Old 02-19-2019, 02:14 AM #1
nbtrdrunner nbtrdrunner is offline
nbtrdrunner is on a distinguished road
led map light disaster
Hello I'm new to the forum and I'm looking for some insight on a led map light issue I'm having. I have a 2018 trd off road premium 4 runner . i replaced the map light and dome light with sylvania led bulbs . while doing the map lights i apparently accidentally bent the reflector plate behind it upwards and its hitting the chip board behind it causing the passenger side map light to flicker all the interior lights a few times before it goes solid. i took it to the dealership and they tried to tell me i have to replace the whole unit and they want to charge me 1800$!!! please if anyone has any info on this or if you ever had this problem give me some kind of helpful info so i don't spend 2k on fixing a small problem my brand new 4runner :rebuke: i can't imagine they would have to replace that whole thing. thank you
nbtrdrunner is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 08:09 AM #2
Cndnmax Cndnmax is offline
Cndnmax will become famous soon enough Cndnmax will become famous soon enough
Can’t you just bend it back? The flicker might actually be the LEDs. Depending on how they are made, some do not like the gradual on/off. Although, this usually isn’t a problem with DC setups but you never know. I would suggest you start by putting the old bulbs in and seeing if he problem is still there.
Cndnmax is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 09:28 AM #3
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Take the reflector out and see if it still flickers. then you will know for sure if that is the issue. If you can't bend it back into shape, maybe some silicon or electrical tape over the offending area will insulate from the board.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 10:04 AM #4
Yes I tried putting stock bulbs in and it still does it
Old 02-19-2019, 10:07 AM #5
That’s reflector is so flimsy I’m afraid if I get it out it will never go back in.. I tried bending it back down too and I thought I did a good job because it’s really hard to tell
Where it’s even bent . That’s why im thinking that’s just what the dealership is saying it is but maybe it’s something else
Old 02-19-2019, 10:17 AM #6
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
$1800 for an overhead console?
Old 02-19-2019, 10:22 AM #7
sntryplt's Avatar
sntryplt sntryplt is offline
Real Name: Dave
sntryplt is on a distinguished road
sntryplt's Avatar
Real Name: Dave
I'd do a little more investigation--the lamp assembly total is less than $200. He's quoting a total overhead console replacement. Does it still flicker if you take that bulb out completely (using just the other side?) and try it? I'm skeptical of what the dealer is telling you. Cheaper LEDs tend to flicker in our sockets (I've proven that on mine). If you can't bend the reflector back, then I'd probably find (search the forum) instructions to pull the overhead console, and bend the reflector away from the board or replace that particular unit. It will be easier on a bench rather than overhead.
2019 GX460, Nebula Pearl. 2014 LE, Mag Gray (sold).
Stable mates: 2020 Subi Ascent Limited, 2021 TRD O/R Premium Black
sntryplt is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 10:50 AM #8
TCLLC TCLLC is offline
TCLLC will become famous soon enough
ask someone who replaced their lights with Arclight led's. you need to remove that plate (I did but have no idea where I put it).
or try a junk yard, heck of a lot cheaper than 1800!
TCLLC is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 10:53 AM #9
[QUOTE=sntryplt;3234886]I'd do a little more investigation--the lamp assembly total is less than $200. He's quoting a total overhead console replacement. Does it still flicker if you take that bulb out completely (using just the other side?) and try it? I'm skeptical of what the dealer is telling you. Cheaper LEDs tend to flicker in our sockets (I've proven that on mine). If you can't bend the reflector back, then I'd probably find (search the forum) instructions to pull the overhead console, and bend the reflector away from the board or replace that particular unit. It will be easier on a bench rather than overhead
I used sylania leds ...I’m not sure if they fall under the cheaper category or not but yeah I’ve been searching everywhere trying to find the reflector part sold separately and came up with nothing . I did find a thread on taking the whole console down and that may be the route I’ll go to further investigate . And for the question of the flickering ... it only flickers when the button is pushed
Old 02-19-2019, 10:54 AM #10
Maybe I should just look into arc light leds Was it hard to remove ?
Old 02-19-2019, 11:23 AM #11
Bayou_Pro's Avatar
Bayou_Pro Bayou_Pro is offline
Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light
Bayou_Pro's Avatar
You are not going to find the reflector plate by itself as it only comes with the console. Your only chance of that would be a junk yard console or a member that has removed thiers.
Is your 4runner still under warranty? If so put all of the factory bulbs back in and take it to another dealer. Might be worth a shot. Good luck.
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
Bayou_Pro is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 11:24 AM #12
rayofsi's Avatar
rayofsi rayofsi is offline
rayofsi is a jewel in the rough rayofsi is a jewel in the rough rayofsi is a jewel in the rough
rayofsi's Avatar
10 minutes, or less.
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
Old 02-19-2019, 11:33 AM #13
I screwed that up already lol I changed all dome lights and map but left the puddle lights led and they saw it
Old 02-19-2019, 11:51 AM #14
Bayou_Pro's Avatar
Bayou_Pro's Avatar
Well damn. Did that record that on your invoice? If so it'll go into TIS where other dealers can see it. led map light disaster
Paul
Old 02-19-2019, 12:53 PM #15
LOLSNOW LOLSNOW is offline
LOLSNOW will become famous soon enough LOLSNOW will become famous soon enough
Can you remove the lenses and give the map light console a good whiff? If it smells like burnt electronics then that's the reason why toyota wants you to replace the console.
You can also remove the map light console to inspect the board. PM me your email and I'll send you my guide that will walk you through the removal.
LOLSNOW is offline   Reply With QuoteReply With Quote
led , light , map , problem , replace
Oil Change Disaster, what did I do? Gen3mrd 3rd gen T4Rs 78 02-20-2018 06:18 PM
P0171 Disaster - Please Help! vr4playa 3rd gen T4Rs 25 06-06-2015 11:13 PM
Nightshade Disaster tamerunner 5th gen T4Rs 19 07-17-2014 04:26 PM
Installed UCA, almost Disaster JamesWhite 5th gen T4Rs 3 02-25-2013 06:42 PM
Disaster Preparedness DigableKid 5th gen T4Rs 9 03-20-2011 08:45 PM
