03-04-2019, 05:13 PM
#16
Real Name: Shelbie
Real Name: Shelbie
-10mm offset and 4.30" bs on 285/70/17
2014 MGM SR5 | Dobinsons | Toytec Superflex | Bilstein 5100s | SPC UCAs | 295/70/17 Cooper STT Pros | StealthCustomSeries SR8s | Frontrunner Slimline rack | Gobi ladder | Baja Designs fogs
03-04-2019, 05:50 PM
#17
My SCS wheels with -10 offset and 4.30 backspace are even with the top of the fender. The sides of the lower fenders are slightly in compared to the tire so it all depends on what you call "even". I like this look, but as others have said it will require some light trimming or BMC depending on which UCA's you have and how it is aligned. I had to remove my mudflaps and do some minor trimming on the front bumper and fender liner mod but no BMC.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
03-04-2019, 06:52 PM
#18
The pictures make 0 and -10 look about the same. On my Tacoma, the sidewall was even with the top of the fender flare.
2019 T4R ORP
03-04-2019, 07:52 PM
#19
So who got some wheels with -10 offset and 4.1 BS?
My (terrible) math had them sticking out a shit load. Now this thread got me more confused.
2018 TRD OFF ROAD
My Build
03-05-2019, 11:14 AM
#20
FX Pro 17x8 wheels with 4.5" backspacing and 0mm offset fit just inside the fenders with Falken Wildpeak A/T3. This wheel is specific fit for 4th and 5th gen 4runners for larger tires and no spacers. The tire design can also impact this some as a tire with a lot of side lugs/features can stick out more at the sidewall and still be a 285 tire.
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
03-05-2019, 01:03 PM
#21
If you mean -10 with 4.3 inch backspace it is everyone with SCS wheels. I haven't found a wheel with -10 4.1. Shouldn't make much of a difference anyway.
03-05-2019, 01:15 PM
#22
Anyone running the new 17x9 from SCS pics pls. Rubbing issues??
03-05-2019, 03:21 PM
#23
If you're talking about the 17x9 -38 3.5BS, there is no way those will fit without modification. If you're looking at putting those on you should probably be prepared for bumper trimming, fender liner mod, mud flap removal and bmc. But damn they look so good
2016 4Runner
Aesthetic: Prinsu + JOE SLAPS, C4 Ladder, Shrockworks Sliders, Rago MSP + Shelf
Suspension: King 2.5 650lb w/ Adjusters, Dobinsons C59-327
Wheels: SCS Ray10 17x9 -38, 35x12.50r17 Yokohama Geolander M/T
Other: Custom Detours of Main Spare Tire Carrier, Freespirit Odyssey 49"
03-05-2019, 04:32 PM
#24
I have FN Wheel Counterstter Type X sitting in my garage.
Just waiting on the lift.
2018 TRD OFF ROAD
My Build
03-05-2019, 04:47 PM
#25
F5's have had the 17x9 -38s for a while so you should be able to ask someone who has them. Should be the exact same with the new Ray10s.
03-05-2019, 09:15 PM
#26
I have almost the same specs but with -10 offset Level 8 MK6. To me with the 285 Wildpeak I notice tire wall poke past the fenders.
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
03-05-2019, 11:24 PM
#27
Not only does flush depend on what tire brand you choose and what offset rims you decide to run, your eyes may play tricks on you, depending on how you view a vehicle from straight ahead or from the rear or from the sides.
FLUSH
https://www.toyota-4runner.org/attac...285s-flush-jpg
POKE:
https://www.toyota-4runner.org/attac...-not-flush-jpg
Rims spec: f5 17x8.5 -12 offset w/ 1.25 spacers, which puts my offset close to -40.
IMHO: 0 offset is flush with the fender (depending on tire), but not when viewed from different angles.
-12 offset gives you a little bit of pokage (depending on tire) and look flush from most angles.
-38 gives you about 1 and 1/2 inches of pokage (depending on tire), and will also look poked out when viewed from most angles (except when I take a photo of my rig from the front or rear).
03-06-2019, 01:05 AM
#28
With 285 on 8" wide -10 offset your tire tread will be sitting directly under the fender. The tire wall poke will be exposed beyond the fender.
I recommend you maxing out your caster above 4.0 with after market ucas to prevent body mount contact on reverse full locked decline driveways turns. You might hear a slight front fender liner rub but that can be remedied. Freeway driving would feel solid as well.
Yes tire models like bfg k02 will have a skinnier profile but you get the idea. I believe it's more accurate to judge the poke from the rear with the assistance of the the body lines but yes our eyes do play tricks on us.
My buddy has the f5 -38 and he required a bmc on 285 70 17 C nitto ridge grapplers. Caster set to D: 4.2 P: 4.4
03-06-2019, 01:54 AM
#29
Originally Posted by TheMagicMan5280
I have 17x8.5 0 offset with spacers and still feel like the fronts sit too flush. Will be switching to -38mm F5's soon.
I know to each their own, but I think your set up looks perfect.
2016 Nautical Blue T4R TEP w/KDSS, Oil Filter canister upgrade, Eibach Pro Truck lift 2.75/1.0, JBA UCAs, XD Machete 17X9 Wheels, Falken Wildpeak 275/70/17.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
