Old 03-14-2019, 07:30 PM #1
genesyn genesyn is offline
genesyn is on a distinguished road
mobil 1 synthetic vs toyota OEM oil
Planning to do my 1st oil change soon. Any difference using Mobil 1 synthetic vs. OEM toyota 0-20 oil?
genesyn is offline   Reply With QuoteReply With Quote
Old 03-14-2019, 08:25 PM #2
Harrisnc Harrisnc is offline
Harrisnc will become famous soon enough
I use the toyota oil and filter because the dealership always has it. I use Mobil 1 in my Silverado but sometimes I have to go to multiple stores to get it.
2022 Limited 4x4 Silver
2017 TRD Offroad. Barcelona Red, 265 BFG KO2, Eibach Pro-truck 1.6/1, Shrockworks sliders-TRADED
Harrisnc is offline   Reply With QuoteReply With Quote
Old 03-14-2019, 10:46 PM #3
redneckj's Avatar
redneckj redneckj is offline
redneckj will become famous soon enough
redneckj's Avatar
Mobil 1 at Walmart. 5 quarts is about $27.00(7 quarts needed) and use a factory filter.
redneckj is offline   Reply With QuoteReply With Quote
Old 03-14-2019, 11:57 PM #4
jbinmd's Avatar
jbinmd jbinmd is offline
jbinmd will become famous soon enough
jbinmd's Avatar
^^^ This is what I do as well for all of my vehicles. Mobile1 occasionally goes on "rollback" at Wallyworld for even cheaper.
2014 4Runner Limited - Barcelona Red
LFD Offroad 3/4 Roof Rack, Eibach Pro-Truck suspension kit, TE rocker conversion, OEM running boards from a TRD OR, 17x8 -10 FN Countersteer Type-X wheels, Cooper AT3 4S tires 265/70-17.
jbinmd is offline   Reply With QuoteReply With Quote
Old 03-15-2019, 12:00 AM #5
osugsxr osugsxr is offline
Walmart mobil one sales occasionally. I ended up with 40 qts of full synthetic euro at like $15
Old 03-15-2019, 01:23 AM #6
willo willo is offline
Real Name: Will
willo is on a distinguished road
Real Name: Will
Mobile 1 quietly lost LL01 certification for BMW a while back so I took a hard look at it. It's not a great oil. it's decent oil but testing over time wasn't impressive in my research. On the other hand Castrol edge is fantastically rated. (For now)
That said regular changes are generally sufficient but I eyeball my oil choice sideways every so often after being quietly screwed by m1.
Reading up on 0w20 is interesting. In the end I opted for edge with Toyota filters. A pair of 5 quart bottles ran me a bit over $50 via prime. Another bottle will give me two oil changes easy.
willo is offline   Reply With QuoteReply With Quote
Old 03-15-2019, 02:34 AM #7
Tuco S.'s Avatar
Tuco S. Tuco S. is offline
Tuco S. has a spectacular aura about Tuco S. has a spectacular aura about Tuco S. has a spectacular aura about
Tuco S.'s Avatar
I'm also not a big fan of Mobil 1, although I haven't tried the 0W-20. My experience is with Volkswagens and VW 502 spec oil. I've used both Mobil 1 0W-40 and Castrol Edge 0W-40, and the car definitely runs smoother and quieter on the Castrol which seems to be a bit thicker and doesn't shear down as quickly. Both oils are simarly priced. I'll probably stick with Edge when I get my 4Runner.
Tuco S. is offline   Reply With QuoteReply With Quote
Old 03-15-2019, 02:52 AM #8
Whippersnapper02's Avatar
Toyota doesn't make oil so it's anyone that can get the contract and that meets specs.
Mobil 1 is only recommended by companies they sent checks to.
In the end, any off the shelf oil with the correct viscosity will work. Just change it when it's needed.
Old 03-15-2019, 02:59 AM #9
CRB Racing CRB Racing is offline
CRB Racing has a spectacular aura about CRB Racing has a spectacular aura about
I have used Mobile1 in my 3rd gen since it was new. I just hit 300k, the cams and heads look brand new with no visible wear or discoloration. I’m going to stick with that for my 5th gen!
CRB Racing is offline   Reply With QuoteReply With Quote
Old 03-15-2019, 07:44 AM #10
jbjones85's Avatar
jbjones85 jbjones85 is offline
Real Name: Josh
jbjones85 is on a distinguished road
jbjones85's Avatar
Real Name: Josh
i've used M1 and Toyota OEM in the past on my 5th gen. have used the toyota oil the last 2 oil changes because my local parts guy gave me a good price on it and I was there anyways getting something else.
2015 TEP W/KDSS. 285/70 KO2's, OPOR Sliders, GOBI rack, King 2.5 ext. travel w/adj, Weathertech Mats, Vision X front lighting, Spacers until time for new tires, ARB OBA, RCI Skids, Ellis Precision FJ Style shifter.
jbjones85 is offline   Reply With QuoteReply With Quote
Old 03-15-2019, 07:59 AM #11
arehman11 arehman11 is offline
arehman11 has a spectacular aura about arehman11 has a spectacular aura about
Toyota oem for me, $6.30 a quart at my local dealer and since I am still under warranty, want to make sure they have no excuses.
2017 MGM TRD Off Road Premium
arehman11 is offline   Reply With QuoteReply With Quote
Old 03-15-2019, 08:44 AM #12
Bayou_Pro's Avatar
Bayou_Pro Bayou_Pro is offline
Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light
Bayou_Pro's Avatar
It's the same. Toyota OEM oil is made by Mobil.
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
Bayou_Pro is offline   Reply With QuoteReply With Quote
Old 03-15-2019, 09:51 AM #13
enyce enyce is offline
enyce is on a distinguished road
Mobil 1 0W-20 and Wix oil filter since day one. 36,000 miles currently and the engine has zero problems. Keep in mind Toyota does not make their own oil or filters. They do ask manufacturers to add certain additives to their brand to stand apart from others.
2015 4Runner Trail Non-KDSS Husky Floor Mats Falken Wildpeak A/T3W P265/70R17 AFe Drop in Air Filter So far stock... Loving it
enyce is offline   Reply With QuoteReply With Quote
Old 03-15-2019, 12:45 PM #14
IanB's Avatar
IanB IanB is offline
IanB has a spectacular aura about IanB has a spectacular aura about
IanB's Avatar
Another option for any Canadians, Motomaster Formula 1 Synthetic is a full synthetic made by Shell for Canadian Tire, goes on sale as low as $16.99CAN for 5L, I stock up when it goes on sale. I use this stuff in all my gas engines.
I'm sticking with Toyota filters.
Also, Mobil 1 is junk as far as synthetic oils go, with the exception of the 0w20 Euro grade that is made in Germany. Historically, this was the only grade of Mobil 1 that was actually a full synthetic and not a blend marketed as a full synthetic.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
IanB is offline   Reply With QuoteReply With Quote
Old 03-15-2019, 12:50 PM #15
stphnman20's Avatar
stphnman20 stphnman20 is offline
stphnman20 is on a distinguished road
stphnman20's Avatar
My Local Costco has a case of 6qrts Mobil 1 0W20 for $25. I use that with OEM filter.
stphnman20 is offline   Reply With QuoteReply With Quote
mobil , oem , oil , synthetic , toyota
Mobil 1 Synthetic Clearance $2.97 a Quart gamefreakgc 3rd gen T4Rs 2 06-25-2015 02:02 PM
New cheaper synthetic oil from Mobil jwyshrek General Discussions 0 05-05-2011 07:54 AM
Mobil 1 Synthetic Lube Lexusbstrdchild Maintenance/Detailing 2 11-14-2010 04:11 PM
Mobil 1 Synthetic cheaper at Walmart geenowalker Maintenance/Detailing 4 02-11-2007 03:07 AM
Mobil 1 synthetic oil varieties txtroutbum Maintenance/Detailing 11 12-13-2006 12:34 PM
