03-05-2019, 05:00 PM
ANyone remove Roof Rack from a '19 TRD Pro
Looking at removing the roof rack from my 2019 TRD Pro. Don't care for the look. I removed the roof rails from my 2018 Land Cruiser and my previous 2017 4runner Pro, but those used hex bolts and this has Torx bolts. I do have the roof rail delete kit from Toyota for removing those rails and to seal up the holes but not sure if it'll work on this rack.
Anyone remove it yet? I assume its the same holes and location points as the other 4Runners.
03-05-2019, 05:15 PM
Real Name: Chris
Real Name: Chris
The bolt holes are the same as the other stock roof racks you should be able to use the delete kit
04-21-2019, 01:19 PM
I just removed them...t40 torx and yes all 5th gens are the same. It’s a PITA with the red loctite. tip, don’t break the screws loose w/o the other pair still in and use PB blaster (or equivalent).
There is a bracket that holds the pair of 2 nuts (where the screws go in) tac welded to the underside of the roof that can break off. If this happens you cannot unscrew them since the nut on the underside of the roof with the bracket will spin freely. I ended up having to take the rear headliner down a little to access the nuts and bracket.
Hard to explain but I will post some pics shortly that should help.
04-21-2019, 05:49 PM
The bracket is twisted but I hope this helps
04-21-2019, 11:20 PM
Real Name: Justin
Real Name: Justin
There was a guy on the lexus forum that put 5th gen OEM rails on the GX460. I can't imagine that they'd change the design for the new and improved FJ rack. It's weird that they used torx but the bolt pattern should be the same.
2010 4Runner SR5 Magnetic Gray: Radflo / Icon + Metaltech / Total Chaos / Dirt King / SCS Stealth 6 / BAMF Sliders + Pelfreybilt Bumper / PRINSU / Indel B / 2014+ IS 350 Retrofit
2012 GX460 Premium Black Onyx: Stock af
04-26-2019, 02:06 AM
Yep, the torx was weird. I ended up finding the brackets at Toyota $3~ each and switched out the hardware with stainless hex head bolts. M8 1.25 and 50mm length and some 5/16 washers .
Sent from my Pixel XL using Tapatalk
04-26-2019, 07:06 AM
Bolts
What is the difference or preference in using either bolt I’m about to mount the 19 pro rack on my 18 ofp which should I use
Mike
04-26-2019, 07:28 AM
Should be the first mod done, that roof rack is hideous.
2021 JGC Trailhawk (waiting for the 6th Gen 4R
2015 Silver TE: (SOLD) KDSS, ICON stg 2, Magnuson, Victory Blitz sliders, Fuel Blitz DDT 18x9 w/ -12o/s, 275/65/18 Nitto TGG2, ARB skids, Spidertrax spacers, Alpharex Luxx, Rigid 40” Stealth LED bar & 360 fogs, Switch Pro 9100 w/ Mount Tray, KC Flex Dual Ditch Lights, KC Cyclone Rock Lights, LED interior, SSS hybrid winch bumper, 30" Rough Country single row LED, Alpine ILX-F308/R line speakers, 8" Alpine Powered Sub. Prinsu Full no-drill roof rack.
04-26-2019, 08:23 AM
To each his own bud
04-26-2019, 01:01 PM
Real Name: B-Money
Real Name: B-Money
I’m SURE people will be fighting to buy that thing from you!
Anger Fuels Motion...Motion Fuels Momentum...Momentum Fuels Action...DO SOMETHING!
2010 4Runner SR5
04-26-2019, 01:34 PM
I'd consider buying it. I know it's not popular around here but I like it. If anyone wants to get rid of one PM me.
04-26-2019, 02:04 PM
I know how hard it was to get mine Toyota treats it like gold
04-27-2019, 07:24 AM
Real Name: B-Money
Real Name: B-Money
It’s definitely not for everyone. I think it looks hideous. It worked beautifully on the FJ. On the Runner...meh...but again, someone will jump all over this. Especially since the dealers are demanding a TRDP VIN to order. Kind of adds more value to those selling. Just saying.
2010 4Runner SR5
04-30-2019, 03:56 PM
Posted this in a similar thread as well but I'm wondering if this is a design exclusive to the 19' Pro only:
Hey I also just removed my 19' rack but had to be super careful not to lose those brackets in the headliner. I've got the delete kit on now but I'm concerned that when I get my Gobi rack the mounting hardware won't fit that bracket or i"ll lose them in the process. Seems when it arrives I might have to remove the headliner entirely to be able to access all 4 brackets.
Is the 19' Pro the only one with that backing bracket style?
07-19-2021, 02:21 PM
Real Name: Tom
Real Name: Tom
I am pretty sure they all have the clipped in backing bracket above the headliner.
1978 FJ40. Mostly stock, reverse shackle 3 inch lift.
2019 Pro Voodoo Blue
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
