09-22-2015 11:36 AM
Projector Headlights karmaic1 4th Gen T4Rs 10 06-14-2011 01:33 PM
Projector headlights in 96-98. Non available? ramminyota 3rd gen T4Rs 1 03-19-2010 06:01 PM
Anyone have these projector headlights or crystal clear headlights?? afdj006 3rd gen T4Rs 12 10-30-2007 12:16 AM
