Old 08-16-2019, 10:28 AM #16
awhitney1 awhitney1 is offline
awhitney1 will become famous soon enough awhitney1 will become famous soon enough
I'm confused by the torque spec numbers for the inner tie-rod. What is the actual torque spec number to use? Thanks!
Originally Posted by Xtremluck View Post
Thanks man I just received a new OEM inner tie rod. To confirm our inner tie rods do not have a locking washer? Most inner tie rods do but the factory manual seems to indicate we donít. I was also surprised my replacement didnít come with one.
awhitney1 is offline   Reply With QuoteReply With Quote
Old 11-16-2019, 08:17 AM #17
ArcticEd ArcticEd is offline
ArcticEd is on a distinguished road
Instructions on How to Remove/Install an Inner Tie Rod on a 5th gen 4runner
1. Remove wheel
2. Loosen the jam nut on the outer tie rod end
3. Remove the cotter pin and castle nut
4. Separate the outer tie rod end from the steering knuckle
5. Back off and remove the outer tie rod end (Counting how many turns for reinstallation later)
6. Remove the clamps and boot for the inner tie rod
7. Turn your steering wheel all the way out to make the inner tie rod end more accessible
8. Using an adjustable plumbing wrench loosen and remove the inner tie rod (May require additional leverage)
9. Install the new inner tie rod using blue loctite on threads (Torque to factory spec)
10. Reinstall the tie rod boot using a zip tie to secure the boot to the steering rack and the original clamp for the outer portion
11. Reinstall the jam nut
12. Reinstall the outer tie rod end (Counting the turns you documented in step 5)
13. Reinstall the outer tie rod end castle nut (Torque to factory spec)
14. Install a NEW cotter pin on the castle nut
15. Tighten the outer tie rod end jam nut
My Original Post Below
Question: So I need to replace my driver side inner tie rod because of some play. Already ordered the OEM part but need to know what size wrench I need to use for the power steering rack to remove and reinstall the inner tie rod. I know you can use an adjustable pipe wrench for the inner tie rod end but you need a wrench on the steering rack side to prevent the torque being transmitted to the rack. Hoping folks on here have done it before. Any ideas?
Answer: You can't use a 1-1/16" wrench on the steering rack side. It's too small. Not sure what size you can use I just torqued the inner tie rod end on and off. No issues.
I'm about to replace both inner & outer tie rods on both sides & came across this looking for tips/tricks.
The steering linkage reassembly page in the service manual (Doc ID: RM0000039T100IX) says to "Fill up the ball joints of the steering rack ends with MP grease", and I don't see that step listed above.
Does anyone know if you have to apply grease to the inner tie rod ends and what type of grease is required?
TIA
2010 Mag Gray LE; Overland Warehouse 2.5" kit; LR UCA's; hard-wired radar detector; 17x8.5 MB Torque Wheels; 285/70/17 Duratracs (all 5); Bud-Built Bump-out Sliders 1/3 plating; WeatherTech Digiliners
ArcticEd is offline   Reply With QuoteReply With Quote
Old 11-20-2019, 01:16 PM #18
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a jewel in the rough Xtremluck is a jewel in the rough Xtremluck is a jewel in the rough Xtremluck is a jewel in the rough
Xtremluck's Avatar
TIA
They should come pre greased
'12 Silver 4Runner SR5: 14+ facelift, Pelfreybilt front, CBI Rear, Warn M-8000S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, Icon CDCV suspension w/UCAs, OME 899, Nitto RG 285s, Full RCI Skids, Metaltech Sliders, Gobi Rack, ARB Awning, Rotopax,1up Hitch Rack
Xtremluck's 2012 SR5 Build Thread
Instagram - @Aperture20
Xtremluck is offline   Reply With QuoteReply With Quote
Old 04-10-2020, 10:46 PM #19
WLSchroder WLSchroder is offline
Real Name: Walt
WLSchroder is on a distinguished road
Real Name: Walt
What is the 'knock'
Ok friends I completed this job last night and it eliminated my steering knock!! Edited my first post with step by step instructions on how to do this. Enjoy.
I have noticed a very slight 'clunk' or 'knock' when I turn the wheel slowly. Turn to the right, slight clunk. Turn the left, clunk. I can 'feel' it in the steering wheel. And on a rough trail or dirt road, its worse. Thoughts?
WLSchroder is offline   Reply With QuoteReply With Quote
Old 12-04-2020, 10:47 AM #20
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a glorious beacon of light Jivewalker is a glorious beacon of light Jivewalker is a glorious beacon of light Jivewalker is a glorious beacon of light Jivewalker is a glorious beacon of light
Jivewalker's Avatar
Great info, I plan on doing inners and outers very soon. I may get the loaner inner end removal tool though so that I can get tightened to proper torque.
2012 TE KDSS | Black| 265/70R17 C KO2's @ 44psi | 222,000 miles |Link To Inside Fishing Rod Holder Mod
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 04-13-2021, 10:43 AM #21
JSBTRD JSBTRD is offline
JSBTRD is on a distinguished road
I just replaced both my inner and outer tie rods with oem replacement parts and I am now experiencing the same very slight "clunk/knock" when turning wheel left or right and I can also feel it in the steering wheel. WLSchroder, you ever find out what was causing your problem?
Anyone else experienced this issue and how did you correct it?
JSBTRD is offline   Reply With QuoteReply With Quote
Old 04-13-2021, 10:57 AM #22
tm965 tm965 is offline
tm965 is a jewel in the rough tm965 is a jewel in the rough tm965 is a jewel in the rough
could also be your LCA bushings being shot. i encountered the clunk/pop at parking lot speeds/turns when mine were ruined.
tm965 is offline   Reply With QuoteReply With Quote
rack , rod , steering , tie , wrench
Lower Ball Joint replacement or dust boot replacement help? dot_tom 5th gen T4Rs 7 01-11-2018 11:52 PM
xreas replacement - shock vs shock/spring replacement amheck 4th Gen T4Rs 21 11-14-2017 08:21 PM
3rd Gen 4runner Rear Coil Spring Replacement and Rear Shock Bushing Replacement mtbtim 3rd gen T4Rs 7 11-28-2016 11:43 AM
JBL replacement toybox 4th Gen T4Rs 6 03-09-2014 11:18 PM
CV boot replacement vs entire joint replacement zerowkul98 Maintenance/Detailing 3 06-29-2010 06:30 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
