Old 03-04-2019, 11:03 AM #1
QwikKotaTx's Avatar
QwikKotaTx QwikKotaTx is offline
QwikKotaTx is on a distinguished road
QwikKotaTx's Avatar
Power Steering Pump Leak Common?
I was changing the oil on our 2010 this weekend and I noticed a lot of build up on the front, passenger side of the block as well as below on the front skid plate and rear one below the engine. I thought it was an oil leak at first but the dipstick did not show any loss of oil and there is fluid slung on the lower area of the passenger cylinder head. My guess is a shaft seal leak on the PS pump. Has anyone had this happen on their 5th gen?
I've found some low mile used pumps but it looks buried in the accessory setup. I can change the pump in 20 minutes on my 4.7L Dakota but this looks like a frustrating job. The PS reservoir was only down about 1/8" and was barely below the "hot min" line and was recently driven. I don't know if the expense and time (read frustration) is worth it for such a minor leak. I don't see any drips to completely diagnose this issue either. Thoughts?
QwikKotaTx is offline   Reply With QuoteReply With Quote
Old 03-04-2019, 11:51 AM #2
progress4m's Avatar
progress4m progress4m is offline
progress4m will become famous soon enough progress4m will become famous soon enough
progress4m's Avatar
I do not recall seeing Power Steering Pump Leak reports on 5th gen 4runers… so if you truly have it you may be the first one…
First thing I would do is clean all the “buildup” and figure out if it is power steering leak…
Not to bring the bad news… but it may be oil leaking from timing cover -I am not going to call it common, but I have seeing reports of that issue especially on the early 5th gens (mainly 2010-2012) - here is the link to one of the discussions: Timing cover leak = first trip to dealer
How many miles are on your truck? From what I know, timing cover leak would appear with fairly low mileage (under 30-40K)…
Keep us posted.
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: [URL=https://www.toyota-4runner.org/2938235-post744.html[/URL] thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
progress4m is offline   Reply With QuoteReply With Quote
Old 03-04-2019, 12:33 PM #3
QwikKotaTx's Avatar
QwikKotaTx's Avatar
Keep us posted.
Ugh, now I don't mind changing the pump, hah. I certainly hope it's not the timing cover but it is possible if it's leaking and being slung by the pump. I don't even think there are any oil spots on the driveway it is such a minor leak. I may just keep driving it if it's the timing cover. I will inspect again in a few hundred miles to see which component is leaking.
We have 90k miles on it and I've been religiously changing the oil every 8500 miles, heck first one was at 1250.
Old 03-04-2019, 03:02 PM #4
progress4m's Avatar
progress4m's Avatar
I understand: clean it up and see.
You have mentioned a “build up” and now you added “no oil spots on the driveway”: sounds like a slow leak and that is why timing cover leak came to my mind… if it is timing cover, I would recommend contacting dealer, as they aware of this problem and may know about TSB for it… if you are lucky and you have a good dealer they may assist you with repair (partially paying for it) even with 90K and 9/10 years old truck… I know it is a long shot, but maybe worth trying if you planning to keep the truck for a long time.
If not, as you said, you can probably drive it as it is.
Good luck!
Old 03-04-2019, 04:17 PM #5
QwikKotaTx's Avatar
QwikKotaTx's Avatar
Good luck!
That would definitely be a long shot. We bought the truck out of town as they had a better deal back when the new gen was hard to find. The local dealer always made a stink about it when I took it in for service. I told them I would have bought locally if available. I do all of my own work (just replaced the clutch on my Dakota, awful job) so I only used them for the 2 free oil changes and to program the windows to go down with key fob. I don't have the patience for the timing cover repair for something so minor though. I mainly buy chain driven vehicles to avoid having to worry about timing belts at 100k.
I will double check the driveway when I get home but I think I would have noticed. Most likely the skid plates catch all of the drips/runs. Ironically, the jacking point near the center rear of the oil filter skid plate has rusted out. Go figure. Thanks for the reply.
Old 03-04-2019, 06:29 PM #6
AkamiNW AkamiNW is offline
AkamiNW is on a distinguished road
No issue with PS leaks on ours
AkamiNW is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 11:13 PM #7
Joe-Runner's Avatar
Joe-Runner Joe-Runner is offline
Real Name: Joe-Runner
Joe-Runner has a spectacular aura about Joe-Runner has a spectacular aura about Joe-Runner has a spectacular aura about
Joe-Runner's Avatar
One year later -- Did you find out what was causing the buildup? I have a similar leak under the hood and I'm trying to pinpoint where it's coming from.
Also have a whine that really sounds like a power steering pump to me but no noticing any missing fluid.
2021 ORP, Naut Blue, sunroof, Gunmetal TRD wheels w/265 Falkens, NFAB steps, 1.75" 5100s front, 1" Cornfed spacer rear / 2̶0̶1̶3̶ T̶r̶a̶i̶l̶, K̶D̶S̶S̶, / 2̶0̶1̶7̶ O̶R̶P̶
https://badges.fuelly.com/images/sig-us/1038471.png
Joe-Runner is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 11:15 PM #8
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Your ten year old vehicle has a leak? Say it ain't so!
Old 05-08-2020, 03:31 PM #9
QwikKotaTx's Avatar
QwikKotaTx's Avatar
2 things. A, it's a 4Runner. B, it's a major repair to fix.
The oil leak has yet to leave a stain in the driveway but there is a layer of it all over the passenger side of the block and skid plate. The lower portion of the head is more of a dusty oil cake. It does not seem to effect the level and it comes back when I clean it, which is really only annually when I change the oil. It's not the PS pump as initially thought.
2010 SR5 MGM w/LEATHER
2002 DAKOTA 4.7L V8 VIPER T56
2015 RAM LARAMIE HEMI
Old 05-08-2020, 10:42 PM #10
Joe-Runner's Avatar
Joe-Runner's Avatar
So, while browsing the "What did you do to/in your 5th Gen today" I came across a post from @EddieV4runnin that intrigued me. He too thought at first he had a PS pump leak but is fairly certain it was actually the passenger-side VVT-i line. My leak seemed to be emanating from the lower connection to this line as well, so I figured why not go ahead and swap it out!
Just completed it two nights ago and so far it's clean under there. Did it fix it? Don't know yet.... but it may be worth looking into in your case. Unfortunately, it's a biotch to see up in that area from above, below, or from the wheel well. Here's the parts list for the job anyway. Good luck to you!
15772-31010 Pipe, Oil
90401-16043 Bolt, Union X2
90430-16016 Gasket, lower end of the line
90430-16012 Gasket, to Valve cover X2
Bolts may not be needed, but I replaced them anyway.
Banjo bolts are 48 Ft Lbs
Power steering pump bolts are 32 Ft Lbs
You need to disconnect the PS pump and let it hang to access the lower bolt and remove the air filter to get easier access to the top bolt. Whole job took me 2.5 hrs from beginning to end.
Here's a few pics. Does yours look like this?
Old 06-13-2020, 10:52 PM #11
egrasob egrasob is offline
egrasob is on a distinguished road
I created an account just to thank you! I too found oil leaking around the PS pump but not from the valve cover. After reading your post and taking a closer look, I noticed crusty oil all over the bottom end of that oil line exactly as described!
egrasob is offline   Reply With QuoteReply With Quote
Old 07-13-2020, 06:25 PM #12
jrharts jrharts is offline
jrharts is on a distinguished road
I am super curious on this one… Did your oil leak get fixed by replacing the parts you mentioned?
Thanks.
John
jrharts is offline   Reply With QuoteReply With Quote
Old 07-21-2020, 12:28 PM #13
Joe-Runner's Avatar
Joe-Runner's Avatar
Thanks.
John
Sorry for the slow response. I just got under there the other day and I do not see any oil yet! It has been over a thousand miles now and she is still clean.
Also talked with @EddieV4runnin and his seems to have done the truck as well. I believe he has several thousand miles since swapping the line.
If you suspect it I suggest you give it a shot before going deeper. It is a very basic job relative to the timing chain cover, and if it works, it works! If not, then go down that road.....
Old 01-03-2021, 01:13 AM #14
MyanRagahis's Avatar
MyanRagahis MyanRagahis is offline
MyanRagahis will become famous soon enough MyanRagahis will become famous soon enough
After seeing this, I'm almost certain I can be counted in for this leak. Definitely not as bad as yours but I first noticed a drip of oil on the bottom of the steering pump.
Traced it's way to the thicker gunk of the lower lower part of the VVT-i line as you described. The oil splatter is heaviest around that area looks like it's the source. Sprayed it off with Simple Green then soap and water. I'll be monitoring it to make sure it's coming from there.
What's the consensus if I don't fix this right away?
Would oil pour out from the bottom connection at all? Or do I need to do this during an oil change?
Thanks for those parts list and your tips for this job too.
I have just over 51,000 miles
YouTube
MyanRagahis is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 05:19 PM #15
Joe-Runner's Avatar
Joe-Runner's Avatar
As far as I can tell this is something you could put another 200,000 miles on and really not have a huge problem. You'll just have to make sure you're not losing too much oil, and if you care, go in there and clean up every once in awhile.
Me personally, I couldn't sleep good at night knowing that I have a leak, so I took care of it. Wasn't too terrible of a job, but I did scratched up my hands pretty good getting back in the cramped space. So, moderately difficult, but pretty quick job.
Since yours is so minimal right now I personally would give it another five to ten thousand miles and see if it even gets worse. Maybe that's all the more you're ever going to see of it. Good luck!
front , leak , oil , passenger , pump
Power Steering Pump or Steering Rack? *VIDEO* LexusFTW 3rd gen T4Rs 44 08-11-2021 10:11 AM
Power Steering Pump Leak RangerME47 Classic T4Rs 6 02-24-2014 07:48 PM
Problems with new power steering pump/ new pump with fluid. no power steering? cdcrone123 Classic T4Rs 3 08-27-2013 09:29 PM
Steering Rack and Power Steering Pump Replacement thebrandon 3rd gen T4Rs 5 07-02-2013 10:07 AM
Power steerking pump RESERVIOR leak... SummerallGuard04 3rd gen T4Rs 4 08-19-2012 09:32 PM
