02-22-2019, 01:31 AM
Considering putting 2019 TRD Pro Fox 2.5 suspension on a 2015 SR5
As the price of a set of 2019 TRD Pro suspension is similar pricing to a comparable set of Fox 2.5..... I am considering putting that onto a 2015 SR5
Now, what rear spring should I use?
Any info on what rear spring a 2019 TRD Pro comes with? (Are they just STOCK?)
So, the new TRD Pro don't have much "lift" as it come stock? Can it be adjusted?
2015 SR5 Premium 4x4 / 3rd row seat
Jicko's Build & Adventure Thread
"Group buy, anyone?"
02-22-2019, 07:22 AM
The Pros rear spring is stock. Eibach,Bilstein and Dobinsons all make rear springs in the 1” range but you’re still going to have more rake than you do now because the trd Fox is lifting only .85” to 1” max in the front
2022 Limited 4x4 Silver
2017 TRD Offroad. Barcelona Red, 265 BFG KO2, Eibach Pro-truck 1.6/1, Shrockworks sliders-TRADED
02-22-2019, 01:22 PM
As already mentioned the rear TRD Pro spring are the same. You are only going to get about .8" of lift with the Pro front coilovers do you probably wouldn't want to add back lift springs with just that. They are not adjustable. You could get the Toytec 1 or 2" spacers and add to the Pro kit to get more lift. At that point depending on what kind of price you are getting on them you might want to look into the Bilstein 6112 kit that would be adjustable. Good luck.
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
08-07-2019, 02:46 AM
TRD Fox Compatibility
I tried to buy a used pair of the TRD Fox Shocks from someone who purchased them from a dealer who stripped them off a pro at the Factory to lift it.
They told me that they are not compatible with the TRD Off Road with KDSS because “KDSS has trac control sensors that cannot be disconnected.“
I was confused by this as the Bilstein pro suspension is compatible.
Is this true? Is this something that Toyota is telling people?
08-07-2019, 09:42 AM
They guy had the suspension removed at the factory? In Japan?
That's news to me.
_____________________
2018 Super White SR5 Premium aka Ben Affleck: Procharged (D1SC), Bilstein 5100s w/ 2" Toytech Superflex, 285/70/18 duratracs (E), 18x9 Volk TE37, OEM Audio+ Ref500, RA Motorsports rack, TRD hood + skid // 2003 Black Limited (2UZFE) aka Blacky Chan: Bilstein 5100 w/ Icon 2.5" springs, BMC, air bag delete, 17x9 SCS Ray10, 285/70/18 Yokos
08-07-2019, 10:06 AM
yeah, that's BS.
Sounds like something that one person is telling people, that is garbage.
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
08-07-2019, 10:43 AM
That's news to me.
With the exception of the paint color, the "TRD Pro" trim is an option package added at the port.
2014 Classic Silver TE w/ KDSS - The Waco Kid's Build and Adventure Thread
Wife's Ride: 2017 RX 350
Past Vehicle:2001 Dodge Dakota Sport 4.7L V8 Quad Cab.
08-07-2019, 10:52 AM
Isn't the whole point of the TRD Fox suspension that it is an internal bypass suspension? Isn't it position sensitive? If so, shouldn't it be run with no lift? It is not a normal shock that would just sit a bit off with a 1" taller spring in the rear.
One way to verify is to search whether any such shocks are offered with a range for lift (like 1-3 or 0-1.5 for regular shocks) or with just a fixed lift.
08-07-2019, 11:08 AM
Yes. Lifting will result in different dampening behavior. Especially the rear that has something like 7 zones of dampening. So being an inch or two taller would mean that you're in a different dampening zone than it was designed for. I have no idea how much difference there is though. It might be the case that it really only ramps up the dampening right at the very end and anywhere in the middle works fine.
In the front I'd think a spacer lift on top of the shock would be the best option so the shock remains in the right base position.
08-07-2019, 04:17 PM
Shut the front door. I did not know that.
08-07-2019, 05:57 PM
Not to derail the conversation, but every TRD goodie on the truck is a port add-on. Toyota USA specifies a few mechanical features (sunroof, ac [now that they're all going dual zone]) and color ranges, then adds on the rack, shocks, and other TRD goodies at the port.
Which kinda makes getting a TRD pro in any other color than the special color kinda silly, (especially with the early offerings) if you paid MSRP or more for it. They may be slightly more differentiated from the factory for 2020 (like if Dual Zone AC and a few other major features aren't also on the TRD offroad Premium trim), but we won't know completely until they're out.
If you go back and read some of the TRD Pro threads from the early years, all the "hate" for people paying over MSRP for it will make a little more sense.
08-07-2019, 06:25 PM
Interesting becacue I work by port and I see Pros in the Toyota lot I doubt they are prepped to go to the dealers. They still has the protective plastic all over the outside.
I'll see if I can see any again when I drive by.
2018 TRD OFF ROAD
My Build
08-07-2019, 08:57 PM
Makes sense.
Wonder what they do with all the steel wheels after.
2018 TRD OFF ROAD
My Build
08-07-2019, 10:08 PM
Originally Posted by Dillusion
Makes sense.
They are turned around on another boat back.
1973 Datsun 240z (traded in for ---->) 1981 Toyota 4x4 Deluxe LB (avatar) stolen while sitting with For Sale sign on it / 1987 Chevrolet Suburban 4x4, workhorse - sold / 1984 Buick Grand National - Totaled, rear-ended / 1986 Buick Grand National - Sold then restified, lives in SF now / 1994 Toyota Camry - 240k - Taken to Austin Tx by son, traded in on VW GTI sport / 2001 Ford Excursion 7.3 212k - still pulling Arctic Fox Trailer - This is the shtf vehicle / 2018 Toyota 4runner TRD Pro Cavalry Blue
