07-02-2019, 04:35 PM
#31
Got mine as well. Before receiving this printed mount, my ScanGauage was always slightly crooked. This fixed my OCD
07-02-2019, 07:09 PM
#32
Originally Posted by 97BlackAckCL
Does the Compustar plug in to the OBD2 plug?
Yes it does.
2018 TRD Off-Road, KDSS, 285 KO2s C, 6112/5160 + B12 rear - 2.5"/1", 1.25" Spidertrax Spacers, Greenlane Off-Road Aluminum Sliders
07-03-2019, 05:41 AM
#33
Everyone that expressed interest in one should have received a response via PM. If you didn't, please send another PM. Just got 6 more printed out so I should have enough for everyone that recently expressed interest and then some extra.
15' Grey Trail Premium - My Build Thread
07-03-2019, 10:15 AM
#34
So my remote start plugs into the ODB2 and uses a splitter. Does anyone run the ScanGauge II with a remote start? Just curious if I'd have any issues with the reader, etc.
This is the first I've ever heard of this, why does your command start need to be plugged into the OBD2 plug?!?
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
07-03-2019, 09:49 PM
#35
I believe it's because most people buy integration components with their remote-start systems that eliminates splicing of cables.
07-05-2019, 11:32 AM
#36
Real Name: Chris
Real Name: Chris
Because it's a plug and play system and it overrides the alarm
07-05-2019, 11:33 AM
#37
Real Name: Chris
Real Name: Chris
@ geofox784
Curious if you recommend using 3M double sided tape or if the tape/velcro that comes with the ScanGauge is sufficient?
07-05-2019, 11:40 AM
#38
@ geofox784
Looking back at it now, I probably would have gone with a weaker tape for the ScanGauge to Mount connection. Would make it easier to remove if I needed to send it back for updates!
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
07-05-2019, 11:42 AM
#39
Real Name: Chris
Real Name: Chris
Thanks, I rip my dash apart frequently so that's why I'm asking. I may mount the mount itself with sturdier tape but the ScanGauge I think I will use what they provided
07-08-2019, 12:56 PM
#40
Real Name: Chris
Real Name: Chris
Got my ScanGauge installed with the 3D Printed Mount, install was super easy. I used black 3M double sided molding tape on the bottom, and the 2 provided velcro tabs to mount it to the 3D printed mount.
Installation was super easy and straight forward.
The ScanGauge fired right up first try.
Thanks
@ geofox784
for the great product, I'm very happy with the install
07-08-2019, 01:00 PM
#41
Looks good! Almost have the same gauge layout as I do! Instead of MPG I have trans fluid pan temps.
07-15-2019, 07:29 PM
#42
Got mine in the mail today. Used 3M emblem tape and 3M Dual Lock "velcro". I mounted mine up close to the steering wheel.
07-16-2019, 02:22 PM
#43
Got mine yesterday. Used 3M tape. nice, secure fit.
Thanks
@ geofox784
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
07-16-2019, 02:44 PM
#44
Real Name: Chris
Real Name: Chris
Curious how you got the tire pressures to display?
07-16-2019, 03:13 PM
#45
>> Toyota TPMS Method 1
I use both the pressure and temp sensors
