Old 04-25-2019, 07:58 AM #46
N52228 N52228 is offline
N52228 is on a distinguished road
Mine seems to have a little bit of sag - just eyeballing it. I'm on stock Pro suspension w/RCI aluminum skids, Gobi, Shrockworks skids.
2018 TRD Pro Cavalry Blue
1995 Saab 9000 Aero
N52228 is offline   Reply With QuoteReply With Quote
Old 04-25-2019, 12:41 PM #47
DesertCanyons's Avatar
DesertCanyons DesertCanyons is offline
Real Name: Dave
DesertCanyons will become famous soon enough
Real Name: Dave
Originally Posted by MeefZah View Post
You cannot. While there is some debate about it, I think (and apparently SDHQ also thinks) that the OEM tie down loops are adequate.
That's probably true if you use a bridle and snatch block (pulley) to equalize the pull on both tie-down loops. I made a bridle and added a second tie-down loop to the rear for this purpose. The bolt threads for the loop are already on the frame. Check this out for how to make a bridle and photos of the second recovery point on the rear. Since this was posted I had the exhaust tailpipe turned sideways behind the rear tire.
How To Make A Bridle
How to add the 2nd recovery point is on page 8 of this thread on recovery gear. There's lots of feedback from other people about recovery gear in this thread.
Recovery Gear Options
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
DesertCanyons is offline   Reply With QuoteReply With Quote
Old 06-19-2019, 02:20 PM #48
MeefZah's Avatar
MeefZah MeefZah is offline
MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold
MeefZah's Avatar
I painted the hook black. Tucked up tight against the fairlead it is all pretty unobtrusive and about as close to stock as it can appear.
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You can’t grasp its vastness from a plane. It’s diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
Photos, mods & trip reports
MeefZah is offline   Reply With QuoteReply With Quote
Old 06-19-2019, 07:18 PM #49
Direwolf82 Direwolf82 is offline
Direwolf82 will become famous soon enough
I was just curious, how is the hawser style fairlead holding up to the wire rope?
I always thought roller fairleads with wire and hawser fairleads for synthetic?
Just curious if you have any wear issues or is that not an aluminum hawser?
Direwolf82 is offline   Reply With QuoteReply With Quote
Old 06-20-2019, 01:27 AM #50
MeefZah's Avatar
MeefZah's Avatar
It's cast iron (and weighs a ton). Holding up fine. Some light rust on the areas where the coating has been worn away by the steel cable but it looks just fine - the rust is inside the "mouth" and not obvious.
It's also the OEM Warn part that they supply with the steel cable.
Old 06-20-2019, 08:38 AM #51
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
still plenty of advantages using roller fairleads with synthetic
jhguth is offline   Reply With QuoteReply With Quote
Old 06-20-2019, 09:52 AM #52
CITYRNR's Avatar
CITYRNR CITYRNR is offline
Real Name: Ben
CITYRNR will become famous soon enough
CITYRNR's Avatar
Real Name: Ben
Great write up thank you. I'm still stuck deciding between this and a lo pro. Does anyone know if you can use the fairlead of the winch as a recovery point (as in being pulled out by someone?). Kind of seems like abusing the winch but it's meant to pull heavy loads like that anyway so I'm not sure.
2019 TRD ORP w/ KDSS (Silver) - 6112/5160 w/ SPC UCA, Full+Fuel RCI Skids, SSO Sliders, C4 Lo Pro w/ X20
CITYRNR is offline   Reply With QuoteReply With Quote
Old 06-20-2019, 03:39 PM #53
Gotcha, I didn't know they made cast iron versions. Thought they were all aluminum.
Looks good.
Old 06-20-2019, 05:59 PM #54
rob_dixon's Avatar
rob_dixon rob_dixon is offline
rob_dixon will become famous soon enough
rob_dixon's Avatar
Nice thanks for this, just commenting on the CS for CBI, I just bought a bunch of stuff from them and I had to call them because they were having website issues. The guy I spoke to was excellent to work with, in fact i'd say went above my expectations. Sorry you had a bad experience there, maybe it was a fluke or the particular person.
rob_dixon is offline   Reply With QuoteReply With Quote
Old 06-20-2019, 06:16 PM #55
STX4Runner's Avatar
STX4Runner STX4Runner is offline
Real Name: Jonathan
STX4Runner has a spectacular aura about STX4Runner has a spectacular aura about
STX4Runner's Avatar
Real Name: Jonathan
Don't do that. A winch is not made for that. Only use the recovery loops on the frame.
2010 TE KDSS|275/70R17 Goodyear MT/Rs|Front Bilstein 5100s @ 2.5", rear Bilstein 5100s & 2" Icon lift springs|RR sliders|RCI skid plates|BudBuilt diff skid|Sonoran Steel HD rear lower links|RCI rear lower link bracket skid plates
STX4Runner is offline   Reply With QuoteReply With Quote
Old 05-27-2020, 11:06 PM #56
MeefZah's Avatar
MeefZah's Avatar
Originally Posted by TexasTJ View Post
Ah yea, I've got an older generation VR8000, you must have the newest gen.
Just did it last week.
bumper cut, do this first as it can be your practice run and will never been seen, so it doesn't matter how ugly it is.
For the facia, I just put it back on the bumper (after cutting the bumper) and traced from the inside of the bumper. Cut that out, and then filed it/trimmed a little more, and filed again. Again, these don't have to be perfect, because the fairlead will then cover the hole.
The annoying part is, if the dealer installed the license plate bracket, you now have two holes in the bumper. Hindsight, I would've bought a new Pro facia without LP holes, cut it for the winch, and kept my original one in the attic, in case I ever want to go back to no winch.
@TexasTJ
Older thread but I'm getting ready to install a winch on my new ORP. This thread was done using my SR5 (I'm the op).
I'm interested in how exactly you installed the fair lead on top of the Pro fascia instead of cutting around it. I just can't figure out how you bolted the fairlead on... since you gotta get behind the bumper to hold the nuts. Can you provide some details on the standoff, the hardware used, and how you bolted up the fairlead, please? Thanks!
Old 05-28-2020, 09:34 AM #57
@TexasTJ
those 2 bolts go all the way thru and bolt to the front of the winch I believe. Thats what i've gathered from reading install instructions on a couple of the hidden winch mounts.
Old 05-28-2020, 10:53 AM #58
MeefZah's Avatar
MeefZah's Avatar
Yes they do, but there's no welded in nuts - you have to get a hand in there to put a wrench on them to keep them from spinning and I can't see how to do that if the bumper is on.
If you trim around the fairlead then the bumper cover goes on after the fairlead is installed so it's no problem. But if you mount the fairlead on top of the cover you'd have to install the fairlead last and it seems damn near impossible to get a hand behind there.
Old 05-28-2020, 11:15 AM #59
TexasTJ's Avatar
TexasTJ TexasTJ is offline
TexasTJ is just really nice TexasTJ is just really nice TexasTJ is just really nice TexasTJ is just really nice
TexasTJ's Avatar
@TexasTJ
The bolts go straight through to the holes in the fairlead mount of the HWM. I just laid down under the front of the 4R, and was able to reach the back of the fairlead mount to hold the nut in place. Sort of off to the side. Repeat on the opposite side. The skid may have been off at the time, but I just went out and tried it with it on, I was still able to easily reach the back of the fairlead nut. Used some grade 8 hardware, cut some PVC as spacers to keep the bumper cover from getting pinched in.
2017 T4R TRD Pro Cement - Dobinsons 2/1" (300/599), IMS 700/701, Air Lift 1000 air bags (60804), Pelfreybilt hidden winch mount, Warn VR8 w/ Amsteel synth, 2021 ORP LED headlights, DD SS3 Sport yellow fogs, CBI steel skid plates, Rough Country 20" LED bar, Gobi stealth no rise w/ ladder, ARTEC sliders, ARB 63qt fridge, Canvasback liners, homemade spare tire hitch carrier, ARB single air compressor w/ Slee mount, bronze TRD Pro wheels
TexasTJ is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 11:27 AM #60
MeefZah's Avatar
MeefZah's Avatar
Thanks! I'll take a second look at the SR5 and maybe drop the skid to get an arm up in there.
bumper , mount , sdhq , steel , winch
SDHQ 2014+ 4Runner Hidden Winch Mount SDHQ OFFROAD SDHQ OFFROAD 3 02-07-2019 06:03 PM
Modifying an universal winch mounting plate for a hidden winch alia176 4th Gen T4Rs 9 09-10-2018 09:44 PM
Winch access and operation on a 5th Gen with hidden winch 08runnertjb 5th gen T4Rs 10 02-12-2016 12:40 PM
What winch for hidden winch bumper spencenasty 5th gen T4Rs 1 11-23-2015 11:06 AM
Budbuilt Hidden Winch Plate and Engo 10K Winch Setup cmoua 4th Gen T4Rs 0 07-01-2015 09:22 PM
