Old 04-26-2020, 04:37 PM #106
JJRus237's Avatar
JJRus237 JJRus237 is offline
JJRus237 has a spectacular aura about JJRus237 has a spectacular aura about
JJRus237's Avatar
Busted a shock mount in Lucerne this weekend. I’ll post some pictures of how I plan on upgrading it later in the week. I’m thinking thru bolting and possibly double shearing it. Along with moving my bumps down.
JJRus237 is offline   Reply With QuoteReply With Quote
Old 04-26-2020, 04:40 PM #107
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Originally Posted by JJRus237 View Post
He now has the TRD beadlocks. Still no rub or chopping.
Crazy! I guess +15 offset is the key! Now only if the spare space was bigger
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 04-26-2020, 06:19 PM #108
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
I sealed up most of the cab drains when I did the sound deadening. I’m sure that’s why.
There are unsealed cab drain holes?
I did see unsealed holes for the wiring attachment clips under the door molding, figured I would silicone them at some point.
delloro is offline   Reply With QuoteReply With Quote
Old 04-26-2020, 09:56 PM #109
JJRus237's Avatar
JJRus237's Avatar
There are random holes for cab drains that do have plugs, but when I had the carpet up I ran a bead of silicone around them for good measure. So I guess to answer your question they are “sealed” from the factory but I don’t really know how sealed that plug would be when going that deep.
Old 04-26-2020, 10:40 PM #110
delloro's Avatar
delloro's Avatar
Gotcha, thanks
Old 04-27-2020, 12:26 AM #111
MrSeth's Avatar
MrSeth MrSeth is offline
Real Name: Seth
MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough
MrSeth's Avatar
Real Name: Seth
I did the same thing in Moab. The drill through and mount with a bolt option does work and did work for me for awhile, but then I switched over to using a TeraFlex lower shock bar pin eliminator kit for an XJ. I was able to move the lowest part of the shock up about 1.5" and haven't had any issues. I welded it on the flat part above where the original lower shock mounted- lots of room. The two bolt holes on the mount area serve as rossette weld points, and then perimeter weld.
Just another option that has served me well.
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
MrSeth is offline   Reply With QuoteReply With Quote
Old 04-27-2020, 10:10 AM #112
doesnt that mean you lose 1.5" of bump travel?
Old 04-27-2020, 10:16 AM #113
dom42 dom42 is offline
dom42 is a glorious beacon of light dom42 is a glorious beacon of light dom42 is a glorious beacon of light dom42 is a glorious beacon of light dom42 is a glorious beacon of light
It’s actually +6mm offset. I have the same wheels. They are perfect for the 4Runner.
dom42 is offline   Reply With QuoteReply With Quote
Old 04-27-2020, 11:39 AM #114
sleepsontoilet sleepsontoilet is offline
sleepsontoilet will become famous soon enough
Have any good pics?
sleepsontoilet is offline   Reply With QuoteReply With Quote
Old 04-30-2020, 06:09 PM #115
MrSeth's Avatar
Real Name: Seth
MrSeth's Avatar
Real Name: Seth
Originally Posted by sleepsontoilet View Post
Have any good pics?
Just took this one.
Old 05-19-2020, 12:11 AM #116
JJRus237's Avatar
JJRus237's Avatar
All fixed. Pretty happy with the turnout.
Old 05-19-2020, 12:42 AM #117
That looks good!
Old 07-14-2020, 09:54 AM #118
dirtqueen2 dirtqueen2 is offline
dirtqueen2 is on a distinguished road
Kellan Meadows at Envy Motorsports (@dirtdreamer on Instagram)
To whom it may concern. BE careful with this guy.
He scammed me out of 2442.00 on shocks that were never sent.
He scammed 6 others out of rims, racing seats, and shocks.
we are all going after him in the state of CA to hopefully put an end to this guy and hopefully protect anyone else he scams.
so far the total from people is above 20,000 plus more that just gave up trying to contact him since he moved. The federal trade commission is still trying to find him since it was online fraud and I am not stopping until some kind of justice is done.
his name :Kellan Meadows at Envy Motorsports (@dirtdreamer on Instagram
Kellan if you see this we are lawyered up brother.
dirtqueen2 is offline   Reply With QuoteReply With Quote
Old 07-14-2020, 02:41 PM #119
Dang. I know of that guy too. Always was weird to me. Hope you get it back.
Old 07-14-2020, 03:09 PM #120
Little confused here, is this person a member here?
4runner , build , front , rear , truck
Sniv's Custom Long Travel Build snivilous 3rd gen T4Rs 804 07-06-2021 10:22 AM
Cheapest Long IFS long travel Kits? Cap. Morgan General Discussions 19 05-05-2020 02:28 AM
89.5 4runner. Motor swap and Long travel build (Help needed) toyotaman1992 Classic T4Rs 3 07-05-2018 01:30 AM
Cartzo's 87 4Runner Homemade Long-Travel Build Cartzo Classic T4Rs 266 05-10-2018 08:28 PM
Dirt King Long Travel System, 14" Travel - +3.5" Wider - Under 2700 Delivered!! TotalAutomotiveLV Total Automotive Performance 13 07-04-2017 02:32 PM
