02-17-2019, 02:14 AM
Synthetic Oil Change for $17
In December I scored 7 quarts of Mobil 1 5W-20 Annual Protection for $2 a quart. Purchased a new OEM oil filter + drain plug washer for $4.
Today I changed my oil, my T4R has 28,000 miles, and the old oil had 7,500 miles. I added copper anti-seize to all the skid plate bolts and will run this oil for 7,500 miles. Not a bad final price for Mobil 1 and a little DIY. Job took 45 minutes to complete.
2016 T4R SR5 Premium + Bilstein 6112 Coilovers front + Bilstein 5100 Rear + TRD 17" rims + 265/70R17 Nitto AT Grappler G2's + Tinted Windows + OEM Running Boards + Rigid Industries D2 Driving Lights in OEM Fog Light location
02-17-2019, 10:33 AM
Nobody cares unless you tell us where you got the stuff so cheap, and if the deal is still going.
2016 SR5 4WD. BFG KO2 275/70R17. FJ TRD Bilsteins + Wheelers 1.25" preload spacers + Eibach rear springs.
02-17-2019, 10:40 AM
Shouldn't you be using 0W-20?
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
02-17-2019, 10:44 AM
Wouldn't that be $18 spent (7q oil x $2 = 14 plus $4 filter/washer) ?
02-17-2019, 10:51 AM
Yep - 0W-20 is the correct oil used in the 5th Gen 4R Dual VVT-I
Single VVT-I...ie…2nd Gen Tacoma uses 5W-30
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
02-17-2019, 11:08 AM
Real Name: Ben
Real Name: Ben
That's a great price
2019 SR5 MAGNETIC GRAY METALLIC
02-17-2019, 11:15 AM
Tough crowd these days...
2016 Nautical Blue T4R TEP w/KDSS, Oil Filter canister upgrade, Eibach Pro Truck lift 2.75/1.0, JBA UCAs, XD Machete 17X9 Wheels, Falken Wildpeak 275/70/17.
02-17-2019, 11:23 AM
Real Name: Chris
Real Name: Chris
That's a great deal. Wrong oil weight though!
02-17-2019, 11:28 AM
Truck won't know the difference at CA temps, and may even be a more stable oil (although that's not really an issue in these engines).
02-17-2019, 11:32 AM
correct on your comment .. he probably was high on drugs and hit the wrong key ..
also the taxes on his oil purchase would be more than $17....since he is from CA....
then using the wrong engine oil spec.
02-17-2019, 11:38 AM
That just proves that you know very little about oil sir. Any idea how the VVT-i works??? I didn't think so.
Toyota even startes in the manual that 5W-20 can be used in a pinch but should be changed out asap.
Paul
02-17-2019, 11:41 AM
Yeah. Not true.
20 weight oils are very shear stable. And the difference between 0w and 5w is cold weather pumpability and not much else. Living in MN? I'd be hesitant. CA? Not so much.
02-17-2019, 11:44 AM
Yeah. Not true.
I know exactly what the differences are but you know better then Toyota engineers so do what you want.
Paul
02-17-2019, 11:50 AM
Then what's the harm? Viscosities at operating temps are nearly identical as are most of the other specs. Pour point is different but that doesn't hardly matter at temperatures above zero.
02-17-2019, 11:53 AM
Cold start up is the point. These engines have very tight tolerances. It's pretty simple just to use the correct oil. The end.
Toyota does sample and analyze the oil on an engine claim. What's going to happen to this guy's engine warranty when Toyota finds the wrong weight oil in his blown motor. And I'm not even saying it's going to happen from 5W oil. I'm just playing devil's advocate here.
Paul
