Old 02-28-2019, 07:44 PM #1
ben550's Avatar
ben550 ben550 is offline
ben550 is on a distinguished road
ben550's Avatar
Check Engine Light P0015
Check engine light came on today driving home. 4LO light started blinking and VSC light came on solid with check engine light.
Drove home and plugged in OBD reader.
P0015 $07E8 Generic
B Camshaft Position Timing
Over-Retarded Bank 1
came up...
2010 with 137,000 miles. Any ideas what this might be? I read a little about it but don't see many people talking about this with 4Runners. I reset the code and will drive it tomorrow to see if the code comes back up.
6,600 miles on current oil. I change the oil with Toyota filter ever 7000 miles using 0w-20 Valvoline High Mileage Synthetic Oil.
Want some ideas before I bring it to a mechanic.
Check Engine Light P0015-img_2480-jpg
'01 SR5 3.4 V6 4WD
'04 SR5 4.0 V6 2WD
'07 Tacoma 4.0 V6 4WD
'06 Sport 4.7 V8 4WD
'10 Limited 4.0 V6 4WD
ben550 is offline   Reply With QuoteReply With Quote
Old 02-28-2019, 08:09 PM #2
kso818 kso818 is offline
kso818 is on a distinguished road
I totally don't know anything on this. But after a bit of reading....
P0015: "B" Camshaft Position - Timing Over-Retarded (Bank 1)
IG: ksotrdpro
2015 Inferno Red TRD Pro | Piaa Platinum LED Headlights | Shrockworks Dual Battery Relocator | National Luna Dual Battery Kit | Optima Yellow Top | SPOD SE | ARB Air Compressor | Rago MSP | Expedition Essentials T4RPAM | C4 Fab Rock Sliders | C4 Fab Dual Swing Rear Bumper | Frontrunner Slimline II Rack | KC C-Series Lightbar | Cooper Discoverer STT Pro 285/70/17 | Dobinson C59-701V | Fox 2.5 Shocks with Remote Resi and DSC | ProComp 2.25" Front Spacer
kso818 is offline   Reply With QuoteReply With Quote
Old 02-28-2019, 09:58 PM #3
ben550's Avatar
ben550's Avatar
I am going to change the variable valve timing (VVT) solenoid/actuator for the Bank 1 side of the engine (Left side when standing in front of the truck looking at the engine). Hopefully this will keep the check engine light from coming back on. I work down the street from a Toyota dealer so ill stop by the parts shop and hope they have one in stock.
looks like its only a 10mm bolt holding it on and a not-so-quick disconnect electrical harness.
Part# 153300S010 More Information for GATES VVS130
I will also change the motor oil. Don't have time until the weekend.
'01 SR5 3.4 V6 4WD
'04 SR5 4.0 V6 2WD
Old 03-01-2019, 02:56 PM #4
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Before you replcae the OCV, check the screens at the oil pipes leading to them. Pipe comes from bottom to top each side. Take bolt out slowly and screens will be on the end of them.
Also, pull the cam position sensors off the valve cover and check for built up sludge, wipe off, put back. might save you some money on the OCV.
Check Engine Light P0015-capture-jpg
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 03-01-2019, 02:59 PM #5
Jivewalker's Avatar
Jivewalker's Avatar
more info...
Check Engine Light P0015-capture2-jpg  Check Engine Light P0015-20180226_192846-jpg
I am fragile.
Not like a flower.
But like a bomb.
Old 06-27-2020, 02:14 AM #6
CraftyTech CraftyTech is offline
CraftyTech is on a distinguished road
I'm curious if this ended up being a faulty camshaft position sensor or wiring?
CraftyTech is offline   Reply With QuoteReply With Quote
check , code , engine , home , light
Check engine light, slip indicator light & flashing 4 Lo light croat5280 5th gen T4Rs 19 06-11-2020 05:16 PM
Check Engine Light, VSC OFF And Check VSC Lights just came on??? the_josh Maintenance/Detailing 5 07-15-2019 01:25 PM
Check engine light, vsc light, traction light all on after a short circuit mikeng 4th Gen T4Rs 3 01-01-2018 07:54 PM
Intermittent vehicle/engine shake and vibration with check engine light present lloydster 3rd gen T4Rs 26 09-26-2017 11:58 AM
Just washed engine bay- now check engine light appears BlackIceWAP 3rd gen T4Rs 9 07-09-2006 08:48 PM
