Originally Posted by MAST4R
My RCI skid dropped my front skid clearance from 9.6 to 8.75.
I can offer another data point. I have just installed a full set of RCI skid plates on my 2016 Trail with KDSS. The lowest point are the bolts that connect the front skid plate to the transmission skid plate. At that point, I measured the ground clearance to be 17.2 cm.
One must be grateful in life. That 17.2 cm is a wonderful improvement over my other vehicle, a Volvo V70, which has a mere 10.1 cm ground clearance at its lowest point.
A note on the RCI skid plates: They added less weight to my vehicle than thought. Engine, transmission, transfer case, fuel tank, rear differential, lower control arms, lower links weighed about 50 kg on my bathroom scales, which is less than the theoretical weight gain given on the RCI site. The removed factory skids and hardware weighed over 10kg. Thus the net weight added to my underside of my vehicle is under 40 kg.
Together with my LFD roof rack (20-22 kg) and console safe (4kg), my vehicle is 65 kg heavier than stock. The after-market kill switch, and electronic front parking-aid that I added, doesn't count for weight. The only planned other mod is to direct the exhaust to the side, so that it does not continuously blow hot gases towards my hitch basket. When my stock tires wear out, I'll replace them with the Toyo M55, which have the best puncture resistance.
