Old 03-22-2019, 11:48 PM #16
yardsale's Avatar
yardsale yardsale is offline
yardsale will become famous soon enough
yardsale's Avatar
Thanks for the pic. Ordered!
yardsale is offline   Reply With QuoteReply With Quote
Old 03-23-2019, 12:05 AM #17
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
Looking good boys, yeah I was surprised how well they functioned and looked. I dig the red heck I even powdercoated my King springs TRD red.
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 03-23-2019, 03:27 AM #18
Kamalani Mahie's Avatar
Kamalani Mahie Kamalani Mahie is offline
Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough
@Akkording @mrblah can you also put these on the rear?
Originally Posted by RysiuM View Post
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
Kamalani Mahie is offline   Reply With QuoteReply With Quote
Old 03-23-2019, 04:04 AM #19
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
no you cannot put them in the rear. The rear bump stops connect to the frame w/ 2 holes. Most aftermarket/universal ones are single holes. The companies that make true upgrades like timbren cost mucho dinero.
I'm currently running toytec extensions on my rear OEM bumpstops, and man, do you feel it when they bottom out. This is more of a bandaid than a true upgrade.
Old 03-23-2019, 11:29 AM #20
Spanky4R's Avatar
Spanky4R Spanky4R is offline
Spanky4R is on a distinguished road
Spanky4R's Avatar
This guy may be able to solve some issues. Forum member designed these.
- DuroBumps
2015 SR5 Barcelona Red, Icon Lift, Icon Delta Joint UCA's, Falken Wild Peak AT3W's LT285/75R17, Warn Semi-Hidden Winch Bumper, Smittybilt Gen2 X20 10K Synthetic Winch, RCI Aluminum Skids, Shrockworks Dimpled Tread Sliders, Boss 4R Strongbox, OCD Rear Sway Bar Links, Rad Rubber Liners, ARB Rear Diff Breather, Airaid MXP Cold Air Intake, Airaid Superaid Throttle Body Spacer, Blackout Badge Kit, AVS Bugflector II, & WeatherTech Floor Liners.
Spanky4R is offline   Reply With QuoteReply With Quote
Old 03-23-2019, 12:04 PM #21
ChildrenOfBodom's Avatar
ChildrenOfBodom ChildrenOfBodom is offline
Moderator
Real Name: James
ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light
Moderator
Real Name: James
Hello,
James here from Energy Suspension.... very cool to see forum members making their own adaptations!
Something to look for in the future, this is still a little while off, but the new Rockflex bump stop is going to be available for 4Runners around the end of the year. It's a progressive rate bump that will give you the same rate as an MCU bump at first, then gradually stiffen up. You won't feel a hard hit, rather, a smooth engagement.
We have already released the bump for the Jeep JL, it has a molded in metal washer base that will allow you to use it with almost any single-bolt application. We have plans to release it for Toyota later this year, but early adopters have already fitted them to the 4Runners.
Part number has been released, but I'm not at work right now. I'll have to post it later. It just barely arrived to market.
Here's a video from the SEMA show for their debut on the JL.
The very next adaptation of this part will be a Toyota IFS version and a rear two-bolt adapted version. The kicker will be the new rear coil bumps featuring rock-flex, that will fit 3rd-5th generation 4Runners.
We also already make high-articulation 3-piece rear arm bushings for 3rd and 4th gen factory arms, I've got approval to bring in a 5th gen to our facility for R&D sometime this year.
I managed to get hold of some of the JL prototypes, lobbed off the top of them, then tested them out on my 3rd gen IFS at the Hammers with great results. Can't wait to get an IFS specific version to market!
IG: @jimharb | YouTube
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
ChildrenOfBodom is offline   Reply With QuoteReply With Quote
Old 03-23-2019, 03:51 PM #22
Akkording's Avatar
Akkording's Avatar
Yeah I was aware of that brand as well but was looking at cheaper alternative solutions. I never felt my rear bottom out before so I didn't give much research into a rear bump stop set.
Old 03-23-2019, 04:19 PM #23
mrblah's Avatar
mrblah's Avatar
Originally Posted by ChildrenOfBodom View Post
Hello,
Make it affordable and it will sell like hotcakes.
Old 03-24-2019, 05:49 PM #24
djc1977 djc1977 is offline
Real Name: Deborah
djc1977 is on a distinguished road
Real Name: Deborah
Originally Posted by Akkording View Post
I kind of discovered these on accident while searching for other parts. So I rolled the dice and tried out Energy Suspension 8.9104R rear bump stops in place of my front bump stops. They worked well for me on a recent trip to Barnwell Mountain, it will bolt right on, all hardware fits. I know it says rear bump stops but that didn't prevent me from trying them up front.
Red:
https://www.amazon.com/gp/aw/d/B01E1...mob_b_pd_title
Black:
https://www.amazon.com/Energy-Suspen...eywords=8.9104
Just placed an order based on your recommendation... can’t wait to get them installed! Energy Suspension 8.9104R rear bump stops in place of front bump stops
2008 4Runner SR5 - Stock for now.
djc1977 is offline   Reply With QuoteReply With Quote
Old 03-25-2019, 07:29 AM #25
borfoo3's Avatar
borfoo3 borfoo3 is offline
borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about
borfoo3's Avatar
For thise shopping around, I'll add that Wheeler's Superbumps bump stops have been good with me so far. For rears, Icon hydarulic bumpstops are the way to go, but $$
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
borfoo3 is offline   Reply With QuoteReply With Quote
Old 04-25-2019, 07:20 PM #26
Real Name: Deborah
Real Name: Deborah
You know I never realized that this thread was in the 5th gen sub-forum. Can’t really tell when you are on the app. Anyhow, will this work for the 4th gen Runner?
Old 04-25-2019, 08:28 PM #27
57buick's Avatar
57buick 57buick is offline
57buick is just really nice 57buick is just really nice 57buick is just really nice 57buick is just really nice
57buick's Avatar
Hello,
So what is the jeep part number for these?
2018 TRD Premium, KING suspension, 285/70/17 Duratracs, 4.88 gears, Addicted offroad front Bumper, C4 FAB rear bumper, My build thread https://www.toyota-4runner.org/5th-g...ld-thread.html
57buick is offline   Reply With QuoteReply With Quote
Old 04-25-2019, 08:46 PM #28
Akkording's Avatar
Akkording's Avatar
I believe they will. If someone can compare Toyota parts numbers we might be able to confirm.
Or just order it and let us know.
Old 04-25-2019, 08:54 PM #29
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
What size bump stop (front) for what size lift? Thanks!
Old 04-25-2019, 09:08 PM #30
Akkording's Avatar
Akkording's Avatar
Cool
They are 2.5 inches tall. I would say it would benefit any type of extra lift. I'm not sure how these would fit for stock suspension though. It was stated earlier the stock bumps are 1 inch tall, I threw mine away and didn't measure them, should of.
bump , front , rear , stop , stops
How much front bump stop clearance should there be? 08 v6 Seymore Butts 4th Gen T4Rs 8 10-09-2018 12:18 PM
Front Bump Stop Clearance jzeyer 4th Gen T4Rs 1 05-01-2016 08:43 AM
FS: '97 stick front coils & rear bump stop cones Charlene For Sale: Suspension/Wheels/Tires 1 12-01-2015 11:10 PM
Front Bump Stop Removal JMG73072 5th gen T4Rs 3 06-04-2015 11:36 AM
'Bump' at a stop? iLLWiLL General Discussions 11 04-12-2009 12:34 AM
