Old 02-19-2019, 01:16 PM #16
TCLLC TCLLC is offline
TCLLC will become famous soon enough
Originally Posted by nbtrdrunner View Post
Maybe I should just look into arc light leds Was it hard to remove ?
wont hurt to try. hell of a great product too. you will need to remove the overhead console, 10-15 minutes of work. instructions are well written too, as long as you follow the directions, very easy
TCLLC is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 03:28 PM #17
TPz_Fuchs TPz_Fuchs is offline
Real Name: Gus
TPz_Fuchs is on a distinguished road
Real Name: Gus
I changed my map light assembly to ArcLights. I may still have the reflector unit somewhere. Let me know if you need one. The ArcLights were easy-peasy to install, just follow the instructions and they work like a champ.
2016 T4R SE Premium, Baja Rack, Shrockworks Sliders, KO2's, Rigid SAE Fog Lights, Gobi Ladder, ArcLight Map & Hatch LED's, Blueridge Overland Attic.
TPz_Fuchs is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 04:44 PM #18
Speedsurfer Speedsurfer is offline
Speedsurfer is on a distinguished road
Agree put the old bulbs back and go to a different dealer and make a warranty claim. Worth a try
2003 V8 4WD Black Still Kicking
2018 TRD Pro Midnight Black Metallic
Speedsurfer is offline   Reply With QuoteReply With Quote
Old 02-20-2019, 02:41 AM #19
engeeoh01 engeeoh01 is offline
engeeoh01 is on a distinguished road
led map light disaster
I had my entire map light assembly replaced at about 19k. Passenger side went first, and then the driver side followed shortly. Lights didnít turn on when doors opened either. Dealer diagnosed it and ruled it to be the circuit board failure. They replaced it, no questions asked. The repair didnít take all day, which was nice. And yes, nbtrdrunner is right. This part is like $1250. Thank goodness for factory warranties.
engeeoh01 is offline   Reply With QuoteReply With Quote
Old 10-10-2021, 07:20 PM #20
AustenKorowski AustenKorowski is offline
AustenKorowski is on a distinguished road
I just wanted to add to this thread with my mistakes tonight. I bought one of the commonly purchased kits off Amazon.
1) Don't twist the bulb accidently. The bulb connector is just a quarter turn fitting into the housing. It popped up inside with the old light bulb still attached.
2) If this happens, don't remove the sheet metal reflector. Even though it looks like it's easy to remove it's too flimsy, you will damage it trying to get it back in, and possibly break the tiny tabs that hold the clear lenses in the process.
3) It's really easy to remove the entire map light console. Just two screws in the sunglass holder. Should have done that from the start when the bulb holder popped inside.
4) The back dome bulb flickered at first when I'd slam my door. Reviews said the bulb was too big, but they must have changed something because the bulb seemed too small almost. Had to pry the contract open a hair and put a new bulb in to get rid of the flicker. The LEDs are one sided and I didn't like that the loose bulb could freely spin around. Was worried it would eventually work it's way to shine upwards into the housing.
AustenKorowski is offline   Reply With QuoteReply With Quote
Old 10-27-2021, 01:39 AM #21
Cuatrorunner1 Cuatrorunner1 is offline
Cuatrorunner1 is on a distinguished road
Same problem!
Nice to know I'm not the only one! Haha... Kinda sucks. I replace the map lights with LEDs since the beginning of the year the passenger one started flickering so I would have to bang the light for it to become solid I decided to replace it but I think I did the same damage as you.. any luck on what it might be?
Thanks again 🤙
Cuatrorunner1 is offline   Reply With QuoteReply With Quote
Old 10-27-2021, 02:29 AM #22
mrblah mrblah is offline
mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future mrblah has a brilliant future
PSA: dont buy crappy bulbs. you don't have to buy expensive ones, but don't buy cheapo ones, so you don't have to deal with polarity issues or fitment issues.
I'm using a combination of lasfit bulbs and JDM stars (amazon) and never had any problems with polarity, flickering, color, longevity, etc.
2016 sr5 2x4 Mall rated edition:
Current peasant build: spacer lift 3 inches, lots of plastidip, sr5 wheels w/ 265s, lots of LED lights, and lots of sponsored brolanding stickers. faking it with the IG crowd since 2016. Lets go brandon..FJB!!!!
Old 10-27-2021, 06:55 AM #23
JPOVS's Avatar
JPOVS JPOVS is offline
JPOVS is on a distinguished road
JPOVS's Avatar
I had originally installed Fyre Flys LEDís. The passenger side flickered for years. Didnít bother me as I usually had it turned off. This summer I switched over to Arclight LEDís, so much nicer being able to switch to red.
I still have the reflector if your still in need of one?
Built by me, for me. No Instagram wanted!
2016 TEP, Elka 2.5 RR Adj F&R, Chaos UCA & LCA, OME 899, KO2 285/70E, Wheeler F&R Bumps, BMC, Nitro 4.88 Gearing, Hefty Fab F&R Bumpers Dual w/ ladder, Warn Plat 12s, Icon Pan & Billet Rear Links, GFC RTT, RCI Sliders, Every RCI Skid Plate (In Alum if avail), SCS Stealth 6 Rims, ARB Twin Comp, ARB 2500 Awn, Quick Pitch Shower Awn, Compustar T11 & RMS, Dual 42" drawers W/ Adj sleep/dog height platform (2nd Row Removed). Switch Pros, Baja LP9ís, S2 Pros A-Pillar and Rear Bumper, Rock Lights, Dometic CFX3 35qt, Transmission Cooler.
JPOVS is offline   Reply With QuoteReply With Quote
led , light , map , problem , replace
Oil Change Disaster, what did I do? Gen3mrd 3rd gen T4Rs 78 02-20-2018 06:18 PM
P0171 Disaster - Please Help! vr4playa 3rd gen T4Rs 25 06-06-2015 11:13 PM
Nightshade Disaster tamerunner 5th gen T4Rs 19 07-17-2014 04:26 PM
Installed UCA, almost Disaster JamesWhite 5th gen T4Rs 3 02-25-2013 06:42 PM
Disaster Preparedness DigableKid 5th gen T4Rs 9 03-20-2011 08:45 PM
