03-08-2019, 11:41 PM
Too Much Lift from Icon 52700 springs?
I was surprised to see after installing these springs, the rear of the truck is 1-inch higher than expected. I wanted a modest lift so i wouldn't have to worry about needing a diff drop. Now i'm wondering if its required.
Any advice or shared experience is greatly appreciated.
2016 T4R TEP | Maxliner floor mat | KO2 285/70/17/C | Precision Interior LEDs | Ceramic window tint | AVS Aeroskin deflector | Rhino Rack Pioneer Platform | SunSeeker Awning | Fox 2.0 front/rear no res | Icon 52700 | VTX Wheels | Side exhaust | Xenon Depot HID Low Beams & LED fogs
Round Rock, Texas
03-08-2019, 11:56 PM
How long ago did you install the springs? They do settle a bit after a few months of use.
03-09-2019, 12:19 AM
Installed today
Yup - forgot to mention they were just installed today. I was worried that the installer forgot to remove the 1" cornfed spacers but i checked the box and there they were.
Round Rock, Texas
03-09-2019, 12:37 AM
looks good to me...not sure what you mean about the differential drop if the rear springs are higher though? are you implying you want to raise the front to level it out and are worried about that?
when loaded down with gear, my rear springs aren't heavy enough to keep the height...it's all a compromise, either too stiff unloaded, or not enough loaded down...i've thought about the icon 'overland' spring with the described dual rate, but have heard a spectrum of contradictory reports on how they feel unloaded
2014 TE
BFG KO2 285/70 17, Icon Stage 2, Shrockworks front bumper, sliders, engine skid, 9.5 winch, FN counter steer type X
03-09-2019, 01:34 AM
I run the Icon “overland” springs and love them. I’m heavy in the back with a rear bumper, but it rides great loaded and unloaded. If you’re stock and unloaded, it might be a bit much.
03-09-2019, 02:11 AM
It'll settle. When I installed mine it gave me about little over 3" but after a few weeks it settled to 2" of lift.
03-09-2019, 07:00 AM
👆🏻 This. Don’t worry...give it a couple of weeks.
Current - 17’ TRD ORP KDSS/Bilstein/Chaos UCA’s/TRD PRO/KO2 285s/Rigid Fogs
Former - 14’ TEP - too much to list
Former - 11’ SR5
03-09-2019, 09:43 AM
give it a little time; they'll settle down a bit. mine ended up at ~2.5" of rear lift.
10 TE - salsa, KDSS+JBL+Nav
ICON XT COs (+IVD) & tubular UCAs • ICON rear coils & 2.5 remote reservoirs + shin guards • Shrockworks • FN Five Star + 285/70 Mickey Thompson MTZ • TRD CAI + aFe Pro Dry S • Magnaflow • ARB diff breather • rack delete + Thule • H9 lo, 9011 hi, selective Y fog • FJ shifter • ScanGauge
06 SE, galactic gray V8: sold // 93 SR5, lots of rust, salt, & mods: R.I.P. // 71 FJ40, never should've let it go
03-09-2019, 09:59 AM
whats your center hub to fender measurement? I installed the OME 440lb springs, and had a lotta rake and 25" rear when unloaded.
2017 TRD PRO Barcelona Red,RCI Sliders,RCI Alum Skids +C4 Fuel Skid, 285 Nitto Ridge Grapplers, Icon Rebound 17x8, HID, SSO Slimline Front Bumper/Warn Zeon 10s Plat, SSO High Clearance Mod, ..King 2.5 Res, Total Chaos UCA & LCAs, ARB Fridge, Battle Born Second battery with RedArc& Solar, ARB Drawers..Frontrunner Full Rack and CVT Mt Ranier RTT, C4 Ladder, Sprint Booster
2021 Audi RS6-Tuned 820hp
2017 F12 Berlinetta
03-09-2019, 03:40 PM
Rear measurements
I'm relieved to hear these springs are expected to settle with time. Right now the measurements from fender to center hub are
RD = 24.5" & RP = 25"
Round Rock, Texas
03-09-2019, 05:35 PM
That honestly looks fine. A little rake is fine, you won't want a level truck. Once you load crap in the back it will bring down the rear anyways.
Keep in mind the springs provide 2" of lift and have a stiffer spring rate than stock. So it'll need a little time to settle.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
07-18-2022, 12:34 PM
I've had the 52700 spring with the 57710 piggyback shocks on my 4th gen 4R and have hated the ride from day one some years ago. 3" lift top high. Sitting on 33" ko2's 285\75\16 and rear is at times ominously bouncy on the road and sits high. Even 8 years later.
The "better than thou owner"of Icon dynamics who seems like he's in love with himself said " it will ride nice with 400lbs loaded".
I'm swit hi g put rear icon spring with a Bilstein that will also lower it 1 inch.
ICON ....NEVER AGAIN.
07-19-2022, 11:44 AM
This.
And I'm also unclear how to much rear lift would affect your front diff. A diff drop is done to reduce the CV angle of the front suspension after lifting. I would maintain it's unnecessary but others would disagree.
07-19-2022, 12:49 PM
Originally Posted by comtn4x4
This.
Yup most of the time most people won't even need diff drops, in this case definitely not needed. The only real few things to worry about on rear lifts is how much rake you want and travel length of the shock if going with a longer rear spring
08-08-2022, 02:02 AM
I went 3” front and 2” HD rear springs and ended up the same. No diff drop.
It has a 1” rake that only kind of settles when I load it up camping.
I’ve gotten used to it and have only had good feedback.
Looks like you could raise the front and be OK. Or swap to a set of 1.5 springs.
