03-03-2019, 09:48 PM
Brake issue
5 gen 4 runner with 295x70x17
Icon stage 7 kit
My brake padel travels down a lot befor brakes are on, I went to the dealer they said it's normal
I replace the rotors and pads with ebc green stuff and slotted rotors
Also had the dealer flushed brake fluid and replaced with race fluid
Still no change.
Anyone know of a brake upgrade kit with bigeer calipers?
Sent from my SM-G965U1 using Tapatalk
03-03-2019, 09:59 PM
When you replaced pads did the pistons have a hard time going back in? These things are known to have seized calipers.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
03-03-2019, 11:24 PM
Icon stage 7 kit
Still no change.
I don't know about pushing them down and them not being applied at all, but I can tell you that they are not super sensitive until they are. So soft sensitivity until you get to a certain point and then grabby. That's my biggest complaint about the 4Runner. In rush hour traffic when you need medium braking they tend to grab and squeal the tires, then when you let off they let off too much. Wash, rinse, repeat.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
03-03-2019, 11:59 PM
Real Name: Greg
Real Name: Greg
Icon stage 7 kit
Still no change.
Hi leo4x4,
My 4Runner is a 2012 LE... not that should make a difference! But I don't experience the "Long-Travel/Soft-pedal" issue that you've described. Now you're using a 295/70 R17 tire(?)!
The 295mm represents the width of the tire in mm, and the 70 describes the height; which is 70% of the (295mm) width, or 11.8 inches wide, equals 8.26 inches high from the rim to the ground (my 275/55 R20 is 6 inches high from the rim to the ground)!
That's a pretty tall/high tire; likely giving you a 'GREAT' mpg, but stopping will suffer... there's NO free lunch; there's ALWAYS a trade off! So let me ask you... did you think to compare the brake pedal 'Before' the tire swap? My guess is that this issue started after the swap... just a theoretical guess!
As far as I know, there have been no written-up complaints regarding squishy brakes on the Gen-5 4Runners since I've been a part of this community... that doesn't mean that it is the tires, just that it could be a factor! 'Best to you',
rig
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
03-04-2019, 01:41 AM
I have a 2019 Offroad and can agree with you that the brake pedal feel is very disappointing to say the least. I also went back to the dealer and had them checked out and "it's normal." Wish there was a simple way to adjust them. Even my 85 BMW E30 has better pedal feel than this.
Edit: the rig is still on stock suspension and wheels
03-04-2019, 02:00 AM
OP said he changed the brake fluid type? Why? Is the new stuff compatible with factory components/seals?
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
03-04-2019, 02:59 PM
Real Name: Greg
Real Name: Greg
...You must still remember,
The ABS and Anti-skid control Grabs-n-Releases the rotors in 'ms', so it's controlling the amount of pressure placed upon the rotors to slow/stop the vehicle w/o losing traction; which may be why the dealership said that this is normal! ...J/S,
rig, cheers!
03-06-2019, 10:26 PM
Icon stage 7 kit
Still no change.
That's exactly it
03-06-2019, 10:28 PM
That's exactly what I think
I also have a 2019 tundra all stock and the pedal is great.
03-06-2019, 10:29 PM
Changed the brake fluid because the original brake fluid was boiling at stop and go traffic and I would lose my pedal
03-06-2019, 10:30 PM
Originally Posted by rigtec
Hi leo4x4,
rig
I do realize that using a bigger tire would take away from my breaking a little bit however I've had that problem even when the car had stock tires
03-07-2019, 01:07 AM
Your original post mentioned replacing brake fluid with Race Fluid. I'm not sure what you mean.
At long lights you could switch to neutral. Is there any other mods that could contribute to heat soak issues?
Edit: just saw your pic with Supercharger. This can add to heat soak problems. Especially with Stop/go traffic. How much do you weigh with all of the mods? Have you upgraded the cooling system?
03-07-2019, 02:08 AM
Have you tried bedding in the brakes?
03-09-2019, 02:26 AM
6000 lb
Have not upgraded cooling system
03-09-2019, 04:13 AM
*TRD PRO*
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
