Old 02-19-2019, 03:52 PM #16
ChrisJHarney ChrisJHarney is offline
ChrisJHarney will become famous soon enough
Originally Posted by Bonyfattony View Post
We are all missing that part. It is what holds the swing out in place. You can install the rear bumper without it. However I was told by Evan, former installer of Pelfreybilt, that it is easier to install the swing outs with the bumper off. He said before they closed, they ordered 100 of the pucks and should have it but it is a matter of finding them or producing them.
Absolutely correct. After doing it, I would have to say it would be damn near impossible to install the arms with the bumper on, I can’t even fathom how you would torque down the spindle bolts with the bumper on. Glad to hear they are going to machine new spindle supports, I would like another set when they do. They are aluminum pieces, and as strong as I rationally know aluminum is, there is just so much dynamic weight being asked to support from (4) bolts, it would just be nice to have a second set just in case, especially since they are custom built.
ChrisJHarney is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 03:59 PM #17
rlarroque rlarroque is offline
Real Name: Rico
rlarroque is on a distinguished road
Real Name: Rico
Yah for sure Lawndart mentioned that we should ask to see if he can make them out of steel for that reason.
I'm also missing the actual spindle unless it's already on the bumper. I haven't had a chance to unwrap anything. Which is why I'm looking for the guide to confirm what I have and don't have.
2017 4Runner TRD Off Road Premium Barcelona Red / FN Wheels Overlander black / Nitto Ridge Grapplers 285/70/17 / Baja Design Lights / Pelfreybilt Sliders w/ top plate, Gobi Stealth rack / ARB Snorkel / RCI Aluminum Skid Plates
rlarroque is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 04:13 PM #18
So the spindle is actually 4 separate pieces. The spindle bearing carrier is made up of two machined aluminum pieces that attach the swing arms to the bumper via 4 bolts each (what you are missing). These two pieces bolt together to form the complete spindle. Inside the spindle there are 2 tapered roller bearings that need to be greased and inserted into the inner swing arm pivot. Then there are 2 machined aluminum center spindle spacers that have O rings to essentially seal in the bearings that slide into the spindle housing before you bolt each one into the swing arm. I will send you a scanned copy of the instructions along with the parts lists I took pictures of before I opened all the bags.
I actually received a Tacoma latch instead of the 4Runner one which I’m hoping Jerry can swap out for me. I was also missing a machined Delrin slide piece for the latch and a license plate light kit. The latch I would consider the only priority.
Old 02-20-2019, 12:53 PM #19
NoOneBetter's Avatar
NoOneBetter NoOneBetter is offline
NoOneBetter will become famous soon enough
did you guys get the reinforcement support brackets? Dont remember seeing this in the set of parts I got but I also haven't unwrapped everything yet.
@rlarroque emailed you a scanned set of the instructions.
2015 Mag Grey TEP
Build Thread
IG - AFK_T4R
NoOneBetter is offline   Reply With QuoteReply With Quote
Old 02-20-2019, 01:34 PM #20
Real Name: Rico
Real Name: Rico
DM'd you on IG with an image of them. Evan handed them to me separately they weren't wrapped up in the bumper.
Old 02-20-2019, 08:53 PM #21
I got the supports, but the hardware was missing, just some bolts, nuts, washers, but it was highly recommended to me to get grade 9 and not the standard grade 5.
I ended up buying a shit ton of hardware due to where I went for the bolts (only sold in bulk), so Rico, if you only got the supports and not the bolts, and you end up picking up the rubber trim pieces for the bumper edges I’ll give you the grade 9 hardware too.
Old 03-29-2019, 03:21 PM #22
Bonyfattony's Avatar
Bonyfattony Bonyfattony is offline
Real Name: Tony
Bonyfattony is on a distinguished road
Real Name: Tony
Has anyone received their spindle supports?
Bonyfattony is offline   Reply With QuoteReply With Quote
Old 07-20-2020, 10:02 PM #23
Eeraera Eeraera is offline
Eeraera is on a distinguished road
Post Last one / instructions .......?
@rlarroque emailed you a scanned set of the instructions.[/QUOTE]
Hey @NoOneBetter , possible to get the Pelfrybilt rear bumper install instructions from you? I just picked up the last non-gated one..
Eeraera is offline   Reply With QuoteReply With Quote
Old 07-20-2020, 10:56 PM #24
erick619 erick619 is offline
erick619 is on a distinguished road
Pelfreybilt Installation Instructions | Tacoma World --- It's on post #2.
Anybody get their spindle supports for the swing outs?
erick619 is offline   Reply With QuoteReply With Quote
bamf , bumper , install , swing , walked
Pelfreybilt rear bumper, resurrection? arthurm 5th gen T4Rs 7 09-11-2018 08:59 AM
Install problem with Pelfreybilt HWM on 2013 Trail Fergie 5th gen T4Rs 7 06-27-2018 08:07 PM
Gauging interest in PELFREYBILT rear bumper/TC zopperman 4th Gen T4Rs 57 09-04-2017 09:30 PM
light bar install help!!on Pelfreybilt front bumper jepoySR5 Nor Cal 2 03-27-2016 01:30 AM
Rear bumper build and Front bumper install ADH8796 3rd gen T4Rs 25 03-09-2016 03:43 PM
