Old 05-28-2020, 05:15 PM #106
shrub1's Avatar
shrub1 shrub1 is offline
shrub1 has a spectacular aura about shrub1 has a spectacular aura about
shrub1's Avatar
Originally Posted by sicnarfone View Post
I am pretty set on getting 5100s on all 4 wheels. I'd also like to do a 2.5" in the front 2" in the back and I am wondering. Is there a difference in ride quality and performance between adjusting the struts to achieve the height/using OEM coilovers and setting struts at 0"/replacing OEM coilovers with 2.5"front/2"rear?
I am looking to level the 4runner and give it a lift but don't know which route I should go.
Go 5100 set at ZERO. and then OME 885 front spring and OME 895E rear.
Good set up for a great price.
shrub1 is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 06:15 PM #107
jakerjac jakerjac is offline
jakerjac is on a distinguished road
I was thinking of doing this exact set-up but 884s instead of 885s. Is the difference the spring length or how much weight it can support?
jakerjac is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 06:29 PM #108
UglyHotness's Avatar
UglyHotness UglyHotness is offline
UglyHotness is on a distinguished road
how much lift did that give you front and rear? I was looking into that spring setup
UglyHotness is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 06:32 PM #109
shrub1's Avatar
shrub1's Avatar
Sorry not certain on 884 springs.
Old 05-28-2020, 06:33 PM #110
shrub1's Avatar
shrub1's Avatar
With stock bumpers I've seen about 2.75 front and about 1.8 rear.
Old 05-28-2020, 07:00 PM #111
sicnarfone's Avatar
sicnarfone sicnarfone is offline
sicnarfone will become famous soon enough
sicnarfone's Avatar
I am considering that set up as well but would like to know if there is any difference.
sicnarfone is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 07:16 PM #112
sicnarfone's Avatar
sicnarfone's Avatar
Does that set up make your 4runner seem leveled?
Old 05-28-2020, 07:40 PM #113
shrub1's Avatar
shrub1's Avatar
Still about 1 inch of forward rake, which I want because when I am loaded up for a trip the rear doesn't sag. Being totally level isn't real practical (for me) when you are loaded up.
Old 05-28-2020, 08:55 PM #114
sicnarfone's Avatar
sicnarfone's Avatar
I am thinking about the same thing. I've seen some 4runners on the freeway with a reverse rake and it looks awful. Worse than forward rake.
Old 05-28-2020, 10:18 PM #115
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
How much weight are you carrying when loaded up? Just curious.
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 10:35 PM #116
shrub1's Avatar
shrub1's Avatar
200-230 range.
More if the guns and gongs are coming with.
Old 06-01-2020, 09:28 PM #117
axel1's Avatar
axel1 axel1 is offline
axel1 is on a distinguished road
axel1's Avatar
Hey all,
Installed the 5100's over the weekend along with 1" cornfed spacers for the rear. Have a great mild lift and it's much tighter on the road.
I've got an alignment scheduled for Wednesday to fix up current no-so-great camber on the front end. However, driving around town today I noticed I'll occasionally get some "thunks" when going over big bumps, potholes, or doing anything that really compresses/extends the suspension. I've heard the "thunks" from both the front and back. Is that something that happens with a new suspension until it "breaks in?" My gut tells me no.
I'm going over in my head what might be loose in the suspension. We torqued most everything we could to factory spec, and using the no spring compressor method we didn't really tear too much apart.
It sounds sort of like swaybar bushing clunk from worn-out swaybar linkages (dealt with that in my old honda) so I'm suspicious of the linkages being loose, but we tightened those up pretty darn tight. Wonder if tearing them down and moving them out of the way was enough to upset them. Luckily that's a cheap replacement if it's needed.
Looking for any suggestions on areas to take a look at to figure this out. I tried shaking the truck from side to side while parked and couldn't get any noises out of it, so any other pointers would be appreciated.
'14 SR5 in Classic Silver, Wilpeak AT3Ws, miscellaneous electrical odds and ends.
axel1 is offline   Reply With QuoteReply With Quote
Old 06-12-2020, 02:25 PM #118
TotalAutomotiveLV TotalAutomotiveLV is offline
TotalAutomotiveLV has a spectacular aura about TotalAutomotiveLV has a spectacular aura about TotalAutomotiveLV has a spectacular aura about
Looking for Bilstein 5100's?
In-Stock and Shipping Daily - Click Here
Complete Sets are already discounted for forum members.
Price includes shipping to Continental US and No Sales Tax outside NV.
_
TotalAutomotiveLV is offline   Reply With QuoteReply With Quote
Old 06-23-2020, 10:49 AM #119
Bilstein 5100 Complete Kits continue to be a Popular Choice!
Rear 5100's, Part #33-187174 - Limited Stock
_
Old 06-23-2020, 05:26 PM #120
GunRock0811 GunRock0811 is offline
Real Name: Sam
GunRock0811 is on a distinguished road
Real Name: Sam
_
Just spoke with Jason on the TA-LV team, I've got to say he's a bright guy. He spent a while explaining things and really making sure he knew what I needed. I look forward to working with you folks in the future!
2019 4Runner ORP - Modified.
2010 4Runner LTD - Stock Daily Driver.
GunRock0811 is offline   Reply With QuoteReply With Quote
2010+ , 4runner , bilstein , complete , shipping
FS: Bilstein 5100 Series Ride Height Adjustable Front Shocks, 5th gen, $80 SLC, UT T4Rdvm For Sale: Suspension/Wheels/Tires 1 08-10-2015 11:57 PM
bilstein 5100's series question runner823 3rd gen T4Rs 1 03-06-2014 03:06 PM
Bilstein 5100 series shocks and bull bar bevel2872 General Discussions 3 03-31-2012 08:50 PM
Bilstein 5100 Series Shocks pearlj10 Classifieds - buy & sell (no commercial ads please) 3 04-14-2010 11:51 PM
