Old 08-25-2019, 07:58 PM #31
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Originally Posted by Akkording View Post
@MAST4R
I've been following your issues. Just curious have you upgraded the stock bump stops or have any intentions to.
I would also suggest you call Bilsteins to confirm the specs on the two different model springs to see what are the specs difference.g.
Thanks! I may have created a wrong impression, I am not having any issues at all but rather a learning experience. Cinder Hills is very unusual terrain and they still performed far better than stock. Yesterday, we drove a variety of dirt road terrain, including a high clearance dirt road. The 6112s were perfect in both performance and comfort. That was the kind of terrain I really wanted to see the 6112s in.
I did call Billstein and they all seem to check out. The springs do have the FJ part number but they said that FJ and 4R springs are both 14" and 600lb.
So all is good! I don't think I will learn much more till the winter though.
Old 09-24-2019, 12:07 AM #32
Guru6022 Guru6022 is offline
Guru6022 is on a distinguished road
Does anyone know if the increased height with the 650lb coil is including the extra weight(80-150lb) or without weight. Trying to get 2 in of lift with 120lb front weight. Is that setting clip 3 or 4 with the new 650lb coils? May need to call bilstien tomorrow.
Guru6022 is offline   Reply With QuoteReply With Quote
Old 09-24-2019, 12:25 AM #33
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
Keep us posted on what they say. Driver is always a tad higher than passenger unless you have kdss.
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 09-30-2019, 03:50 AM #34
pixjohn pixjohn is offline
pixjohn is on a distinguished road
Do you still have the sale price on the springs?
pixjohn is offline   Reply With QuoteReply With Quote
Old 09-30-2019, 07:41 AM #35
ThatRig ThatRig is offline
ThatRig is on a distinguished road
I have FJ TRD pro suspension on my 4runner. I was thinking about upgrading to a c4 lopro bumper with winch. Is this spring going to achieve additional lift of .7”?
I also have a cornfed 1.5” spacer on it... can I still use the spacer or is the added height and # just going to help with the additional weight?
ThatRig is offline   Reply With QuoteReply With Quote
Old 01-15-2020, 12:36 PM #36
MobbinDez MobbinDez is offline
MobbinDez is on a distinguished road
Originally Posted by dahveeed View Post
Posted this in another thread "quick question, on a few sites with part# 47-284142 they are listed for FJs but not 4th gen 4runner. This part number is the exact same as # 47-260153 except springs are 650lbs instead of 600lbs correct?"
47-284142 has 700 lb springs and has a lot more control in the valving. and yes it will work on 4th gen 4runners
MobbinDez is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 01:04 AM #37
neoguri neoguri is offline
neoguri is on a distinguished road
Originally Posted by Battle Born Offroad View Post
4 Sets in stock
interested! pls pm
2006 Limited V8 4x4. Shadow Mica. FN fx pro wheels. bfg ko2 265/70/17 load range C.
Full album
neoguri is offline   Reply With QuoteReply With Quote
Old 02-01-2021, 01:59 AM #38
MAST4R's Avatar
MAST4R's Avatar
Originally Posted by MAST4R View Post
Are we sure the regular 6112 springs are 600lb? I had 586lb Dobinsons springs
So, is the 6112 spring really 600lb?
Does the 6112 shock have a really good internal bump stop or whatever the correct technical term is?
It took forever, and I have been on 650lb springs for more than a year, but I can now answer my own questions.
1/ No, the 6112 standard spring is not 600lb. It is max 550.
2/ The 6112 strut is indeed quite capable.
Also, the 8112 uses the same spring as the standard 6112. That does not necessarily mean the softer spring makes the 8112 need the 650 for more serious offroading as it does with 6112. I have to drive the 8112 to see how the three-zone design would work with the softer spring.
Old 06-22-2021, 04:05 PM #39
Battle Born Offroad Battle Born Offroad is offline
Battle Born Offroad has a spectacular aura about Battle Born Offroad has a spectacular aura about Battle Born Offroad has a spectacular aura about
Expecting these back in one week
Battle Born Offroad is offline   Reply With QuoteReply With Quote
Old 06-22-2021, 04:40 PM #40
MAST4R's Avatar
MAST4R's Avatar
After taking video, going slow-mo and taking measurements to scale, using the 6112 on 650, and getting the factory front bump stops fully compressed,
I will venture a guess that the 650 lb will be necessary even with the 8112 (for higher speed desert, not for anything else).
Old 06-16-2023, 02:58 PM #41
There is more dampening and bottom out control with the 8112, but the 650 is our preferred spring for it.
bilstein , front , spring , suspension , weight
Bilstein 8112 TrDpRo_J 5th gen T4Rs 27 08-20-2023 12:42 PM
Bilstein 6112 Strut Spring Assemb + 5160 Reservoirs Set 03-09 4Runner 4WD 1.9" meltdowner 4th Gen T4Rs 2 10-07-2018 10:28 PM
Front suspension upgrade - LCA bushing swap, Bilstein 6112 alia176 4th Gen T4Rs 10 06-24-2017 04:39 PM
Bilstein 8112 at AZ Off Road Expo Az4runnin 4th Gen T4Rs 5 03-29-2017 11:59 PM
