Old 09-25-2021, 01:17 AM #61
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
Originally Posted by Akkording View Post
Timbrens got too proud as well. I missed out on a rear used set for sale for $100. If I were to start over I would of gone with the oem GX rear bump stops ($100 a set) due to the square curvature for that positive contact point over the center of the axle. My rear Eibachs ($125 then) work but the round contact point only hits the front half of my axle. It might not even be that big of a deal after all, maybe it was designed that way. I would love to see pictures of the axle contact print on someone who upgraded to the taller stock GX bumps stops to confirm my rambling.
same..i would have went with the lexus option as well.
Old 11-13-2021, 02:07 PM #62
dakgildea dakgildea is offline
dakgildea will become famous soon enough
Originally Posted by mrblah View Post
me too...i still won't pay more than i have to if i know there are less expensive (aka. CHEAPER) alternatives out there.
These have served me well, and are still on my vehicle.
I wont buy durobumps either, even though they probably work well.
From a design/engineering aspect and quality of materials, timbrens and ES made more sense than the durobump design.
Any loss of up travel? They feel pretty firm
| IG: daks.4rnr | 2018 TRD Off Road Premium | Dobinsons 302/505 700/705 | Dobinsons UCA | Shrockworks Angled Sliders | RCI Skids | C4 LoPro | Prinsu 3/4 |
dakgildea is offline   Reply With QuoteReply With Quote
Old 11-13-2021, 07:07 PM #63
mrblah's Avatar
mrblah's Avatar
I haven't noticed any loss of travel, and i don't notice they are there when I hit them (unlike the stock ones).
Old 01-15-2024, 11:58 PM #64
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
This might be a tad too tall for the fronts but this new redesign should compress better. I remember speaking to Ryan(*James) from ES years back and they were in preproduction testing.
Someone test them out and report back.
Energy Suspension 9.9178G Jounce Bumper Kit – Energy Suspension
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 01-16-2024, 12:03 AM #65
ChildrenOfBodom's Avatar
ChildrenOfBodom ChildrenOfBodom is offline
Moderator
Real Name: James
ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light
Moderator
Real Name: James
This might be a tad tall for the fronts but this new design should compress better. I remember speaking to Ryan from ES years back and they were in preproduction testing.
Idk who Ryan is, but those are just the JL bumps with a universal part number, identical to the ones posted up above a while back.
IG: @jimharb | YouTube
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
ChildrenOfBodom is offline   Reply With QuoteReply With Quote
Old 01-16-2024, 12:07 AM #66
Akkording's Avatar
Akkording's Avatar
Should work up front right? Looks juicy! I think it was you!
Thanks for the correction James, it's been awhile
Old 01-16-2024, 12:10 AM #67
Akkording's Avatar
Akkording's Avatar
Ok it's part of this then
Originally Posted by ChildrenOfBodom View Post
I left Energy Suspension in January 2020, so I don't know the answer to that.
Before I left, we had rate tested the JL bumps and found that they're literally the perfect rate for 4Runners.
At this rate, I will bet that ES will just reuse the same bolt-in style JL bump as previously shown and then just include a couple of bolts and call it a 5th gen 4Runner set. In that case, I'd just buy the Jeep bump set and use my existing 4Runner hardware to mount them.
Jeep set includes 4, but only 2 will be usable, as the others are not meant to be bolted in.
Old 12-01-2024, 03:40 PM #68
saaddp saaddp is offline
saaddp is on a distinguished road
Hi guys!
A question about the energy suspension bump stops 8.9104 for the front
I want to put them on, but unsure what there fully compressed at max force height is? Do they compress taller or shorter then stock bump stops? I do some fast off-roading, I'm looking for a little more comfort but want to make sure the bump stops engage the full stop at the same height as stock.
TIA
saaddp is offline   Reply With QuoteReply With Quote
bump , front , rear , stop , stops
How much front bump stop clearance should there be? 08 v6 Seymore Butts 4th Gen T4Rs 8 10-09-2018 12:18 PM
Front Bump Stop Clearance jzeyer 4th Gen T4Rs 1 05-01-2016 08:43 AM
FS: '97 stick front coils & rear bump stop cones Charlene For Sale: Suspension/Wheels/Tires 1 12-01-2015 11:10 PM
Front Bump Stop Removal JMG73072 5th gen T4Rs 3 06-04-2015 11:36 AM
'Bump' at a stop? iLLWiLL General Discussions 11 04-12-2009 12:34 AM
