Old 03-06-2019, 08:18 AM #1
dedonderosa dedonderosa is offline
dedonderosa will become famous soon enough
Synthetic or non synthetic gear oil? whats everyone running?
have been debating on what i want to use in my front and rear diff. i have been searching around and wanted to see what everyone is running in their front and rear diffs ? been seeing mixed reviews with people saying use synthetic 75w90 and many others saying stay away from synthetic gear but not sure exactly why. let me know you opinions and what you using etc. thank you guys
dedonderosa is offline   Reply With QuoteReply With Quote
Old 03-06-2019, 08:41 AM #2
chester4Run chester4Run is offline
chester4Run is on a distinguished road
I've been using Amsoil 75w90 for the last 60K miles. I just changed both front and rear and the oil appeared as new in both after that mileage. The argument I've heard for conventional oil is better heat dissipation. I haven't checked the differential temps on my 4Runner, but years ago when I started using synthetic gear oil in my Jeep I did do so. (checked when arrived home, at highway rest-stops, after wheeling, all of this in sunny, warm, FL) The differential casing was always within a couple degrees of the frame temperature.
2011 SR5 4wd
2004 SR5 4wd
1994 SR5 4wd (SOLD)
chester4Run is offline   Reply With QuoteReply With Quote
Old 03-06-2019, 09:32 AM #3
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
Red Line 75w-85 GL-5 because that is the weight Toyota recommends for this truck. Few other companies make 75w-85 though.
<<<< is offline   Reply With QuoteReply With Quote
Old 03-06-2019, 10:02 AM #4
epjfsa epjfsa is offline
epjfsa will become famous soon enough epjfsa will become famous soon enough
Anyone who says stay away from synthetic probably still says that [any established technology] in cars is just "one more thing to break." It's 2019, use synthetic. I'm using Amsoil as well.
'16 TEP
'21 Model 3 LR
epjfsa is offline   Reply With QuoteReply With Quote
Old 03-06-2019, 11:11 AM #5
MTN4RNR's Avatar
MTN4RNR MTN4RNR is offline
Real Name: Max
MTN4RNR is a jewel in the rough MTN4RNR is a jewel in the rough MTN4RNR is a jewel in the rough MTN4RNR is a jewel in the rough
MTN4RNR's Avatar
Real Name: Max
I opt for Redline 75w85. One of the only options that stays within Toyota spec. Lots of people use 75w-90 with no issues. In either case, go with a synthetic... /thread
2016 MGM Trail Premium - KDSS
Explore4R.com
Building the MTN4RNR
Instagram --- life.to.the.max
Writer/Editor at Trail4Runner.com
MTN4RNR is offline   Reply With QuoteReply With Quote
Old 03-06-2019, 12:07 PM #6
STX4Runner's Avatar
STX4Runner STX4Runner is offline
Real Name: Jonathan
STX4Runner has a spectacular aura about STX4Runner has a spectacular aura about
STX4Runner's Avatar
Real Name: Jonathan
Redline 75 85 as well. Had it in the rear for the last 60,000 miles and just changed the front last year and put it in.
2010 TE KDSS|275/70R17 Goodyear MT/Rs|Front Bilstein 5100s @ 2.5", rear Bilstein 5100s & 2" Icon lift springs|RR sliders|RCI skid plates|BudBuilt diff skid|Sonoran Steel HD rear lower links|RCI rear lower link bracket skid plates
STX4Runner is offline   Reply With QuoteReply With Quote
Old 03-06-2019, 12:26 PM #7
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Amazon has Toyota OEM oil "Used, Like New" for $23/qt. What do you think "used, like new" means? lol.
I still have whatever Toyota put in originally. I'll probably swap out to a synthetic of the same weight. I'm not totally sure the original is not synthetic, but I don't know. I haven't found much information on what it actually is.
Old 03-06-2019, 03:23 PM #8
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
I wonder if this "use only conventional gear oil" thing is the result of the following article by East Coast Gear Supply?
https://eastcoastgearsupply.com/file...mendation1.pdf
Early on they mentioned "clutch". OK - maybe for that type of application, but how many 4 Runners / Tacoma's / etc - have this today?
Mine is a 2WD. Have been running Super-Tech 75W-90 full synthetic and see none of the problems brought up on the web.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 03-06-2019, 03:47 PM #9
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
the 4 runner has open diff's so NO clutches .. my GM sedan has a posi traction full time rear diff so I have to use conventional gear oil with the slip additive because it has clutch .. so synthetic on my GM sedan will not work properly get chatter ..
Toyota runner open diff I asked the dealership . they said 75-90wt synthetic , suck it out from 55 gallon drums ..
I changed my rear diff @3K miles because of a heat damage on the oil.gray and particles in it .. so far now 20K miles on the mobil synthetic 75-90wt oil looks like new . I also increased MPG by 2 ..
I will use the toyota transfer case oil very specific has many lube additives . not an issue on the 75WT the issue is the lubrication additives .. expensive odd ball fluid 30K-40K miles replacing use..
catrains is offline   Reply With QuoteReply With Quote
Old 03-06-2019, 04:44 PM #10
enyce enyce is offline
enyce is on a distinguished road
Amsoil Synthetic 75W-90 for the rear diff.
2015 4Runner Trail Non-KDSS Husky Floor Mats Falken Wildpeak A/T3W P265/70R17 AFe Drop in Air Filter So far stock... Loving it
enyce is offline   Reply With QuoteReply With Quote
Old 03-06-2019, 05:13 PM #11
QwikKotaTx's Avatar
QwikKotaTx QwikKotaTx is offline
QwikKotaTx is on a distinguished road
QwikKotaTx's Avatar
Don't overthink it. There are millions of trucks on the road with 100k miles and the owner has never changed the diff fluid. 60k should be fine on the OEM fluid.
QwikKotaTx is offline   Reply With QuoteReply With Quote
Old 03-06-2019, 06:10 PM #12
zonzin's Avatar
zonzin zonzin is offline
zonzin has a spectacular aura about zonzin has a spectacular aura about
zonzin's Avatar
Mobile 1 75/90 F&R diffs, Royal Purple Synchromax Transfr.
Comes out looking clean every 30k.
zonzin is offline   Reply With QuoteReply With Quote
Old 03-06-2019, 06:58 PM #13
QwikKotaTx's Avatar
QwikKotaTx's Avatar
Then why do you change it so often?
Old 03-07-2019, 12:09 AM #14
Gclark949's Avatar
Gclark949 Gclark949 is offline
Gclark949 will become famous soon enough
Gclark949's Avatar
Amsoil. Both front and rear Toyota oil came out surprisingly dirty looking at 10,000 miles so I was glad I spent the money but I am sure most of that is just new gears wearing in and would not normally look so bad after so few miles.
2016 Trail Edition Premium, Silver with KDSS, 2.5 King lift, T13 rear springs, FN Six Shooter with ST Maxx, BB Skids
Gclark949 is offline   Reply With QuoteReply With Quote
Old 03-07-2019, 08:28 AM #15
isnt the transfer case suppose to use "toyota 75w" as there are a ton of additives in this fluid compared to other fluid people are using
gear , oil , running , stay , synthetic
100k + Oil Changes. Conventional, synthetic blend, full synthetic? Jeffrey_VB 4th Gen T4Rs 17 01-12-2016 01:50 PM
difference between full synthetic and synthetic blend chetJ 5th gen T4Rs 20 07-18-2013 09:08 PM
synthetic brake fluid and full synthetic powerstering johnathandm 3rd gen T4Rs 3 07-20-2011 10:35 AM
Oil... dealer says i have choice on synthetic or synthetic with additives 4RunnerTrail 5th gen T4Rs 15 05-07-2010 03:38 AM
