02-18-2019, 03:25 PM
#31
Originally Posted by northcoast
So, as someone who worked on the inside, what is your thought on the "lifetime" transmission fluid? Not picking a fight, I genuinely want to know.
I'm a maintenance nut so no way for me. My dealership aways recommended a drain and refill at 50K and that's what I'll do with mine. That really only replaces less then half of the fluid. Even Toyota recommends fluid change every 60K of you use it for heavier duty application, like towing, offroad and rooftop carriers.
My background is in the racing industry and I've done probably 40-50 oil Analysis on quite a few different oils and vehicles, and my oil of choice would be Reline by a mile. That being said I would only use the Toyota WS when doing my Trans. I will use the Toyota "Gold" in the transfer case as well since of the viscosity that it calls for and no one seems to make a replacement for it. Everything else gets Redline.
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
02-18-2019, 07:11 PM
#32
A couple times a year Mobil offers a pretty nice rebate, like $12 off 5 quarts, and you can submit up to two of them. If you get the 5qt jugs from walmart, et al you can get a jug of mobil for anywhere from $10-$15 each.
Example:
Mobil1 Full Synthetic Oil - $10.88 After Rebate - Walmart
Slickdeals.net
My GX takes 8.2qts, so with a Toyota filter ($5-$8) and drain washer I'm usually looking at about a ~$30 synthetic oil change. My local Lexus dealer wanted to charge $90 + tax for regular and something like $120 or $130 for a synthetic change. If you factor my time the dealer is certainly cheaper but I enjoy the DIY.
Regarding 5W-20 vs 0W-20, this is a Toyota, this doesn't matter.
In fact I even think my Lexus manual actually states that 5W-20 is fine if 0W is not available. I've personally run 5W-20 that I had on hand, and mixed the remainder of my 5W-20 in with 0W-20 on the next change. I'd imagine the 4.0 V6 in the runner is even less fussy than the 4.6L V8.
Honestly going with synthetic in general on these engines IMO is overkill, but I personally like mobil products and it makes me feel slightly better taking the oil to the full 10,000 mile interval.
02-18-2019, 10:07 PM
#33
Man you guys are worse then the euro car crowds, 0w or 5w you’ll be fine. Since these number refer to extreme cold and your in California you will never see a difference.
02-18-2019, 10:28 PM
#34
Originally Posted by 97BlackAckCL
It's always a pissing contest over topics like this
I used to come here for info and collegiality. It has turned into a bunch of apes thumping their chests and measuring their dicks. I keep hoping for a change in personnel but it looks like a bunch of jerks have moved into the neighborhood. Has anyone ever heard of “if you don’t have anything nice (constructive) to say, don’t say anything”? Who cares if this guy uses 0 or 5 whatever... the difference between those oils is (a) not a big deal and (b) not your problem... it’s his truck. Before you type your next response to a post, stop and think... am I really trying to help someone, or am I just trying to make myself look important/smart?
2022 SR5 Premium 4WD
02-18-2019, 10:31 PM
#35
Pc snowflakes getting triggered
02-19-2019, 12:19 AM
#36
Originally Posted by Bayou_Pro
I know exactly what the differences are but you know better then Toyota engineers so do what you want.
well using that logic make sure you keep the stock garbage shocks, tires, and don't add weight like sliders cause the engineers would've known better.....
02-19-2019, 12:30 AM
#37
So pretty much the OP tried to brag about his cheap oil but ended up getting pissed on by everyone for using the wrong oil.
2018 SR5 Premium MGM
TRD Pro wheels
LT265/70/17C BFG KO2
02-19-2019, 12:36 AM
#38
Totally different logic but whatever.
Paul
02-19-2019, 08:32 AM
#39
Not really. Hell, they might even use 20 weight just for better gas millage. Id be curious to see what other countries recommend. My motorcycle recommends oil changes every 3k miles in the US/Canada manual but 6k miles in the European manual (no i wasn’t looking at KM).
02-19-2019, 10:16 AM
#40
Real Name: Chris
Real Name: Chris
Agreed, unfortunately lots of people are know it all tough guy on the Internet
