Old 03-18-2019, 08:41 AM #31
jsun_2k's Avatar
jsun_2k jsun_2k is offline
jsun_2k is on a distinguished road
jsun_2k's Avatar
Originally Posted by xyzzy View Post
If you have a buddy with the sd card you want to duplicate, the following command (Linux, Mac OS X, Cygwin, Win 10 bash shell, ...) should allow you to make an exact bit-by-bit duplicate of one sd card onto another sd card (of the same size) regardless of the format used.
Be extra careful that you have input and output devices correctly identified or you will wipe out the good card by writing the bad card to the good card.
if - is the input block device
of - is the output block device
bs - is the block size (in this case 100 MB)
conv - is the conversion to apply to the copy
# dd if=/dev/sda of=/dev/sdb bs=100M conv=notrunc
Oh, and the # prompt means that you will have su'd to root or sudo'd the command. If you don't know what this means and are not comfortable with it, then don't try this and use another solution.
Review the dd man page for options available to you and be careful with commands like this - they can be catastrophic. You have been warned multiple times!
You probably should have used this method to make a backup of your OEM card prior to attempting any modifications. Just sayin...
You have 2 SD card readers? one inetrnal, one external?
jsun_2k is offline   Reply With QuoteReply With Quote
Old 03-18-2019, 09:20 AM #32
zzdocxx zzdocxx is offline
zzdocxx is on a distinguished road
Hey I don’t remember paying extra for nav at the dealer, I don’t have the sat radio subscription.
So is the nav something I would have had to add or turn on at the dealer?
Does it actually work when you are way out in the boondocks?
2017 TRD Off Road
zzdocxx is offline   Reply With QuoteReply With Quote
Old 03-18-2019, 12:16 PM #33
Infinus Infinus is offline
Infinus is on a distinguished road
Doing a straight clone of the sd card to another card wont work even if it is a bit by bit duplicate because of the encryption on the file linking the maps to the specific card. There is a unique file that is encrypted with the hardware ID of your specific card. If you clone the card the encrypted key for the prior card will copy, when the system checks to verify it will see your card is a different card than the original and will fail to load. The only way this would work is if you were backing up your own card and flashing back to that same card. These hardware ids are not changeable so you can't modify your card to match the other one.
Infinus is offline   Reply With QuoteReply With Quote
Old 02-13-2020, 03:40 PM #34
stonewall55 stonewall55 is offline
stonewall55 is on a distinguished road
I bought a 2017 TRD Pro recently and it didn't come with an SD card, and therefore no GPS. I'm pretty sure GPS was supposed to be included. How can I get this card? And get the dealership to pay for it?
stonewall55 is offline   Reply With QuoteReply With Quote
Old 04-30-2022, 06:51 AM #35
Acevedo Acevedo is offline
Acevedo is on a distinguished road
If you have a data recovery issue, there are a few things you can do to try and recover your data. First, if you have an SD card, try using a data recovery program to see if you can recover any lost or deleted files. If the program is unable to recover your data, you may need to send the SD card to a professional data recovery service. If you do not have an SD card, you may still be able to recover your data by using a data recovery program on your computer. However, if the program is unable to recover your data, you will likely need to send your computer to a professional data recovery service. Data recovery services( SD Card Data Recovery) are often able to recover data that is otherwise unrecoverable. Thus, if you have a data recovery issue, it is best not to attempt to recover the data on your own since this may result in permanent loss of your data.
Acevedo is offline   Reply With QuoteReply With Quote
Old 05-10-2022, 03:04 AM #36
N6WRV N6WRV is offline
N6WRV is on a distinguished road
Originally Posted by Bonniem View Post
Hi guys, I need your help or advise. To make long story short I accidentally formatted my Toyota’s micro sd card, and no more navigation. What are my options to get it back some how instead of going to the dealer.
Thanks
No worries. I purchased the following micro SD card from Amazon for $32.
2014 2015 2016 2017 2018 2019 Toyota Latest Navigation Micro SD Card 86271-0E072
Brand: HERE
Amazon.com: 2014 2015 2016 2017 2018 2019 Toyota Latest Navigation Micro SD Card 86271-0E072 : Electronics
2015 4Runner Limited with X-REAS Sport Enhancement Suspension, 37qt ARB fridge wired directly to battery with ARB Wiring Kit.
N6WRV is offline   Reply With QuoteReply With Quote
Old 05-10-2022, 10:08 AM #37
DAW89446's Avatar
DAW89446 DAW89446 is offline
Real Name: Dave
DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light
DAW89446's Avatar
Real Name: Dave
I bought my ‘18 used in ‘19. It is equipped with nav, but lacked the card. I got mine off of eBay from an AZ dealership for $60 shortly after I bought my truck. New, sealed, well packaged, 2018 mapset, plug and play.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
DAW89446 is offline   Reply With QuoteReply With Quote
Old 05-10-2022, 11:15 AM #38
Dorobuta Dorobuta is offline
Dorobuta is on a distinguished road
Brand: HERE
I did the same thing and it worked nicely. I was tired of driving on freeways my GPS said didn’t exist…
2016 TE Premium, Barcelona Red. Icon Stage 2, Motometal Wheels and BFG KO2 285/70R17s, Demello Hybrid Sliders, Wet Okole covers, Prinsu full rack, and Westscott designs ladder. Diode Dynamics SS3 Pro amber fog lights.
The only things stopping me now are physics and law enforcement
Dorobuta is offline   Reply With QuoteReply With Quote
back , card , micro , options , toyota
WTB: Hella Micro DE for 99-02 MaukaRunner Want to Buy/Trade 0 03-21-2016 02:49 PM
EDC Micro flashlights KidVermicious Off Topic 18 09-20-2015 03:54 PM
TOYOTA Brake Service (PADS) for $100 and get $50 VISA gift card! nissanh For Sale: T4R Items 2 03-03-2014 01:04 AM
Toyota Credit Card JungleJim 4th Gen T4Rs 4 08-23-2006 11:43 PM
Toyota credit card beeper 4th Gen T4Rs 5 05-12-2005 11:21 AM
