Old 03-17-2019, 09:38 PM #1
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
Inner Tie Rod Replacement
Instructions on How to Remove/Install an Inner Tie Rod on a 5th gen 4runner
1. Remove wheel
2. Loosen the jam nut on the outer tie rod end
3. Remove the cotter pin and castle nut
4. Separate the outer tie rod end from the steering knuckle
5. Back off and remove the outer tie rod end (Counting how many turns for reinstallation later)
6. Remove the clamps and boot for the inner tie rod
7. Turn your steering wheel all the way out to make the inner tie rod end more accessible
8. Using an adjustable plumbing wrench loosen and remove the inner tie rod (May require additional leverage)
9. Install the new inner tie rod using blue loctite on threads (Torque to factory spec)
10. Reinstall the tie rod boot using a zip tie to secure the boot to the steering rack and the original clamp for the outer portion
11. Reinstall the jam nut
12. Reinstall the outer tie rod end (Counting the turns you documented in step 5)
13. Reinstall the outer tie rod end castle nut (Torque to factory spec)
14. Install a NEW cotter pin on the castle nut
15. Tighten the outer tie rod end jam nut
My Original Post Below
Question: So I need to replace my driver side inner tie rod because of some play. Already ordered the OEM part but need to know what size wrench I need to use for the power steering rack to remove and reinstall the inner tie rod. I know you can use an adjustable pipe wrench for the inner tie rod end but you need a wrench on the steering rack side to prevent the torque being transmitted to the rack. Hoping folks on here have done it before. Any ideas?
Answer: You can't use a 1-1/16" wrench on the steering rack side. It's too small. Not sure what size you can use I just torqued the inner tie rod end on and off. No issues.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 03-18-2019, 01:57 AM #2
rigtec's Avatar
rigtec rigtec is offline
Real Name: Greg
rigtec is just really nice rigtec is just really nice rigtec is just really nice rigtec is just really nice
rigtec's Avatar
Real Name: Greg
Hi Xtremluck,
...it should be the same size as the original tie-rod. Upon removal of the old tie-rod, just be sure to count/mark the number of turns, write it down, and match the number of turns installing the new part! 'Best to you',
rig
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
rigtec is offline   Reply With QuoteReply With Quote
Old 03-18-2019, 07:05 AM #3
Gt4r Gt4r is offline
Gt4r is on a distinguished road
Autozone has a loan a tool with all the sizes and you can use a torque wrench on.
2014 Mag Gray TEP, Toyo OC AT2, 5100s and JBA UCAs
Gt4r is offline   Reply With QuoteReply With Quote
Old 03-18-2019, 09:27 AM #4
Xtremluck's Avatar
Xtremluck's Avatar
Originally Posted by rigtec View Post
Hi Xtremluck,
rig
What you mentioned is the outer tie rod end. Will be following that procedure of course but am looking for information on the inner tie rod.
Old 03-18-2019, 09:42 AM #5
Xtremluck's Avatar
Xtremluck's Avatar
Yup, I also know that harbor freight makes tools as well for easy removal and installation. However, they only work on the inner tie rod itself. I need to know what size wrench to use to counteract the torque on the steering rack side.
You can see what I mean in this video for a Toyota Tacoma inner tie rod replacement:
Toyota Tacoma Inner Tie Rod Replacement
Looks like he uses an 1 1/16" wrench to do it so I'm going to give that a shot.
Old 03-18-2019, 11:43 AM #6
rochmpr's Avatar
rochmpr rochmpr is online now
Real Name: Krister
rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all rochmpr is a name known to all
rochmpr's Avatar
Real Name: Krister
Yep, was going to link you to that video. I would think a 27 mm would work, quite possibly.
2020 Tundra Limited Crew Max 4X4 - Tundra Build
2014 4Runner TE - rochmpr Build - SOLD
rochmpr is online now   Reply With QuoteReply With Quote
Old 03-18-2019, 11:16 PM #7
rigtec's Avatar
Real Name: Greg
rigtec's Avatar
Real Name: Greg
Hi Xtremluck... Great user name; wish I could claim the same, Lol!
The new Inner Tie-rod should be the same as the factory original (thread, diameter and length)! Also, why change the One tie-rod end when ALL 4 should have the exact same proportional mileage/wear on them; I only ask this because you have to align the front end after any component replacement? 'Best',
rig, cheers!
Old 03-19-2019, 08:48 AM #8
Xtremluck's Avatar
Xtremluck's Avatar
rig, cheers!
That's a fair question. I've already replaced both outer tie rod ends but only replacing the driver side inner because its the only one having symptoms of failure. I could replace both but Im trying to reduce throwing endless amounts of money into this thing and getting more life out of OEM components. At this point I think I literally have replaced most of the OEM front suspension :P
Old 03-19-2019, 08:49 AM #9
Xtremluck's Avatar
Xtremluck's Avatar
Ill be posting a step by step how to on this once I tackle the job this weekend. I have a feeling those who wheel their rigs will need to do this eventually.
Old 03-19-2019, 03:42 PM #10
You dont need another wrench. The 4runner tie rod is not the same as the one in your vid. I used this fj cruise video YouTube as a guide when I replaced my inner tie rod. The only difference is I didnt find a locking washer on the original inner tie rod.
Old 04-20-2019, 10:21 AM #11
Xtremluck's Avatar
Xtremluck's Avatar
Thanks man I just received a new OEM inner tie rod. To confirm our inner tie rods do not have a locking washer? Most inner tie rods do but the factory manual seems to indicate we don’t. I was also surprised my replacement didn’t come with one.
Old 04-20-2019, 01:33 PM #12
Correct. I have a 2014 and it didnt have a locking washer. I used red loctite and torqued to spec.
Old 05-03-2019, 09:26 AM #13
Xtremluck's Avatar
Xtremluck's Avatar
Ok friends I completed this job last night and it eliminated my steering knock!! Edited my first post with step by step instructions on how to do this. Enjoy.
Old 05-03-2019, 10:11 AM #14
nb rob's Avatar
nb rob nb rob is offline
nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice
nb rob's Avatar
Nice writeup. thanks for sharing- and I'm glad it got rid of your knock
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
nb rob is offline   Reply With QuoteReply With Quote
Old 05-03-2019, 10:48 AM #15
rochmpr's Avatar
Real Name: Krister
rochmpr's Avatar
Real Name: Krister
Booked marked for the potential future trail repair. I hope to never have to perform this on the trail, but I already have the spare parts and a now a quick tutorial. It was so much easier in the SAS days with Marlinks and such. Damn IFS
rack , rod , steering , tie , wrench
Lower Ball Joint replacement or dust boot replacement help? dot_tom 5th gen T4Rs 7 01-11-2018 11:52 PM
xreas replacement - shock vs shock/spring replacement amheck 4th Gen T4Rs 21 11-14-2017 08:21 PM
3rd Gen 4runner Rear Coil Spring Replacement and Rear Shock Bushing Replacement mtbtim 3rd gen T4Rs 7 11-28-2016 11:43 AM
JBL replacement toybox 4th Gen T4Rs 6 03-09-2014 11:18 PM
CV boot replacement vs entire joint replacement zerowkul98 Maintenance/Detailing 3 06-29-2010 06:30 PM
