02-17-2019, 08:46 PM
#1
Member
Member
Energy Suspension 8.9104R rear bump stops in place of front bump stops
I kind of discovered these on accident while searching for other parts. So I rolled the dice and tried out Energy Suspension 8.9104R rear bump stops in place of my front bump stops. They worked well for me on a recent trip to Barnwell Mountain, it will bolt right on, all hardware fits. I know it says rear bump stops but that didn't prevent me from trying them up front.
Red:
https://www.amazon.com/gp/aw/d/B01E1...mob_b_pd_title
Black:
https://www.amazon.com/Energy-Suspen...eywords=8.9104
__________________
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
02-17-2019, 11:27 PM
#2
Member
Member
How was the overall size compared to the stocks?
__________________
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
02-17-2019, 11:28 PM
#3
Member
Member
What is a bump stop? I hear a bump-like sound when I go over some speed bumps and when I reach the bottom of a dip in the road. Would bump stops help that?
__________________
2022 SR5 Premium 4WD
02-17-2019, 11:35 PM
#4
Member
Member
Quote:
Much taller, they are 2.5 inches tall
The red pair are $22 shipped
The black pair, model 8.9104G, go for $28
__________________
02-19-2019, 06:24 AM
#5
Senior Member
Senior Member
alright you have my attention. I'll give these bad boys a try.
__________________
2016 trail 4runner, twin locked on 34's.
Can read more of my build here (2 parts):
https://www.lasfit.com/blogs/news/ho...ad-build-part1
02-19-2019, 04:44 PM
#6
Member
Member
Your shocks and LCAs will thank you.
I'm also doing more research for other potential candidates for the rear bump stops but that is not priority for me at the moment
__________________
02-19-2019, 04:53 PM
#7
Member
Member
Gotcha. So are they limiting your overall compressed travel compared to stock?
__________________
Paul
02-19-2019, 05:03 PM
#8
Member
Member
You can cut/trim them if needed. The material is much firmer than stock.
Energy makes great replacement bushings for the 4Runner.
8.9104R - Energy Suspension Bump Stop - Battle Born Offroad - The Offroad Part Source!
02-19-2019, 05:37 PM
#9
Member
Member
^ugh nice plug
I wouldn't recommend trimming anything, the other aftermarket manufactures options are all about the same height for a reason I'm sure and I have not seen or heard them mention trimming.
Your shocks will still compress, this prevents you from the hard bottoming out that happens with the shorter OEM rubber bump stops.
__________________
03-22-2019, 06:36 PM
#10
Senior Member
Senior Member
alright i installed mine today, and other than having to crawl under my vehicle, it was pretty straightforward to install.
Driving around, it seems to help. More squishiness over big bumps....less teeth rattling thumps.
I ordered from the amazon link posted by akkording, which seemed to be the best price, although it took a month to get to me. Luckily, I wasn't in any hurry to install these (hate crawling under my vehicle).
I got the red ones, cuz you know....its red.
Good buy
thanks mr. akkording for the recommendation of these.
__________________
03-22-2019, 07:41 PM
#11
Member
Member
How tall are the OEM ones? Did you have to jack your truck up to install?
03-22-2019, 08:04 PM
#12
Member
Member
Picture?
03-22-2019, 09:13 PM
#13
Member
Member
Quote:
Just ordered a set myself. I got them from Jegs.com. Paid a little more but they had them in stock. Wanted to make sure I had them on hand just incase I get an actual day off work to put my lift on.
__________________
Paul
03-22-2019, 11:15 PM
#14
Senior Member
Senior Member
Quote:
Originally Posted by yardsale
Picture?
your wish is my command. Excuse all the wd40 sprayed all over the place. I used it to soak the old bump stops to get em off easier.
__________________
03-22-2019, 11:17 PM
#15
Senior Member
Senior Member
Quote:
OEM is about 1 inch tall. I didn't have to jack mine up to take off old bump stops. I did have to jack my ride up to install these mainly because my allen wrench was too dang long and wouldn't clear the lower control arms. If you have the right size allen wrench I guess you wouldn't have to jack your car up.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
