02-27-2019, 04:24 PM
TRD's w/ KDSS - Lower Ground Clearance???
Is this true, compared to others w/o KDSS?
02-27-2019, 05:22 PM
Yes. TRD Pro 9.5 inches, TRD OR w/o KDSS 8.5 inches, TRD OR with KDSS 8.0 inches.
The vehicle doesn't actually sit lower than a non-KDSS OR, but the front skid has to drop down an inch to avoid the KDSS.
I installed a 3 inch lift on my KDSS and got 4" of lift so now I sit at 12".
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
02-27-2019, 06:05 PM
Need to go measure at the dealer side by side.
TRD Pro skid fits on KDSS model. So no question that same ride height = same clearance as TRD Pro.
KDSS area is not the lowest point on the front skid plate.
So... unless KDSS models have shorter front springs... they should be about the same as other models. Springs have changed numerous times throughout the 5th gen production model years. I do not know what changed between years. Earlier KDSS models had different springs left/right and different shocks from the non KDSS. I think now they are the same left/right and same shocks as non KDSS. So it may be year specific.
This is a KDSS skid plate. Where would you say is the lowest point?
Do you think that point is lower or higher than this non-KDSS skid?
02-27-2019, 06:07 PM
Banned
Real Name: Tobias Fünke
Banned
Be interesting to read where those numbers are from.
This is false. It only appears lower because the skid plate the non kdss skid covers less going toward the front of the vehicle.
Have a look see yourself.
02-27-2019, 06:19 PM
The only number I’ve ever seen in Toyota’s documentation is 9.6”. I believe that’s every 5th Gen 4Runner, but maybe they state that KDSS is lower somewhere. I think the rear diff is the low point.
02-27-2019, 06:30 PM
2019 Toyota 4Runner Strengthens Legacy in 35th Year | Toyota
"All four-wheel-drive models offer a generous 9.6 inches of ground clearance. All 4Runner models come with a full-size spare tire."
2023 TRD ORP w/KDSS. Red again.
This is a big step up from the 1986 Subaru GL wagon I used on the Outer Banks beaches for 14 years. That thing would go anywhere in the sand on 185/70-13 tires. Dual range 5 speed, factory skid plate, 3 position manually adjustable rear shocks and armored exhaust. All factory, including the white spoke wheels. The front sub frame finally rusted apart.
02-27-2019, 07:01 PM
x2 on that!
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: [URL=https://www.toyota-4runner.org/2938235-post744.html[/URL] thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
02-27-2019, 08:09 PM
Here we go again.
Trd and Sr5 have about an inch more clearance than the kdss TRD under the front skid where it curves upwards.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
02-27-2019, 08:28 PM
Originally Posted by MAST4R
Here we go again.
I'm sure you're correct regarding ground clearance measured at the skid - gotta assume you are since I have no first-hand experience. I think the 9.6" of ground clearance Toyota claims is measured from the lowest point on the vehicle. I don't believe the skid plate is the lowest point on a 4Runner, but I may be wrong. I think it's the rear diff.
02-27-2019, 08:43 PM
Honestly,
@ Jetboy
's insistence made me doubt my own measurements from last fall, but the nearby dealer had no KDSS vehicles right now on my way back!
I am pretty sure, like you, that Toyota does not measure ground clearance at the skid plate but rather at the rear diff both because it is 9.6 there and because the lowest I have measured on brand new SR5 and my brand new TRD non-kdss was 9.2 at the skid plate under the oil pan.
There was a thread by a guy in, I think, Denver who posted about being very disappointed at measuring 1" less than advertised after delivery of a KDSS 4R but I cannot find it.
EDIT: found it, confirmed, 8.6 vs 9.6 exactly as I measured it last spring.
Nowhere near the advertised ground clearance
02-27-2019, 08:55 PM
Honestly,
@ Jetboy
Gotcha. Thanks for looking up the info. I don't have KDSS, and I won't be wheeling in the near future, but good to know for future discussions. And other guys on here may appreciate knowing. Probably other automakers make similar measurements.
Front skid extends further but not lower. Still hit front valance first for approach. This is with RCI aluminum skids.
I have no idea how you got your numbers. KDSS bar sits higher off the ground than many other bits.
And it improves articulation and road manners by a lot.
02-28-2019, 01:52 AM
Real Name: Ted
Real Name: Ted
My 2015 KDSS Trail had 9.00” minimum clearance at the skid. I put in a 2” lift and got clearance at the skid plus some.
2015 TE w/KDSS. BFG KO2 LT275 summer tires/Michelin LTX Winter tires; RCI Al skid set; OPOR sliders; Rr diff breather mod.; FJToyMan Rr Shock Skids; MetalTech Rr Lower Link Skids. Lift: Bilstein 6112 front 2" lift (3rd clip) and rear Bilstein 5100's with 2" Icon lift springs.
02-28-2019, 02:09 AM
F A L S E.
My 2018 TRD OR with KDSS had 9.25" clearance at the LOWEST point on the skid, which is significantly lower than most of the skid. Easy 9.5"+ everywhere else.
02-28-2019, 11:38 AM
I measured mine last night. 8.7" at the lowest point on the skid, which was below the KDSS piston on the driver side of the vehicle.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
