Old 02-18-2020, 01:40 PM #811
VB.TRD.Pro's Avatar
VB.TRD.Pro VB.TRD.Pro is offline
VB.TRD.Pro will become famous soon enough VB.TRD.Pro will become famous soon enough
VB.TRD.Pro's Avatar
Originally Posted by EddieV4runnin View Post
Kustom 54 FTW
2021 Lexus GX460 Premium Plus + Sport Design Pkg
2019 VooDoo Blue 4Runner TRD Pro
2016 Nissan GT-R Black Edition
VB.TRD.Pro is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 07:51 PM #812
4RNOMAD 4RNOMAD is offline
4RNOMAD is on a distinguished road
Originally Posted by MillerPKA View Post
For anyone who has an aftermarket steel bumper that has the straight line cut (like CBI), are you guys able to remove the headlight without removing the whole bumper? I'm hoping i can remove that upper bumper valence that remains and sneak a wrench in there.
I have a 3 hoop bumper and I was able to move the upper grill forward enough to remove the light housing with the bumper on.
4RNOMAD is offline   Reply With QuoteReply With Quote
Old 03-02-2020, 09:14 AM #813
kelkins kelkins is offline
kelkins will become famous soon enough
Originally Posted by SlugInfinite View Post
I hadn't looked closely at my wife's lights, both her passenger and driver's side have the LEDs out at the same place the LED is flickering in mine. That's 3 out of 4 headlights in our household - appears to be a clear manufacturer issue.
I'm assuming the one of mine that is flickering will die shortly too - we've had her lights in since November, mine since early January.
Just had the same LED go out in my drivers side headlight. Seems like this may be a design flaw, as several have had the same LED go out. I hope Xenon Depot will respond once I report it.
kelkins is offline   Reply With QuoteReply With Quote
Old 03-15-2020, 11:33 PM #814
Just finished up getting my new headlight installed. Overall the return/replacement process has been pretty painless from the customer service side of things. I wouldn’t want to rip another headlight out anytime soon though. Xenon Depot responded to my request the next day, and had a new headlight out to me within a week or so. Just have to drop my old headlight off at UPS now.
No deposit was needed on my end (like a core charge), and a label was provided for printing. All in all, this went much smoother than expected. The replacement headlight appeared to be new as well... although it could have been a renewed light. I saw no signs of previous use.
Old 03-16-2020, 10:22 AM #815
david05111 david05111 is offline
david05111 will become famous soon enough
Kustom 54 FTW
It’s crazy how much some of their stuff is. I was looking at a set of their taillights, because you can actually get them blacked out (the depos aren’t) but the damn things are near $1000. That’s insane
david05111 is offline   Reply With QuoteReply With Quote
Old 03-16-2020, 11:43 AM #816
EddieV4runnin's Avatar
EddieV4runnin EddieV4runnin is offline
EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough
I didn’t know they also sold taillights, I quite like the OEM assemblies. They are expensive but the difference in light output and where it puts that light is amazing. Mine have the 5.0 D2S projectors, which require some modification to the radiator support but it’s worth it. I’ve had them through rain, snow, and multiple drive through car washes and no signs of leaking yet.
Mods are loading.......
EddieV4runnin is offline   Reply With QuoteReply With Quote
Old 04-20-2020, 03:04 PM #817
krypto89 krypto89 is offline
krypto89 is on a distinguished road
finally had a chance to install these. before i go through the aiming process and putting the fender back on, has anyone tried or figured out how to have just the drl turn on without the amber side marker?
krypto89 is offline   Reply With QuoteReply With Quote
Old 04-20-2020, 03:28 PM #818
It should do just that when you have the stalk set to DRL. Did you use the included DRL harness? Otherwise, it won’t turn on until the “parking light” setting on the stalk is selected.
Old 04-20-2020, 06:35 PM #819
ForRun's Avatar
ForRun ForRun is offline
ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all
ForRun's Avatar
I think you need the rig powered on and in drive for the DLR to come on
ForRun is offline   Reply With QuoteReply With Quote
Old 04-20-2020, 10:33 PM #820
Thanks for the reply. I think I installed the DRL harness correctly into the fuse box. If not, the DRL would not function, right?
I have the stalk set at DRL on. When I start the engine, I would assume the DRL would be on, but it doesn't. It only goes on at the second click up, which activates the amber parking light as well.
Am I doing something wrong?
Old 04-21-2020, 11:45 AM #821
Is your parking brake on? Also the DRL harness is only needed for the super bright DRL stalk setting. The strip would operate with the parking lights even without the harness.... I think. It’s been a while since my install.
Old 04-24-2020, 11:46 PM #822
Yep, park brake was it. Thanks! Now to put everything back on and go through the aiming process.
Old 04-26-2020, 12:45 PM #823
SlugInfinite SlugInfinite is offline
SlugInfinite is on a distinguished road
Additional update from me on the XB headlights. I'm on my 2nd set in my wife's car and 2nd set in mine - so in total 4 pairs of headlights. The DRL diode in the upper left passenger side and upper right driver's side has failed in all 4 pairs of headlights.
The first 2 sets were replaced under warranty from XenonDepot/Morimoto - this process took nearly 2 months with multiple PMs here, phone calls, emails, etc before I finally got a response. I was promised this was a manufacturing issue on the 2 early sets, and that the issue had been addressed.
The diodes in the replacement sets have begun to fail progressively over the last 2.5 weeks - so clearly this is not a resolved issue.
At this point I would just request a full refund from XenonDepot and replace the headlights with Kustom54. However, since it took XenonDepot 2 months to respond to a warranty claim for replacement, I don't hold out a lot of hope for a refund. I'm also pretty tired of taking the front end of the vehicles apart and wasting 3+ hours of my weekends.
Overall, the headlights look nice, good concept - but there are significant and consistent issues with reliability and manufacturing QC. Coupled with terrible customer service from XenonDepot/Morimoto - these headlights are absolutely not worth the cost and headache.
SlugInfinite is offline   Reply With QuoteReply With Quote
Old 04-26-2020, 06:07 PM #824
mynameistory's Avatar
mynameistory mynameistory is offline
mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold
I'm glad I don't have any LED doohickeys from TRS/Xenon Depot anymore. Customer service was atrocious. Tons of calls, emails, etc every few weeks trying to get replacements for parts under warranty. I filled out a new request form on the website and referenced the original claim number. Finally got through to them and was told that any email responses I sent without receiving one first pushed my request to the bottom of the queue. Huh? So I'm just supposed to twiddle my thumbs for a month waiting for my request to float to the top, and any questions about status would bump it to the bottom? And they'd only answer phones for 2 hours a day. Bizarre.
Now I'm using H9 bulbs that are brighter and project further, and I can pick them up for $8 at the auto parts store. No more of this instagram lighting bullshit for me.
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
mynameistory is offline   Reply With QuoteReply With Quote
Old 08-09-2020, 12:29 PM #825
Well my second headlight has failed. Same problem as last time, the corner led failed. Additionally, the lens has turned yellow in five months. They are now requiring a 380 dollar refundable deposit to replace the defective units. This was not required last time. Ultimately seems anti consumer since it potentially prevents people from getting a replacement. They have the option of you sending the defective unit back first, but who wants to drive around for weeks without a headlight?
I’ve had my headlights about 10 months, and have had a failure every 5 months. I’m not enthused.
2014+ , bit , dough , drop , estimated , mid-summer , pricey , set , start , theretrofitsource
Hid's or Projector Headlights Johnnyek9 5th gen T4Rs 164 03-29-2017 07:21 PM
Projector Headlights for 2nd Gen Gtrain Classic T4Rs 11 09-22-2015 11:36 AM
Projector Headlights karmaic1 4th Gen T4Rs 10 06-14-2011 01:33 PM
Projector headlights in 96-98. Non available? ramminyota 3rd gen T4Rs 1 03-19-2010 06:01 PM
Anyone have these projector headlights or crystal clear headlights?? afdj006 3rd gen T4Rs 12 10-30-2007 12:16 AM
