08-25-2019, 07:58 PM
#31
Originally Posted by Akkording
@ MAST4R
I've been following your issues. Just curious have you upgraded the stock bump stops or have any intentions to.
I would also suggest you call Bilsteins to confirm the specs on the two different model springs to see what are the specs difference.g.
Thanks! I may have created a wrong impression, I am not having any issues at all but rather a learning experience. Cinder Hills is very unusual terrain and they still performed far better than stock. Yesterday, we drove a variety of dirt road terrain, including a high clearance dirt road. The 6112s were perfect in both performance and comfort. That was the kind of terrain I really wanted to see the 6112s in.
I did call Billstein and they all seem to check out. The springs do have the FJ part number but they said that FJ and 4R springs are both 14" and 600lb.
So all is good! I don't think I will learn much more till the winter though.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
09-24-2019, 12:07 AM
#32
Does anyone know if the increased height with the 650lb coil is including the extra weight(80-150lb) or without weight. Trying to get 2 in of lift with 120lb front weight. Is that setting clip 3 or 4 with the new 650lb coils? May need to call bilstien tomorrow.
09-24-2019, 12:25 AM
#33
Keep us posted on what they say. Driver is always a tad higher than passenger unless you have kdss.
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
09-30-2019, 03:50 AM
#34
Do you still have the sale price on the springs?
09-30-2019, 07:41 AM
#35
I have FJ TRD pro suspension on my 4runner. I was thinking about upgrading to a c4 lopro bumper with winch. Is this spring going to achieve additional lift of .7”?
I also have a cornfed 1.5” spacer on it... can I still use the spacer or is the added height and # just going to help with the additional weight?
01-15-2020, 12:36 PM
#36
Originally Posted by dahveeed
Posted this in another thread "quick question, on a few sites with part# 47-284142 they are listed for FJs but not 4th gen 4runner. This part number is the exact same as # 47-260153 except springs are 650lbs instead of 600lbs correct?"
47-284142 has 700 lb springs and has a lot more control in the valving. and yes it will work on 4th gen 4runners
08-19-2020, 01:04 AM
#37
Originally Posted by Battle Born Offroad
4 Sets in stock
interested! pls pm
2006 Limited V8 4x4. Shadow Mica. FN fx pro wheels. bfg ko2 265/70/17 load range C.
Full album
02-01-2021, 01:59 AM
#38
Originally Posted by MAST4R
Are we sure the regular 6112 springs are 600lb? I had 586lb Dobinsons springs
So, is the 6112 spring really 600lb?
Does the 6112 shock have a really good internal bump stop or whatever the correct technical term is?.
It took forever, and I have been on 650lb springs for more than a year, but I can now answer my own questions.
1/ No, the 6112 standard spring is not 600lb. It is max 550.
2/ The 6112 strut is indeed quite capable.
Also, the 8112 uses the same spring as the standard 6112. That does not necessarily mean the softer spring makes the 8112 need the 650 for more serious offroading as it does with 6112. I have to drive the 8112 to see how the three-zone design would work with the softer spring.
06-22-2021, 04:05 PM
#39
Expecting these back in one week
06-22-2021, 04:40 PM
#40
After taking video, going slow-mo and taking measurements to scale, using the 6112 on 650, and getting the factory front bump stops fully compressed,
I will venture a guess that the 650 lb will be necessary even with the 8112 (for higher speed desert, not for anything else).
06-16-2023, 02:58 PM
#41
There is more dampening and bottom out control with the 8112, but the 650 is our preferred spring for it.
