02-21-2019, 02:31 PM
Replacing oil filter housing
I broke the plastic oil filter housing when doing oil change last weekend. I put it back on without leaking and added new oil in. Now I've ordered the new metal housing and want to replace the broken plastic one. Just wondering do I have to drain all the 6.6 qt oil out to replace it or there is a better way to do it?
02-21-2019, 03:03 PM
You could use an oil extractor to suck oil out the dipstick tube, keep it clean that way, and reuse it. When you open that oil filter housing, the oil is going to come out otherwise.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
02-21-2019, 03:05 PM
No need to drain all of the oil. You can put a drain pan under the filter and just remove the filter housing. You will lose only the amount of oil in the housing which is messy but is actually very little oil.
02-21-2019, 03:07 PM
Real Name: Ben
Real Name: Ben
Dumbest design ever. I wish this thing had a spin on filter so badly. An oil change on other vehicles I have take 15 mins but this thing...
It's not so much the time it's just unnecessary
2019 SR5 MAGNETIC GRAY METALLIC
02-21-2019, 03:11 PM
Replace the housing and check the level. You may need to add 1/4 to 1/2 quart.
I have a Jowett housing coming in today so I can avoid this.
02-21-2019, 03:21 PM
I would just remove the skid plate, pull the filter housing off completely with the filter tool and have an empty drain pan underneath to catch what comes out, pour everything out of the filter into the drain pan too. Then swap the center stem part and filter over to your new metal housing, swap o rings (since you just put them in it should be fine), and tighten up. Measure what came out by pouring into an old oil quart jug, and add that amount back in. It may waste a quart or less, but not 6.6 quarts of brand new oil.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
02-21-2019, 03:47 PM
Thanks for this tip, I didn't know. I broke mine about two weeks ago as well. Probably put that oil tool on wrong in one spot, or it was just that tight from Toyota, I have no idea. I bought a Dorman housing for $30 at AutoZone. Had a small leak on one spot. Wondered if I should return it and hesitated on draining new oil. I haven't seen any leak since that day so no worries. $15 at RockAuto if you can wait though.
YouTube
02-21-2019, 04:29 PM
Good to know I can save some fresh oil. Thanks!
02-21-2019, 05:21 PM
I used to feel the same way. But after changing to a RCI skidplate, and getting the proper filter housing socket/tool, it only takes a few more minutes than a spin-on. While I'm under the vehicle, I grease the driveshaft U-joints also.
2010 4R SR5, "best 4 wheel vehicle that I've ever owned" TRADED !
2019 4R TRD Off Road
02-21-2019, 06:47 PM
Banned
Real Name: Tobias Fünke
Banned
Not really sure if you have to drain everything or not. I cannot remember my first change well as I'm about to hit 10K. That being said I think you can drain the filter alone without draining the entire system.
More to the point while you are in there replace that plastic shit with the metal version from the highlander. Easy swap and you will avoid this going forward. I swapped mine during my first service.
02-21-2019, 07:42 PM
If you don't have a leak now, just wait until your next oil change and swap the housings then.
02-21-2019, 07:47 PM
Banned
Banned
That's asking for trouble.
02-21-2019, 08:55 PM
My old e46 3 series had a cartridge filter on top so oil changes were really easy and fast. I think the cartridge filter is better performance and more environmentally friendly, in general, vs the spin on. But the 4Runner design with the cartridge on the bottom makes the process “interesting.”
02-22-2019, 08:21 PM
thats why I ordered this adapter specifically for the 4runner to convert it to a spin on oil filter. No more issues
Cartridge to Spin-On Adapter
2018 TRD Premium, KING suspension, 285/70/17 Duratracs, 4.88 gears, Addicted offroad front Bumper, C4 FAB rear bumper, My build thread https://www.toyota-4runner.org/5th-g...ld-thread.html
02-23-2019, 12:51 AM
Real Name: Derrick
Real Name: Derrick
Get yourself a remote oil filter housing. I love mine! Oil changes are a breeze! I don't have to take off any skid plates, super simple oil changes:
2015 Toyota 4Runner Trail Edition
Havik's Build Thread
