Originally Posted by luke150
Which model and equipment package would be best for towing a 4000lb. boat?
Whichever one you like the best.
Not trying to be flip, it's the truth. All the Runners come with the same engine, so there's no difference there. As far as the transmission, you can go with the full time 4x4 XREAS that comes in the Limited if that makes you feel better, but ALL of the Runners come with 4x4 as an option, and the rest of the trim / interior upgrades on the Limited make it the most expensive T4R out there out of the gate. Plus the exterior (front end, mainly) of the Limited is different than the rest of the Runners, I dunno if the "look" is a consideration to you.
As far as the suspension, unless you're getting a TRD Pro, they're all the same... and though the TRD shocks / springs are a bit beefier, they're not intended for towing and won't get you any added advantages like installing an aftermarket airbag setup would. Someone can correct me if I'm mistaken but all the different trim levels of Runner are rated for the same towing capacity (4700 lbs. if memory serves)
As you probably know, having 4x4 in your rig isn't absolutely necessary for towing, it just depends on what you're going to get into. Are you just towing the boat to the slip / dock and putting it in the water? Are you having to tow it offroad at all?
Long story short, it depends on what you're having to tow through... but I'd say put a decent set of tires on your rig and decide whether you need 4x4 or not and then just pick whichever Runner you like and go for it.
