Old 03-18-2019, 03:33 PM #1
DigitalRJH DigitalRJH is offline
DigitalRJH will become famous soon enough
LED grille lights - Add a fuse using the tail light / side marker fuse
Hey guys, I'm going to be installing the amber LED lights in the grille and am going to use the under hood fuse box method. Was going to use the 10A INJ fuse so they are on when the ignition was on but then thought I'd rather have them come on when the parking / side marker lights are on. So I'm assuming I simply put the add a fuse into the 10A tail lights fuse that also powers the parking / side marker lights? Thanks
DigitalRJH is offline   Reply With QuoteReply With Quote
Old 03-18-2019, 05:41 PM #2
hardyplante's Avatar
hardyplante hardyplante is offline
Real Name: Shawn (F) & Alex (M)
hardyplante will become famous soon enough
I don't have experience with it but it makes sense to me that it'd work. I don't have anything real valuable I guess lol. I'm just commenting so I can see what someone with true experience says. I'd be interested in the same for our rig.
hardyplante is offline   Reply With QuoteReply With Quote
Old 03-18-2019, 05:49 PM #3
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
It's not uncommon to use the fuse box to control your lights. Just make sure you find away to make that fuse box is dust proof after you run wires to the fuse box.
Old 03-18-2019, 05:54 PM #4
I don’t feel like going through the firewall and also having the fuse box cover off in the cab. I saw some videos on using the engine bay fuse box with the advantage of being able to replace the cover. Just haven’t seen anyone use the tail light marker light fuse.
Old 03-18-2019, 07:41 PM #5
Cndnmax Cndnmax is offline
Cndnmax will become famous soon enough Cndnmax will become famous soon enough
Easiest way would be to use a splice connector to tap the marker wires on the headlights.
Cndnmax is offline   Reply With QuoteReply With Quote
Old 03-18-2019, 09:13 PM #6
SidKo's Avatar
SidKo SidKo is offline
SidKo is on a distinguished road
SidKo's Avatar
+1 on this method. I spliced and soldered in a relay. Now it all lights up together. Works out real well as they are lined up across nicely. Positive from the headlights activates relay while the actual power is from the battery. Used a waterproof connector in the event I need to remove the front grill. Used this connector - https://www.amazon.com/dp/B01A6LTK44
SidKo is offline   Reply With QuoteReply With Quote
Old 03-18-2019, 10:55 PM #7
The relay is overkill imo. The LEDs use so little current that it won’t even come close to affecting the bulb your tapping into.
Old 03-19-2019, 03:28 PM #8
Thanks, but I’d rather not tap into the wiring on my brand new 4R. I figured the fuse method would be the simplest and least intrusive.
Old 03-19-2019, 04:44 PM #9
SoCaFroal SoCaFroal is offline
SoCaFroal is on a distinguished road
I was hesitant to go through the firewall, but it's so easy and non-intrusive I can't think of any reason not do to it this way. Having the open fuse panel inside isn't a big deal. That being said, check out this thread with pics and info
Switched 12v under the hood
I like the idea of adding the waterproof connector though. Good idea.
EDIT: Scratch that, they are tapping into the fuel injection system, no bueno. Sounds like everything in the hood fuse box is always hot.
2018 TRD Offroad Premium w KDSS - Blacked out emblems, Raptor LED's, Fyre Flys LEDs
SoCaFroal is offline   Reply With QuoteReply With Quote
fuse , led , lights , marker , side
Tail light fuse keeps blowing? lumberjude Problems & Warranty Issues 9 06-02-2022 08:16 PM
Where is the Parking/Side Marker Light Fuse gundrted+t4r 5th gen T4Rs 11 03-16-2018 01:36 AM
#6 fuse for 'tail' losing dash lights boogielove 3rd gen T4Rs 2 07-29-2012 11:22 PM
tail light fuse keeps blowing janthony Problems & Warranty Issues 0 10-03-2008 09:17 PM
tail light fuse keeps blowing janthony 4th Gen T4Rs 10 10-03-2008 09:02 PM
