Possible tire rub with swap
I am also considering swapping from stock SR5 whees to the TRDs. Both are 7" wide, but the offest is different (more negative on the TRDs). It seems that many people have made the swap without problems. At least one owner apparently got rubbing--perhaps the tire size or brand of tire they used was just enough bigger to catch a corner of tread. In any case, there is the real possibility that the change in offset might change the tire position enough to make rubbing a risk with the TRD wheels but not with the stock wheels.
Has anybody put 275/70/17 KO2s with TRD wheels on an SR5? If so, any rubbing?
