03-04-2019, 09:41 PM
KDSS to Standard Sway Bar Conversion?
Has anyone attempted a KDSS to standard sway bar system on the 5th Gen? I've been reading about disabling or removing the KDSS / tacking up the hydraulics / etc. but have yet to find anyone attempting a conversion to an OEM (or other mfr) sway bar. Are the mounts the same?
Just curious.
03-04-2019, 09:49 PM
I believe people had tied up the KDSS Pistons to stop them from working.
I don't know if anyone got as far as making another sway bar. I didn't get that far wouldn't of gotten KDSS if I wanted to get rid of it.
KDSS Removal
2018 TRD OFF ROAD
My Build
03-05-2019, 06:45 AM
Im currently deciding between KDSS and non-KDSS. I've heard nothing but good things about the system. Why are you/people attempting to disable it?
03-05-2019, 09:50 AM
Real Name: Krister
Real Name: Krister
The mounts for KDSS and non-KDSS are different especially on the rear axle. It would take some fab work to potentially make it happen. There are now kit's for the Anti-Rock for the rear, which will take some work (welding) to install or more, depending on your set-up and bumpers.
For those looking to strap the piston, it's somewhere in my build thread. I did this several years ago in order to get the full effect of the LT rear suspension set-up. I have been running no sways since that time with-out issue. Just don't drive like an idiot or think you are in some rice rocket.
2020 Tundra Limited Crew Max 4X4 - Tundra Build
2014 4Runner TE - rochmpr Build - SOLD
03-05-2019, 10:54 AM
The frames of a KDSS and non-KDSS are different also. I don't know how or why, but the frame part numbers are not the shared between the two. The Limited, TRD Pro, Non KDSS TRD OR/Trail and SR5 models share one frame and the KDSS TRD-OR has its own frame part number. 2WD also has a different frame.
That said - I have no idea on whether the sway bar mounts are present on the KDSS frame. And as ^ rochmper said, the rear axle mounts are different as well.
Something like a curry antirock is probably the easiest non-KDSS sway bar to add, or you could swap rear axles for a non-KDSS housing.
The other alternative would be to consider having a custom sway bar made that retains KDSS but has lower torsion spring rate and/or longer arms for more travel.
03-05-2019, 12:12 PM
The only reasons I can think of are:
1) Increasing lift or suspension travel too much for the KDSS to handle (in which case, I'd consider selling and buying a non-KDSS...)
2) The system is malfunctioning outside of warranty coverage, and the owner doesn't want to pay to fix or have it fixed.
2018 TRD Off Road Premium - Barcelona Red
03-05-2019, 12:14 PM
I love mine. I think KDSS gives me the best of both worlds. I may reevaluate if I was looking at a repair bill in the thousands, but it sounds like it could cost as much or more to delete.
03-05-2019, 12:38 PM
I wish there was an easy way to get KDSS to disconnect up to 20 mph.
stress on the easy part.
Build thread
03-05-2019, 12:45 PM
It just depends on your plans and how crazy you intend on getting with the suspension… there comes a point where things like this just start getting in the way. For most people, it’s a non-issue.
03-05-2019, 12:50 PM
Probably why the TRD Pro doesn't have KDSS as an option. I think the whole TRD Pro concept was desert running at speed.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
03-05-2019, 02:34 PM
if you put the same rate sway bar and same springs/shocks it will feel the same at speed
but if you want an easy way to allow it to move at speed you can install a switch
03-05-2019, 02:43 PM
It's called a trade-in...
You can disconnect the bars and tie up the Pistons.. just be careful not to loosen any of the hydraulic lines or loose pressure in the system.. that was a painful and $$ mistake .
I'd rather just leave it as is really. There's not much to gain unless you are going LT
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
03-05-2019, 03:14 PM
Banned
Real Name: Tobias Fünke
Banned
Haven't seen anyone with an actual switch. Only read rumors.
03-05-2019, 04:08 PM
people have unplugged it and it worked fine, a switch is no different just easier.
03-05-2019, 06:34 PM
Curious how you just add a switch on a hydraulic system.
2018 TRD OFF ROAD
My Build
