03-08-2019, 12:36 PM
Opinions?
I have a 2016 4runner TRD Pro, wanna do a 2 inch spacer lift, corn fed or toytec? And 285 70 17 tires k02 or Nitto ridge grapplers? Will they rub?...what’s the better setup?...I’m 90 % on road 10 % off road. Any incite will be greatly appreciated.
03-08-2019, 12:41 PM
Seriously...? Just read this - Going Bigger - 5th Gen Tire Fitment Guide - Toyota 4Runner Forum - Largest 4Runner Forum
Read all of it.
Cement, RCI Skids & Sliders, Nitto Ridge Grappler, Northstar AGM, Goose Gear Plate, Dometic CFX 65W, Dometic Fridge Slide, BPF Molle Panel, Pedal Commander, Compustar, BlackVue, Diode Dynamics SS3
03-08-2019, 01:01 PM
It all depends on how much plastic dip you intend to apply
2012 Limited Blizzard Pearl
03-08-2019, 01:04 PM
285s require 7.5 inch width rim size, would they fit well on a stock TRD Pro wheel 7inch?
03-08-2019, 01:14 PM
Zero chance they won't rub. Most folks will have "some" rubbing with 275's like I did. Had to remove the mud flaps with 275's but no fender mod or BMC needed. You will likely need both with 285's, but some trimming will be required at the very least.
03-08-2019, 01:40 PM
This has to be a rhetorical question - you seem to take the oxy out of oxymoron.
03-08-2019, 01:51 PM
I will never understand buying a Pro and then putting a spacer lift on it.
2019 TRD Off-Road Premium
285 Cooper STT Pros - Tandem Offroad 612 Charlie in bronze
Dobinsons - Front: C59-300, GS59-574 Rear: C59-505, GS59-701 - JBA UCAs
RSG Metalworks Sliders - Angled - RCI Skids
03-08-2019, 02:25 PM
Real Name: KE0OIC
Real Name: KE0OIC
Mist people buy them for the stickers.
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
03-08-2019, 02:32 PM
A ton of guys..myself included run 285's on TRD wheels w/o issues.
I am lifted 2.75 in the front and 2 inches in the rear with 285/70/17 Nitto RGs with SPC UCA and have no rubbing at all and had to do zero trimming and maintained my mud flaps and I do wheel my rig and air down to 15 PSI.
Pro's have the front bumper cut slightly at the port so you may have to do that. All rigs are a little different though.
If you decide to run spacers you will rub however.
03-08-2019, 04:27 PM
Great, thanks
03-08-2019, 04:48 PM
Real Name: Danny
Real Name: Danny
I'm with you on that.. You're effectively paying double for the suspension. Premium on the pro suspension and again when replacing suspension parts.
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg BJ UCA's Fox 2.5 Resi rear W/ Icons. Method 701's, Cooper S/T Maxx 285/70/17. Shrockworks sliders. LLama Tales
Dual Battery Thread
03-08-2019, 06:38 PM
But the TRD OR doesn't have the TRD Pro emblem on the side.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
