Old 02-19-2019, 12:04 AM #16
looks perfect. the wheelers rear springs ride great too.
Old 02-19-2019, 09:51 AM #17
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
ah so you went with the 600 pound coils that are an inch longer 3x14 from 3x13
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 07:29 PM #18
speedyglx's Avatar
speedyglx speedyglx is offline
speedyglx will become famous soon enough
speedyglx's Avatar
That is correct. I used the coils from a Bilstein 6112 kit.
2017 Toyota 4runner TRD Pro
2012 Toyota Highlander
speedyglx is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 08:22 PM #19
jlaviano jlaviano is offline
jlaviano is on a distinguished road
Measurements
Hey nice setup, I’m going this route. Do you mind posting the measurements from ground to fender and hub to fender?
jlaviano is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 09:38 PM #20
speedyglx's Avatar
speedyglx's Avatar
I actually took some pictures of the measurements this morning from ground to fender. Dead even from front to back. I did not expect that.
Front pic
Rear pic
Old 02-20-2019, 03:42 PM #21
Bayou_Pro's Avatar
Bayou_Pro Bayou_Pro is offline
Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light
Bayou_Pro's Avatar
Any concern with down travel and topping out the factory shocks, front or rear, with this setup?
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
Bayou_Pro is offline   Reply With QuoteReply With Quote
Old 02-20-2019, 04:45 PM #22
mqphung's Avatar
mqphung mqphung is offline
mqphung is on a distinguished road
mqphung's Avatar
How much did you lift your rear? I'm looking to add a similar setup to my 4runner and wanted to compare.
mqphung is offline   Reply With QuoteReply With Quote
Old 02-20-2019, 05:44 PM #23
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
Originally Posted by speedyglx View Post
No clip setting. The shocks are from a TRD Pro. They have no clip settings like the 6112 shocks. The rears I kept stock. Same as the front, just replaced the coil.
I don't understand. You said you put 6112 on your TRD Pro which I assuming you took the OEM TRD Pro Bilsteins off. Were the 6112 not adjustable height?
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 02-20-2019, 05:54 PM #24
Bayou_Pro's Avatar
Bayou_Pro's Avatar
No he used the 6112 springs ONLY with the factory TRD shocks.
Paul
Old 02-20-2019, 05:58 PM #25
Akkording's Avatar
Akkording's Avatar
Old 02-20-2019, 06:09 PM #26
Tejas Tejas is offline
Tejas is a jewel in the rough Tejas is a jewel in the rough Tejas is a jewel in the rough
Did you use wheel spacers OP? If so, which ones?
Tejas is offline   Reply With QuoteReply With Quote
Old 02-20-2019, 09:01 PM #27
speedyglx's Avatar
speedyglx's Avatar
No because TRD Pros use the same shock as the shock from the Bilstein 6112 kit. Just no adjustments.
Wheeler T13 coil suppose to have a lift of 1.5 inches, I believe I got around 1.25 inches of lift.
Bayou_Pro and Akkording answered that question. Thank you.
Old 02-20-2019, 09:02 PM #28
speedyglx's Avatar
speedyglx's Avatar
No wheels spacer.
Old 02-20-2019, 10:22 PM #29
No wheels spacer.
Interesting, I am running 275's on my 2018 Pro with the stock Bilsteins and 1.5" top hat spacers and I don't think my wheels stick out anywhere near that much. I like the look.
Old 02-20-2019, 11:23 PM #30
speedyglx's Avatar
speedyglx's Avatar
I don't think they stick out that much. Here is another shot.
coils , lift , pro , swap , trd
Difference between TRD Pro front struts & Bilstein 6112? More inside... 57HotrodVW 5th gen T4Rs 1 09-03-2018 12:32 AM
6112 vs 5100 w/coils rocket67 5th gen T4Rs 2 05-05-2018 10:57 AM
Help Me Please.....Pics inside GX4SEVEND 3rd gen T4Rs 28 09-25-2010 08:39 PM
