Old 06-05-2020, 12:14 AM #61
MeefZah's Avatar
MeefZah MeefZah is offline
MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold
MeefZah's Avatar
Here's my install on a 2019 ORP. A lot of it is very similar to the install on my 2017 SR5 (which my wife has now laid claim to, thus resulting in the 2019 ORP for me).
Here's the SDHQ kit. Same as the prior version, except they sent me the directions for a Tacoma by accident. Didn't really need the directions since I've done this before! The powdercoat also appears to be a more matte finish than the semi-gloss from the previous model.
I went with a Warn VR-8S EVO. The prior install was a VR-8. At that time I had wanted steel cable as I intended to skid a lot of downed trees with the winch. Fast forward 18 months, guess how many trees I moved? Zero. I did use the winch several times for recovery and the 8k seemed just fine for my applications, so I stayed with that weight rating. This time I went with synthetic line though, just for ease of use and weight. The EVO has replaced the base VR in the Warn lineup. It's very similar but it also comes with a wireless remote, which is a nice touch at its price point. It also has an aluminum hawse, the old VR series had this insane cast iron hawse for both synthetic and steel cable and it weighed like 148 pounds. The EVO also has a quarter turn clutch instead of a 180 degree clutch. Weirdly, it doesn't come with some of the nice add ons that the VR-8 did, like a cable sheath, wire looming, a decal... or good instructions. I actually would have been a little confused with installing it had I not done it before because the instructions were seriously lacking.
First step is to remove the front bumper skin and then separate the fascia, easy to do. Watch the video linked in the first post of this thread. By now I can remove the bumper blindfolded and in about 3 minutes!
Remove the aluminum OEM sub-bumper with 8 14mm bolts. When you do, keep the steel outer ears. We'll use a piece of them again since the ORP install has one glaring issue!
Starting install:
Winch (minus control box) bolted in:
It's a little tight... but the clutch does clear the line:
You also have to bend the AC line slightly:
So on the 2017 SR5 install I had a LED bar above the winch that interfered with the control box, so I had to move the control box. On this one, I don't have that LED so technically there is enough room for the control box on top of the winch. Only problem is that the PS line (I think it's the PS line) runs right through there. I decided to raise the control box an inch to clear the line. First I wrapped the line with a bit of old motorcycle innertube:
I replaced the bolts with longer ones (I believe they are M4x30) and put a 1" spacer over the two front bolts to space the control box up. I used a old Tacoma front mudflap, the ones that go in front of the front tire that no one knows the purpose of, as a rubbery baseplate to keep the control box from banging around since it won't be bolted down on the back.
Continued next post
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You can’t grasp its vastness from a plane. It’s diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
Photos, mods & trip reports
MeefZah is offline   Reply With QuoteReply With Quote
Old 06-05-2020, 12:14 AM #62
MeefZah's Avatar
MeefZah's Avatar
Okay, remember above I said there is a glaring issue for ORP installations (or Trail / OR / PRO)? The issue is, if you want to have the fairlead on top of the bumper skin, instead of in the bumper and trimming the skin around it, you have to bolt in spacers under the fairlead to act as a standoff between the SDHQ bumper and the fairlead. You cannot access the back of the SDHQ bumper to hold the nuts for the fairlead bolts in place once the bumper skin is installed. There is a poster above that has done it, I asked him about it, and his advice didn't work for me. I honestly do not see any way to get an arm in there.
So... I cut off the ends of those OEM sub-bumper ears pictured above. The ears have M10 nuts welded in, and by cutting off about 1.5" of the ear you get a nut with a square backing, that you can drop into the SDHQ bumper. When you tighten the fairlead bolt into that nut, the square backing catches on the bumper and allows you to tighten the bolts.
I painted them before install (shown unpainted):
This is how they will interface with the bumper:
And this is how I'll hold them in place as I'm seating the bolts: grease!
Starting the trimming. This is the part that tears up my gut. You screw this up, it's time for a new piece. The OR / PRO models you can cut the bumper skin in a big rectangle since it'll be covered but you better get the fascia cut right!
This is one ugly cut! Luckily no one will see it after this!
Fascia trimming. I made the holes significantly bigger (in increments) after this picture was taken:
I used M10 bolts for the fairlead and used three 1/2" nuts as spacers (the bolt drops through them and doesn't thread into them).
Home stretch now! Reinstall the fascia to the bumper skin, reinstall the bumper skin to the truck, bolt up the fairlead:
Spacing from above. Pretty flush; I'm okay with it. Better slightly too far off the bumper than too snug against it.
Cut an access port in the radiator cover:
I still need to either reinstall my front plate or plug the holes, get the wiring sheathed and zipped neatly away, add an M8 thumb nut to easily connect / disconnect the power cable from the battery, and I am waiting for a thimble to arrive to get the winch line squared away. I went with a Mile Marker thimble, it is pretty interesting and doesn't need a separate pin like the Factor 55, Smittybilt AWS, etc. It's also smaller, cheaper, and takes one entire link out of the system.
MM thimble install video: YouTube
Old 06-08-2020, 10:42 PM #63
MeefZah's Avatar
MeefZah's Avatar
Installation completed with thumb nut to + battery terminal, wire loom on all exposed wiring, 1/4" panel plugs to cover the license plate holes, and Mile Marker thimble:
Smaller gauge red wire is under the nut (not thumb nut) and controls my HAM radio.
Ended up not really in love with the MM thimble, so I went with a Factor 55 Flatlink bought from SDHQ with the forum discount!
Old 06-12-2020, 11:43 PM #64
damnitzryan's Avatar
damnitzryan damnitzryan is offline
damnitzryan is on a distinguished road
Thank you @MeefZah for all the great info! Which fairlead setup do you like better for the ORP with the extra valence/fascia?
Did you look into the LFD and Rago hidden winch offerings before buying the SDHQ one for your second 4Runner?
2018 T4R TRD ORP
damnitzryan is offline   Reply With QuoteReply With Quote
Old 06-12-2020, 11:47 PM #65
MeefZah's Avatar
MeefZah's Avatar
Do you mean do I prefer mounting the fairlead on top of the plastic as opposed to trimming the plastic around the fairlead? I prefer it on top, it's just a cleaner install.
I did not look at other stuff. I was real pleased with the first SDHQ unit so I saw no reason to mix things up.
Old 11-29-2020, 03:56 PM #66
MeefZah's Avatar
MeefZah's Avatar
Originally Posted by JayEmVee View Post
I have been following this post and have decided to do pretty much the same thing. I mounted the solenoid box inside the engine bay, however.
IMG_2002.jpg - Google Drive
IMG_2003.jpg - Google Drive
Can't see your pics... but I'm interested to see them. Reattach them?
Old 11-30-2020, 08:20 PM #67
JayEmVee JayEmVee is offline
JayEmVee is on a distinguished road
I think I figured out how to attach pictures.
Here is my control box inside my engine bay.
SDHQ hidden winch installation-2000-jpg  SDHQ hidden winch installation-2001-jpg
JayEmVee is offline   Reply With QuoteReply With Quote
Old 12-25-2021, 04:52 PM #68
4WheelAstroHack 4WheelAstroHack is offline
4WheelAstroHack is on a distinguished road
Originally Posted by N52228 View Post
Just finished installing the SDHQ mount and Smittybilt x20 10k on my truck over the weekend. Install was fairly straightforward minus figuring out what to do with the control box. I have the same light bar setup as @MeefZah and followed his lead by mounting the controls to the light bar bracket.
I'll try to get a few pictures of what I did with the front plate and fairlead when I get home later this afternoon.
Any chance you could post what you did with the control box? I have the same setup that I'm installing.
4WheelAstroHack is offline   Reply With QuoteReply With Quote
Old 12-29-2021, 07:32 PM #69
Jp9075 Jp9075 is offline
Jp9075 is on a distinguished road
Hi fantastic setup did u had suspension done on 2nd 4Runner or it’s OEM. If not OEM what ur suspension setup. Did it snag
Jp9075 is offline   Reply With QuoteReply With Quote
Old 02-12-2022, 12:02 AM #70
Lcsguthrie Lcsguthrie is offline
Lcsguthrie is on a distinguished road
Just got mine installed. Thanks for the advice, the SDHQ mount is sharp, and you can’t beat no lead time. Only issue I had was with one of the welds on the mount that had spilled over into the area the winch sits. Ended up having the grind down the weld about 1/4” to get the winch to bolt up.
I modified a waterproof aluminum box for the solenoid and wiring and mounted it in the engine bay. Also was able to fit a 500A battery disconnect on the tray next to it. Based on the circuit length and amperage calculations, I went with 2/0 cable. These big cables ended up being a pretty major PITA. Crimping, routing, and general fitment is all just more difficult and time consuming with the big gauges. In the end I think the result was good, just don’t know if I’d recommend running anything bigger than #2 or #3. The winch itself comes standard with much much smaller wires than 2/0 anyway.
SDHQ hidden winch installation-5df47f2d-f850-4464-816b-5d94433d8d63-jpg  SDHQ hidden winch installation-973cb23b-43c2-4374-9972-55910df8eaa4-jpeg  SDHQ hidden winch installation-b3f399db-b1b4-4ec6-a815-bef3ba5b8b10-jpeg
Lcsguthrie is offline   Reply With QuoteReply With Quote
Old 02-01-2023, 01:10 AM #71
4Brewz's Avatar
4Brewz 4Brewz is offline
4Brewz is on a distinguished road
4Brewz's Avatar
Installed one today in a 2022 ORP with Warn 8VR
Couple things
The template was no where near for me. I do have a 1/2” body lift, and I measured down a 1/2 inch but way off. Didn’t matter as others showed a big rectangle is all you need. I simply marked the holes where they needed to be for the fascia.
I made mine flush to the fascia. I did this using washers to space it out. It came to 13/16” worth
I moved the cooler line up and the winch fit with the control box just fine.
I was able to tape a nut onto a wrench and fit my arm down to tighten the fairlead.
SDHQ hidden winch installation-a1e9dd12-ce94-45a0-a133-d772b670799d-jpg  SDHQ hidden winch installation-1cceb8e7-1586-4d6d-959d-5441258d0e48-jpg  SDHQ hidden winch installation-9afacab4-18fb-4d80-80e7-bca9e0c3ff90-jpg  SDHQ hidden winch installation-bb612c4b-831f-490e-8e21-b66c613b92c2-jpg  SDHQ hidden winch installation-0959e500-e662-4490-9e97-89846738e2cf-jpg
22 Toyota 4Runner ORP Army Green
IndyGarage Amateur Hour Channel
5th Gen 1/2" Bodylift
5th Gen Raptor Light Adapter Plug
Use code IndyGarage10 for 10% Off
4Brewz is offline   Reply With QuoteReply With Quote
Old 02-06-2023, 02:35 PM #72
MeefZah's Avatar
MeefZah's Avatar
Sorry for the delay, I'm not on this forum anymore. It's basically a 2.5 front 1.5 rear lift using Eibach / Wheeler T1 and T13 coils, and 33" tires. No rub (snag?).
bumper , mount , sdhq , steel , winch
SDHQ 2014+ 4Runner Hidden Winch Mount SDHQ OFFROAD SDHQ OFFROAD 3 02-07-2019 06:03 PM
Modifying an universal winch mounting plate for a hidden winch alia176 4th Gen T4Rs 9 09-10-2018 09:44 PM
Winch access and operation on a 5th Gen with hidden winch 08runnertjb 5th gen T4Rs 10 02-12-2016 12:40 PM
What winch for hidden winch bumper spencenasty 5th gen T4Rs 1 11-23-2015 11:06 AM
Budbuilt Hidden Winch Plate and Engo 10K Winch Setup cmoua 4th Gen T4Rs 0 07-01-2015 09:22 PM
