03-12-2019, 08:32 PM
Busted KDSS hose
I was in a hurry to cut off the tab near the KDSS system when I accidentally damage the hose. Well, it busted today while driving. Is there a non-toyota/Lexus place that would fill and bleed the KDSS system after getting the hose replaced? This is on a GX460 which is similar to the KDSS system on the 5th gen, btw. Anyone have this hose laying around. I figure some of you have removed the KDSS system.
03-12-2019, 10:48 PM
I feel sorry for you. Looks like standard hydraulic line. Have you called the dealer for a quote? Sometimes easier to do it right the first time.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
03-13-2019, 06:18 AM
Bohica
Current - 17’ TRD ORP KDSS/Bilstein/Chaos UCA’s/TRD PRO/KO2 285s/Rigid Fogs
Former - 14’ TEP - too much to list
Former - 11’ SR5
03-13-2019, 10:53 AM
Can you get a zoomed out photo of the hose?...we just pulled two complete KDSS systems out of two 5th gen 4runners. Everything is available, minus the hard lines.
2015 4R TE w/ KDSS, Mag Gray, King coilovers, King shocks, Timbrens, Dobinsons 749V progressive coils, Dirt King UCAs, Full Rokmen rear arms and panhard, OPOR Sliders, Hefty Front aluminum bumper, rear C4 dual swingout bumper, Warn VR10000S, HeftyFab full skids, AVS Aero, Interior LED's, XenonDepot HID w/ Phillips 4300k, ARB twin compressor, Rear-diff Breather mod, TRD Pro front, Dometic 50, Frontrunner Slimline II Full, TrekBoxx System Alpha, Trekboxx sleep platform, BlueSea, and BajaDesigns lights (LP9's, S8 20", Squadron Pro's, S2's), McQueen Fiberglass Fenders...and a hatchet! 35" Falken Wildpeak MT01's wrapped around SCS Ray 10s, BORA 1" wheel spacers. ECGS 4.88's.
03-13-2019, 12:09 PM
Banned
Real Name: Tobias Fünke
Banned
May I ask why? Do share.
03-13-2019, 12:31 PM
any hydraulic hose place can fix that hose.
03-13-2019, 12:50 PM
This is the lower hose of the two that is connected to the front piston. Thanks.
03-13-2019, 01:25 PM
Here it is a little zoomed out
Sent from my SM-N950U using Tapatalk
03-13-2019, 05:45 PM
They both went +2 long travel, with custom reinforcement of the frame around the UCA's and shock mounts for the bypass shocks. The KDSS hoses and mounts were in the way...likely will do some sort of antirock sway once the rear suspension is sorted out
03-13-2019, 05:57 PM
Banned
Banned
That's what I figured. I keep hearing about people doing this and mentioning anti rocks. Can't wait to see someone make a post about it.
03-13-2019, 09:54 PM
Check Jsparky's build thread on here...he has an antirock. Lawndart did as well.
There's another person on here working on a front version.
Also, Total Chaos released a front sway bar recently that is LT compatible. Haven't seen it in person though
