08-02-2021, 10:31 PM
#61
Real Name: Kirk
Real Name: Kirk
Still have a set available??
AMLOR
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
08-04-2021, 09:01 AM
#62
30 out of 50 are sold.
Thanks everyone!
08-04-2021, 09:18 AM
#63
PM sent
08-20-2021, 03:43 PM
#64
Recovery points have been manufactured, and are shipping as soon as we pick them up!
10-04-2021, 10:21 PM
#65
Real Name: Tom
Real Name: Tom
PM sent if there’s some left.
A white 2017 Off-road for me, and a Cement 2020 Tacoma Off Road for the wife.
10-11-2021, 03:02 PM
#66
Real Name: Danny
Real Name: Danny
Question to the thread, I have a limited and my tail pipe is in the way of one of the mounting points. Anyone have detailed steps of how this was approached?
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg BJ UCA's Fox 2.5 Resi rear W/ Icons. Method 701's, Cooper S/T Maxx 285/70/17. Shrockworks sliders. LLama Tales
Dual Battery Thread
10-11-2021, 05:19 PM
#67
4th gens have a large resonator there so I chopped the tailpipe with a sawzall so it exited pointing down right behind the rear tire.
Or an exhaust shop can modify the tailpipe so it turns before the recovery point and it exits out the side of the vehicle.
10-12-2021, 12:36 PM
#68
This batch of recovery points has sold out.
Reply down below if you are interested in the next batch and I'll notify you when we start again.
10-13-2021, 10:04 AM
#69
Please put me on the list for your next batch.
11-05-2021, 04:53 PM
#70
In for next batch
11-09-2021, 03:45 PM
#71
Hey - if you have any left, I’ll but 2.
Please PM me.
Thanks
02-21-2022, 09:50 AM
#72
I'm in for two.
06-09-2022, 06:56 PM
#73
I'm in for the next batch! x2.
'22 Super "Betty" White TRD Pro
to the Raptor Light reppin', Heritage Grill Pro lookalikes!
12-16-2022, 09:40 PM
#74
For future recovery point orders, visit my brother's website. He has them in stock at all times as far as I know.
Rear Recovery Points
– Iconic Fabrication
12-17-2022, 12:30 AM
#75
Real Name: Dave
Real Name: Dave
Rear recovery points
4Runners all come with one tie-down loop, usually on the back left frame. But if you look, you'll see there is a matching set of bolt holes on the right side frame. You can confirm this by taking off the one that's there and bolting it on to the other side. Then go buy the Toyota Part with bolts and mount it on the frame where it doesn't have one. Cheap and easy. It's as strong as anything I've seen made aftermarket.
If you're serious enough to need recovery points, or you want to eliminate exhaust coming in the back window when it's open, you should have already turned your tailpipe sideways to exit behind the rear tire.
For really serious pulls or self-rescue with a winch, use a bridle that connects both recovery loops.
Here's a couple of photos showing the tie-down loop and a DIY bridle I made using 1/2" Samson synthetic rope. !/2" rope is thicker than any bridles on the market and the synthetic rope in your winch.
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
