02-27-2024, 11:43 AM
BACK to 4RUNNER.. again, lift opinion?
Hello all, please no spam about searching the forum... I have had (2)4Runners, and various lifts from spacers to ICON, OME: Titans, Tundras, Tacoma, Ridgeline, ZR2, RAM...
I just traded in my RAM diesel back to a 2021 4Runner, and looking for opinions.
- Goal: 3" lift front, 2" rear ( maybe a .5" rear-spacer to keep the rake ( 2000$-ish), no major Armor for now..
- OME - liked it on my Tundra, missed adjustability
- ICON stage 1, great on my last 5th gen
- Never tired ELKA, Toytec-Bilstein, Toytec-Boss, FOX?
- Kings are little over budget
I'm thinking I will just go with ICONs again, but its been about 8 years since I poked on here all the time, so I'm open to suggestions?
Thanks!
Retired: RAM2500, ZR2, Ridgeline, Tundra, Titan, 5thGen, 4thGen, Titian, Xterra
Current: 2021 SR5 with TRD rims, (nothing else for now )
Next: 2024 Landcruiser (Give the 4runner to my teen)?
02-27-2024, 03:42 PM
![El Dusty's Avatar](https://www.toyota-4runner.org/customavatars/avatar275184_4.gif) |
Thanks!
Avoid Toytec Aluma series and Elka. They are the same Canadian made kits and sourcing metric re-build parts or finding someone to work on them is a PITA. The lower bushings will start squeaking every 20-30k miles so will need bushings re-built and are not covered under warranty. I went through one warranty claim and two rebuilds in 4 years.
I cant speak on Ikons, Fox and Kings but they seem to be the best for heavy offroad abuse and easy re-builds. A lot of people love the dobinsons kits and speak highly of their staff who can help you build a kit for your needs.
Bilstein 5100s are tried and tested non-rebuildable entry level kit with some adjustability. Great value imo.
If I could do it all again I would test the OME MT64s. Not a lot of reviews Ive seen yet but they are the new mid-tier kit from ARB and have decent looking adjustability up front (snap rings). The top teir BP-51s are the best performance shocks I have owned but are on the expensive end. I think the MT-64s fill the mid-tier void nicely. Fairly priced for ARB quality too.
Old Man Emu - MT644RS - Standard Suspension Kit with MT64 Shocks
02-27-2024, 05:13 PM
![///AIRDAM's Avatar](https://www.toyota-4runner.org/customavatars/avatar91264_1.gif) |
Real Name: Adam
Real Name: Adam
Bilstein 5100 and Eibach rear springs is pretty cheap and hard to beat honestly.
I personally have Tacoma TRD Offroad front shocks with a 1" spacer in the rear on my 4th Gen and an aluminum spacer on front with eibach rear springs on my 5th gen. I am like 2.55" up front, and .875" rear over stock and i love the way my 5th gen looks with wide tires tucked under it on stock Limited wheels.
There are tons of folks looking for TRD Pro take-offs and aftermarket coil-overs. It depends on how you plan to use it, mall crawlers like mine, i would run 5100s maxed out and the Eibach 2" spring in the rear for what you are looking to get. I can tell you from experience, and this is why i normally stop around 2.5" up front, is that once you go past 2.5" up front you cant keep the camber in factory specs on the front end alignment. So if you plan to go 3" up front you might also want to look into upper A-arms that correct the alignment so you can get the caster back in adjustment. Tons of folks build upper A-arms you can go cheap or go baller just depends on your budget. I saw some of the cheaper $500 sets that had sealed ball joints and the plates welded at a different angle from stock to reduce the angle on the upper ball joints. Honestly i would likely end up with a set like that over something uber expensive like Camburgs or others. Its your call, go as far or as expensive as you want.
current
2005 Tundra DC limited + 2008 4R Urban Runner + 2023 4R TRD Sport
past
2008 Tacoma TRD Sport DC TRD supercharged + 2012 4Runner Limited
02-27-2024, 06:33 PM
Thanks for the responses.... I was going to jut get ICON again, but I did think Bilstein or OME would also work, maybe the mid-grade M64
My wife wants the bathroom remodel done first, but that can be quick
02-29-2024, 10:03 AM
![AggieOE's Avatar](https://www.toyota-4runner.org/customavatars/avatar167341_5.gif) |
My wife wants the bathroom remodel done first, but that can be quick ![Smilie](https://www.toyota-4runner.org/images/smilies/smile.gif)
I have Bilsteins on my SR5 with stock springs and love them. They're a night and day difference in driveability with no nose dive or roll anymore. I'm at 1.75" front and 1.5" rear but if I was going to go to more height, I'd probably go with OME systems.
2015 4Runner SR5 4x4, Bilstein 5100s at 1.75-F with 1.5" Cornfed-R, AirLift 1000 Airbags, 265/70 BFG KO2s, Shrockworks Sliders
2016 Jeep Wrangler Unlimited Rubicon
02-29-2024, 10:56 AM
I had the Bilstein 6112/5160 on my last 4Runner. They were a fairly decent setup for the easy/midlevel trails I take. However, Bilstein wouldn't replace under their "life time" warranty as they said that was "normal wear n tear."
I'm looking at the Eibach Stage 2R setup for my new 4Runner as they have had good reviews, work for the trails I ride, and have some adjustability to them.
2023 SR5 Hefty FabWorks Slider, Falken AT4W
Sold- 2016 TE w/KDSS, Bilstein 6112 (6 passenger, 5 driver) & 5160 w/T13 springs, Firestone Destination AT, Hefty FabWorks Sliders, IS 690TOY Speakers, Husky Liners WeatherBeaters, Covercraft SeatSavers
02-29-2024, 03:58 PM
![TRD PANTHER's Avatar](https://www.toyota-4runner.org/customavatars/avatar286880_7.gif) |
Real Name: BLACK TRD PRO
I have Radflo 2.5 fully adjustable with resi’s. Smooth on and off road. High quality and fully rebuildable. I keep my vehicles for a long time, so I wanted a quality performance suspension system.
02-29-2024, 06:46 PM
Thanks, I also noticed some sites that would pair bilstein 6112 / 5100s with OME coils, so no (or very little ) preload. My previous ICONs were great, but I'm mostly only street duty 90% of the time now.,
02-29-2024, 06:56 PM
![MossJenks's Avatar](https://www.toyota-4runner.org/customavatars/avatar170820_1.gif) |
Real Name: KE0OIC
Real Name: KE0OIC
There must be 1000 threads in the 5th gen section alone on this topic.
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
02-29-2024, 07:27 PM
then i'd stick with someone like dobinsons, bilstein, or eibach. eibach has some nice looking 2.0 coilover units.
also, hello fellow 2x ex titan owner. lmao
03-07-2024, 09:58 PM
lol, 2 Titans, 3rd 4Runner, 2 tundras, 1 Taco, 1 XTerra, couple of jeeps, etc…
03-07-2024, 10:38 PM
I installed Bilstein 6112/5160 like so many others. Icon 2” rear springs. At the time, it was what was available and in my budget. Couldn’t be happier. Lots of miles in weirdo situations in Central Baja made me a believer in the Bilsteins. Maybe I just had good luck. My friend has Icon gear and really pushes it- also had great results, no problems. Take your pick, I suppose.
