Old 03-18-2019, 10:51 AM #31
STLDAVE's Avatar
STLDAVE STLDAVE is offline
STLDAVE is on a distinguished road
STLDAVE's Avatar
Originally Posted by Bayou_Pro View Post
It's the same. Toyota OEM oil is made by Mobil.
My local dealer told me the same thing. Toyota oil is Mobil 1.
2011 Salsa Red TE, KDSS, Running boards (not sure what to replace these with), Weathertec mats, Canvasback cargo liner, BudBuilt skid plates, full set of Billy 5100s, Light Racing UCAs, Toytec Ultimate front coilovers (with the "correct" 5th gen 5100s), SAW 1.5 rear coils, ScanguageII...
STLDAVE is offline   Reply With QuoteReply With Quote
Old 03-18-2019, 04:58 PM #32
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
I was actually told the same thing by my Mobil rep at work BUT it's not Mobil 1 It's a completely different formula made specifically for Toyota to their spec.
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 03-18-2019, 08:34 PM #33
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
No one seemed to mention that there are quite a few Mobil 1 proucts these days in 0W-20 weight. 7 when I use their oil selection website. Even the TGMO formula was changed since it’s intro. I used it when I could find it at a reasonable price. Now I’ve been perfectly happy with M1 Extended Performance.
What type of oil and oil filter for my car? | Mobil™ Motor Oils
1000MPH is offline   Reply With QuoteReply With Quote
Old 03-18-2019, 08:45 PM #34
Real Name: Chris
Real Name: Chris
First oil change at 2K miles with Toyota oil, 2nd at 5K miles was Toyota oil, 3rd at 10K miles was M1 Advanced Fuel economy and I thought the engine got louder but thought it was all in my head. 15K mile change is Valvoline SYNpower and I again feel like it got even louder. Issue is, I only put about 7500 miles a year on my 4Runner so these oil changes are done at different times of the year in different temperatures. When I change it at 20K I will be going back to Toyota oil and we'll see what happens. That'll be my own little test to see how quiet or noisy it is. Again though that'll be around August when the oil is thinner at start up so who knows.
Old 03-19-2019, 08:06 AM #35
4runnerinbc 4runnerinbc is offline
4runnerinbc is on a distinguished road
Just in process of buying a new 2019 4Runner.
First few oil changes will be at the dealer.
Just wondering if your local dealer, or mine hear in BC Canada might be able to cheap out?
Or would they have to buy the quality Toyota spec/mobil 1 oil discussed here?
4runnerinbc is offline   Reply With QuoteReply With Quote
Old 03-19-2019, 08:21 AM #36
Redsoxx1918 Redsoxx1918 is offline
Redsoxx1918 is a jewel in the rough Redsoxx1918 is a jewel in the rough Redsoxx1918 is a jewel in the rough Redsoxx1918 is a jewel in the rough
You’ll be fine at the dealer. Relax.
Redsoxx1918 is offline   Reply With QuoteReply With Quote
Old 03-19-2019, 08:27 AM #37
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
I switched to m1 at around 140k, and do 3k-5k OCI's. I can definately say that the one time I ran pennzoil it was much quieter than the m1. I was at the dealer yesterday and was quoted 6.42/qt for the toyota oil. I will be changing it this weekend and will update on noise. I may do a before and after video to capture the sound. I've been using the M1 high mileage EP. I'm at 167k now. I switched to m1 because after 140k of dealer changes I was developing sludge, and they never greased ANY of the zerk fittings. I did have a couple of OCI's past 10k, which may have helped the sludge develop. I also have other theories, but they are just that. That is why i do 3-5k changes now. Forthose of you using the dealer, check your zerks. Mine still had factory black coating on them at 140k! No grease would go in until I cleaned it off!
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 03-19-2019, 08:49 AM #38
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
I don't know how things work in Canada. In the U. S. - car dealers buy oil in bulk. In many cases, they use ONE oil. That could be 5W-30; 5W-20, who knows. Whatever the dealer wants to use. Every car gets that ONE weight of oil whether it's what's called for or not.
People on another Toyota forum went "oh no no no...my dealer would not do that". A few techs chimed in and that was the end of that.
The only way you will ever get what you want for any vehicle you own is to supply the parts yourself and roll up your sleeves.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 03-19-2019, 09:18 AM #39
northcoast's Avatar
northcoast northcoast is offline
northcoast will become famous soon enough
northcoast's Avatar
And it's probably not TGMO.
2016 Nautical Blue T4R TEP w/KDSS, Oil Filter canister upgrade, Eibach Pro Truck lift 2.75/1.0, JBA UCAs, XD Machete 17X9 Wheels, Falken Wildpeak 275/70/17.
northcoast is offline   Reply With QuoteReply With Quote
Old 03-19-2019, 11:12 AM #40
sandcrawler's Avatar
sandcrawler sandcrawler is offline
sandcrawler has a spectacular aura about sandcrawler has a spectacular aura about
if you actually have sludge (which totally sucks btw) you may be better off using the Pennzoil Platinum (or Ultra Platinum) as its chemistry purportedly cleans internals better than other oils.
10 TE - salsa, KDSS+JBL+Nav
ICON XT COs (+IVD) & tubular UCAs • ICON rear coils & 2.5 remote reservoirs + shin guards • Shrockworks • FN Five Star + 285/70 Mickey Thompson MTZ • TRD CAI + aFe Pro Dry S • Magnaflow • ARB diff breather • rack delete + Thule • H9 lo, 9011 hi, selective Y fog • FJ shifter • ScanGauge
06 SE, galactic gray V8: sold // 93 SR5, lots of rust, salt, & mods: R.I.P. // 71 FJ40, never should've let it go
sandcrawler is offline   Reply With QuoteReply With Quote
Old 03-19-2019, 11:49 AM #41
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Originally Posted by genesyn View Post
Planning to do my 1st oil change soon. Any difference using Mobil 1 synthetic vs. OEM toyota 0-20 oil?
I believe most synthetics are similar. Any differences are probably just splitting of hairs.
The reason I say this is that I've owned quite a few Toyotas over the past 37 years, and have driven somewhere around 1.3 million miles in them. I've bought used ones and new ones (mostly used).
I used conventional oils until my 1988 4Runner, where I converted to Mobil 1 at around 100k miles. That Runner received 305,000 miles, and several other cars went well over 200k. With all those miles and engine types, I only had one engine that ever experienced a noticeable increase in oil consumption. That was a 2002 Chevy Prizm (i.e. Toyota Corolla 1.8 engine), and that engine had a design flaw that resulted in rings wearing prematurely (past 150k miles).
So for the next 300,000 miles, I bet you don't see any problems related to your choice of oil if you're using a good synthetic.
My 2 cents.
thennen is offline   Reply With QuoteReply With Quote
Old 03-19-2019, 11:56 AM #42
Jivewalker's Avatar
Jivewalker's Avatar
I have read that somewhere as well, along with a bunch of other ideas like running ATF, SeaFoam, Rotella, etc. For me, engine runs great, filter comes out fairly clean at my 3-5k changes, and oil doesn't look bad. Havent pulled the valve covers or the oil pan, but did pull the OCV screens out and they had some sludge on them. cleaned them up and has been running good since.
I may give the Pennzoil another shot if I can find the Ultra for a decent price. They all have claims of this and that, but hard to verify any of it. thats why i just do short OCI's.
I am fragile.
Not like a flower.
But like a bomb.
Old 03-19-2019, 04:48 PM #43
Real Name: Chris
Real Name: Chris
Sludge is generally from going too long before changing your oil. Yeah I know Toyota says run it for 10K but that's BS IMO The same rep that told me the Toyota oil is made by Mobil also told me DO NOT run it for 10k, it will not hold up and is not designed for it by any means. No matter what oil I use, I will not go past 5K miles on it.
Old 03-19-2019, 04:58 PM #44
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
I'm quite certain that original conventional Toyota oil was just Mobil 5000. So not totally incorrect. OEM synthetic may be a Mobil product made specifically for Toyota.
Regardless, oil is oil^1000.
Old 03-19-2019, 05:03 PM #45
Real Name: Chris
Real Name: Chris
From what I was told, they do make it but to Toyota spec. It does not match any other oil they sell over the counter and is Toyota specific. Who knows, I just know the M1 definitely made my engine louder. We'll see what happens when I go back to Toyota Mobil lol
BTW, oil is absolutely not oil. Oils are by no means all created equally.
mobil , oem , oil , synthetic , toyota
Mobil 1 Synthetic Clearance $2.97 a Quart gamefreakgc 3rd gen T4Rs 2 06-25-2015 02:02 PM
New cheaper synthetic oil from Mobil jwyshrek General Discussions 0 05-05-2011 07:54 AM
Mobil 1 Synthetic Lube Lexusbstrdchild Maintenance/Detailing 2 11-14-2010 04:11 PM
Mobil 1 Synthetic cheaper at Walmart geenowalker Maintenance/Detailing 4 02-11-2007 03:07 AM
Mobil 1 synthetic oil varieties txtroutbum Maintenance/Detailing 11 12-13-2006 12:34 PM
